Orbi WiFi 7 RBE973
Reply
NIC speed of NV 102
eggamull
Tutor
NIC speed of NV 102
OS 6.9.0, 2 HDD 4TB, RAID 1 RN10224D
NIC works only on 100 MBit how to force switching to 1Gbits/sec?
Model: RN10211D|ReadyNAS 100 Series 2-Bay
Message 1 of 4
Accepted Solutions
eggamull
Tutor
Re: NIC speed of NV 102
There was a contact stuck inside the RJ45 socket. Now NIC works as before...
Message 4 of 4
All Replies
Guru
If you are connected to a gigabit switch or router, then the next step is to try a different cable.  If some of the wires in the cable aren't connected properly then autonegotiation can fail.
Message 2 of 4
eggamull
Tutor
Hi Stephen, sorry not mentioning it; i did that basic things already: changing switch, router, cable. What aI did latest before the problem was installing Plex-App on NAS.
Thanks anyway
br Albrecht
Message 3 of 4
eggamull
Tutor
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 914 views
  • 0 kudos
  • 2 in conversation
Announcements
