× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NIC IP addresses for teaming on ReadyNAS Pro 4
talmage
Tutor
I just received a Pro 4 as a replacement for a broken NVX. Now I want to use both NICs. I'm using static IP addresses in my network. Do I give each of the Pro 4's NICs the same IP address?
Message 1 of 3
TeknoJnky
Hero
Re: NIC IP addresses for teaming on ReadyNAS Pro 4
no.
when you bond the nic's in frontview, it will show them as one interface which gets 1 ip.
I assume that you understand you need a switch that supports bonded ethernet channels, ie a managed/smart switch.
Message 2 of 3
Marto731
Teaming on ReadyNAS Pro 4
Talmage,
As TeknoJuky has said, the switch must support LAG, (link Aggregation ) ,
or Etherchannel as it may be known as.
Both devices should be set to the same
LACP protocol. Test at an off peak time before roll out.
Regards, Marto
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1250 views
  • 0 kudos
  • 3 in conversation
Announcements
