Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NV+ Booting Issues and Possible Data Loss (16344829)
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
04:43 AM
2011-08-10
04:43 AM
Hey guys,
My NV+ has stopped booting successfully, it would always hang and just say "Booting...". I contacted support and they helped as much as they could, but since my unit is no longer under warranty, they couldn't really solve my problem.
What I have figured out is even though all 4 drives passed SeaTools tests, drive 3 somehow had a corrupted partition table. I was instructed to remove that drive and try to boot without it by support. I've done so, but it still just hangs at "Booting...". I am able to ssh into the box in the state that it is in and here is a dump of dmesg after it has stopped booting (hdg is the removed drive):
Does anyone know of anything else I could try? At this point, it seems my data may be unrecoverable.
Add dead device not present and allow master sector.
Link drive hdg to its hwgroup.
hdg: max request size: 512KiB
hdg: use capacity 2930277168 sectors (1500301 MB)
Drive support hpa, still should not change max addr.
:<6>hdg: 2930256688 sectors (1500291 MB), CHS=65535/255/63
::<6> hdg: (Fix non bootable low sector,flag=0xffffffff)
ide3 at 0x300-0x307,0x308 on irq 34
idedisk_deaddisk_init on hdg
ide-disk: hdg: from special init, need to reset values.
Change X_RAID running mode from 0 to 1
::::Update backup SB.
X_RAID: recovery thread got woken up ...
No drive to use, stop recovery.
:<6> hdc: hdc1 hdc2 hdc3 < hdc5 >
:<6> hde: hde1 hde2 hde3 < hde5 >
:<6> hdg:
:<6> hdi: hdi1 hdi2 hdi3 < hdi5 >
kjournald starting. Commit interval 5 seconds
EXT3 FS on hdc1, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
linked, 1000mbps mode
CMD to offline/lost_intr chn(2): 80f07ae0
::<4>EXT2-fs warning (device hdc1): ext2_fill_super: mounting ext3 filesystem as ext2
Adding 255968k swap on /dev/hdc2. Priority:0 extents:1 across:255968k
Adding 255968k swap on /dev/hde2. Priority:0 extents:1 across:255968k
Adding 255968k swap on /dev/hdi2. Priority:0 extents:1 across:255968k
enable_irq(11) unbalanced from f804059c
:<6>hdc: cache flushes supported
:<6>hde: cache flushes supported
CMD to offline/lost_intr chn(2): 80b17ae0
:<6>hdi: cache flushes supported
:<6> hdg: (Fix non bootable low sector,flag=0xfffffff5)
Message 1 of 7
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
05:09 AM
2011-08-10
05:09 AM
Re: NV+ Booting Issues and Possible Data Loss (16344829)
When did you purchase your NV+? Was it purchased brand new on/after Aug 21, 2007?
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
05:12 AM
2011-08-10
05:12 AM
I did purchase it brand new, but it was on May 16, 2007.
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
05:19 AM
2011-08-10
05:19 AM
Support is right. The unit is out of warranty. Was just wanting to make sure.
So support didn't have any paid options available to you for them to attempt data recovery?
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
05:23 AM
2011-08-10
05:23 AM
They didn't offer any, I didn't realize that was an option. I'll reply to them again and inquire about it.
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
05:26 AM
2011-08-10
05:26 AM
That option may only be available to those with units under warranty, I don't know. As a fellow ReadyNAS user though I'd suggest inquiring as to whether there's any option for that. It'd definitely be better than trying to fix the problem yourself.
Another option would be to try a local data recovery company that understands how to recover data from Linux devices that are using RAID.
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
02:22 PM
2011-08-10
02:22 PM
I am still waiting on a response from Netgear if an out of warranty service is even an option.
In the meantime, I acquired a brand new 2TB drive (my NAS contained 4x1.5TB), so I should be able to use the 2TB drive to replace the dead 1.5TB one under normal conditions. I installed the new drive in the slot and turned on the NAS, and of coarse it still hangs at Booting... I then sshed into the box and looked around and this is where things get weird. Both fdisk and hdparm report the new drive in slot 3 as the old one. fdisk shows it as a 1.5TB drive and hdparm even shows the serial number of the old drive. Does anyone have any idea why this may be happening? Is there any way to force the NAS to redetect the drives and (perhaps) attempt recovery?
The only thing that keeps me going on this are the following lines in dmesg:
This is pretty much the last thing that happens before it stops booting. My thought is if I can get the NAS to see the new drive, it may attempt a recovery using it.
Message 7 of 7
