- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My NAS killed the drives after 'ERASE' command
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have had issues with this NAS and disk capacity, had 2 x 2tb and 2 x 4tb. have finally figured out and understood the interesting way netgear try and hide their raid setup, as only had 6tb of space and expected more
so moved 4tb discs to bay 1 and 2, and 2tb to bay 3 and 4
after several factory resets it stubbornly refused to forget about the volume, so i deleted the volume using the NAS menu "ERASE"
erases, fine, counting, says it will reboot when done
THATS when it goes haywire. it has never rebooted properly with the discs in it
i have tried several ways, i can get it to boot with 1 disc, but when i try to create a volume it fails saying cannot access - fsync error
i have put the discs into a windows PC - BIOS detects, but when i try any program to fdisk etc i get "cannot initialise disk"
i have even tried a linux distribution to install, and same fsync error
so the BIOS detects the drive correctly, but somehow the disks are toast - all 4 i cannot access, fdisk, format, nothing so far
suggestions for any tools i may not have already tried? i am astounded, and stumped
firmware is 5.3.13 all latest available. all i did was follow the porcedure and this
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
# hdparm --security-unlock NETGEAR /dev/sda
# hdparm --security-disable NETGEAR /dev/sda
In the NV+ v2 the internal disks should be /dev/sda, /dev/sdb, /dev/sdc and /dev/sdd
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My NAS killed the drives after 'ERASE' command
thanks for this
ok so have built a ubuntu 20.10 desktop, attached hard disk, tried the hdparm, and get security-password "NETGREAR" permission denied
have tried upper and lower case, also tried no password
any other possibility?
- Mark as New
- Bookmark
- Subscribe
- Permalink
also, i can boot into tech support mode and telnet in, but only diskless. if i have any of the secured disks in it - which i imagine i need to fix them - it doesnt boot, sits on boot menu "booting..."
- Mark as New
- Bookmark
- Subscribe
- Permalink
ah ok figured it out thanks for steering in the right direction some more googling with your parameters and tech support root access managed to get things back on track cheers
