× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NAS102 Power light flashing, can't access unit through ReadyCloud
arhlene
Hi, yesterday my NAS was off (possible power outage?) so I powered it back up but it was not visible on the network and the blue power light was/is flashing (1 short, 1 long).  I could not access it through ReadyCloud either ("No devices discovered").  I tried to turn if off and on again but it wasn't responding using the power button, I had to pull the power cable.  I took the drives out, tried to reinstall the OS but I'm not sure if that worked (between pushing the reset button on the back, holding the power button down in front and plugging it back in while only using two hands, it was not smooth going).  I reinstalled one of the drives but that did not work.  I swapped it out with the second drive and am able to access it from my PC (it's backing up to an external drive right now) but the power light is still flashing and ReadyCloud access is still unavailable.  According to RAIDar, I am using firmware version 6.5.1.  Are the drives causing the problem (Seagate ST3000VN000)?  Or is my NAS failing?  Thanks in advance!
Model: RN10200|ReadyNAS 100 Series 2- Bay (Diskless)
Message 1 of 8
Guru
Re: NAS102 Power light flashing, can't access unit through ReadyCloud
It can't work, because the function reinstalls the OS onto the drives.
That suggests a problem with the first drive.  After the backup completes you might want to test it with seatools in a PC.
Can you reach the web admin page (either use https://nas-ip-address/admin, or get there via RAIDar).  It might also be useful to download the log zip file.
Message 2 of 8
arhlene
When I try to access the admin page through RAIDar, I am prompted to enter a username and password but I can't get in.
Message 3 of 8
arhlene
Disregard, I found it.  So, how do I attach a log zip file?
Message 4 of 8
mdgm-ntgr
NETGEAR Employee Retired
You don't. You email the zip file in (see the Sending Logs link in my sig).
Message 5 of 8
arhlene
Ok, I emailed the log file a few hours ago.
Message 6 of 8
Retired_Member
Not applicable
There was only one HDD in the chassis when you downloaded the logs, and it doesn't seems too happy:
Model: ST3000VN000-1H4167
Serial: ******2B
[Tue Jan 10 16:41:13 2017] ata3: SATA link down (SStatus 0 SControl F300) [Tue Jan 10 16:41:13 2017] ata2: SATA link down (SStatus 0 SControl 300) [Tue Jan 10 16:41:13 2017] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [Tue Jan 10 16:41:13 2017] ata1.00: ATA-9: ST3000VN000-1H4167, SC43, max UDMA/133 [Tue Jan 10 16:41:13 2017] ata1.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [Tue Jan 10 16:41:13 2017] ata1.00: configured for UDMA/133 Jan 10 15:45:04 NAS102 kernel: res 51/04:02:02:00:00/00:00:00:00:00/e0 Emask 0x1 (device error) Jan 10 15:45:04 NAS102 kernel: ata1.00: status: { DRDY ERR } Jan 10 15:45:04 NAS102 kernel: ata1.00: error: { ABRT } Jan 10 15:45:04 NAS102 kernel: ata1.00: configured for UDMA/133 (device error ignored) Jan 10 15:45:04 NAS102 kernel: ata1: EH complete Jan 10 15:45:04 NAS102 kernel: ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 Jan 10 15:45:04 NAS102 kernel: ata1.00: irq_stat 0x40000001 Jan 10 15:45:04 NAS102 kernel: ata1.00: failed command: READ DMA Jan 10 15:45:04 NAS102 kernel: ata1.00: cmd c8/00:04:04:00:00/00:00:00:00:00/e0 tag 9 dma 2048 in [repeated numerous times]
So I'd start with that.
You should test this HDD with the manufacturer's tool.
Message 7 of 8
arhlene
So, I bought two new WD Red Pro 4tb drives (WD4002FFWX).  I removed one of the old drives, installed a new one and let it sync.  Then I installed the second new drive and let that sync.  During this time, I received a ton of alerts stating Bit Rot detected errors that couldn't be fixed.  Now, connecting to the NAS is spotty.  It doesn't always show up using RAIDar and I can't access a number of pdf files; I receive an error stating the file is damaged.  I don't know what to do.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2427 views
  • 0 kudos
  • 4 in conversation
Announcements
