Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NV+ v2 Kernel bug reported when under heavy load via AFP
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-07
03:23 AM
2012-10-07
03:23 AM
Hi folks,
This message may need to be moved to a different section of the forum, because it might be a general ARM kernel problem rather than an AFP-specific problem, but I have only experienced it using AFP.
I recently purchased a NV+ v2 and loaded it with a single 3TB drive (more 3TB disks to come when I need them and they're cheaper). This is my first NAS - up until now everything has been on separate computers, and I'm looking to centralise bulk storage - so the first thing I've had to do is dump a LOT of data onto the drive, from a few different machines (sometimes at once). A couple of times in the initial process of setting up TM backups, but more repeatedly today during a particular transfer task, the NAS has partially stopped responding: it's still online and the shares can be accessed, but in one case the admin interface became inaccessible, and in a couple of cases today it stopped processing data/connections from one particular computer. In all cases, to restore normal operation I've needed to reboot it, and when I've rebooted it with a disk scan, it's turned up a couple of repairable errors (presumably as a result of the crash itself). Today I found that when I tried to dump more than dozen GB or so of data on it (over gigabit ethernet all the way, so pretty quickly), it would stop responding to that computer after a while, and the following error showed up in the system log:
... and here's another one from a bit later:
... and here are the e-mails I received after the disk check:
Any thoughts? Provided it doesn't happen except under extraordinary loads, it doesn't bother me too much... but on the other hand, it's a (somewhat) repeatable kernel crash, so should probably be worth fixing.
Oct 7 16:02:36 The_Library kernel: kernel BUG at mm/filemap.c:1939!
Oct 7 16:02:36 The_Library kernel: Unable to handle kernel NULL pointer dereference at virtual address 00000000
Oct 7 16:02:36 The_Library kernel: pgd = c9bac000
Oct 7 16:02:36 The_Library kernel: [00000000] *pgd=093f6031, *pte=00000000, *ppte=00000000
Oct 7 16:02:36 The_Library kernel: Internal error: Oops: 817 [#1]
Oct 7 16:02:36 The_Library kernel: Modules linked in: tntfs(P) armvpd(P)
Oct 7 16:02:36 The_Library kernel: CPU: 0 Tainted: P (2.6.31.8.nv+v2 #1)
Oct 7 16:02:36 The_Library kernel: PC is at __bug+0x18/0x24
Oct 7 16:02:36 The_Library kernel: LR is at __bug+0x14/0x24
Oct 7 16:02:36 The_Library kernel: pc : [<c002c8a8>] lr : [<c002c8a4>] psr: 20000013
Oct 7 16:02:36 The_Library kernel: sp : cd307d60 ip : 0000397c fp : 00000000
Oct 7 16:02:36 The_Library kernel: r10: cd306000 r9 : 00000000 r8 : 00000fec
Oct 7 16:02:36 The_Library kernel: r7 : 00000000 r6 : 0448f000 r5 : 00001014 r4 : 000012c0
Oct 7 16:02:36 The_Library kernel: r3 : 00000000 r2 : cd307d54 r1 : c05950b3 r0 : 00000027
Oct 7 16:02:36 The_Library kernel: Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Oct 7 16:02:36 The_Library kernel: Control: 0005397f Table: 09bac000 DAC: 00000015
Oct 7 16:02:36 The_Library kernel: Process afpd (pid: 2765, stack limit = 0xcd306270)
Oct 7 16:02:36 The_Library kernel: Stack: (0xcd307d60 to 0xcd308000)
Oct 7 16:02:36 The_Library kernel: 7d60: 000012c0 c009a478 000012c0 c009bf4c 00000fec 000012c0 c08d0ae0 00000000
Oct 7 16:02:36 The_Library kernel: 7d80: 000001d4 cd307ec8 cafbc800 c5b2ba94 c0468c90 c5b2b9f8 00001000 00000000
Oct 7 16:02:36 The_Library kernel: 7da0: c0468c90 c5b2ba94 cd307f58 00000001 00001014 00000fec 00000000 c08d0ae0
Oct 7 16:02:36 The_Library kernel: 7dc0: c5b2b9f8 0448ffec 00000000 0448dfec 00000000 c5b2b9f8 00000000 00002000
Oct 7 16:02:36 The_Library kernel: 7de0: 00002000 c009c6a8 0448dfec 00000000 cd307f18 00002000 00000000 c03a1244
Oct 7 16:02:36 The_Library kernel: 7e00: c18e1540 cd307f18 cd307f58 cd307ec8 cafbc800 c5b2ba94 00000000 00000001
Oct 7 16:02:36 The_Library kernel: 7e20: 000dcd14 c03a0528 00000040 00000000 cd307e3c 00002000 c910b180 c5b2ba68
Oct 7 16:02:36 The_Library kernel: 7e40: cd307ec8 cd307f58 c5b2b9f8 00000001 00000000 cafbc800 c5b2ba94 c009d09c
Oct 7 16:02:36 The_Library kernel: 7e60: 00000040 00002000 cedd3300 0448dfec 00000000 c5b2b9f8 00000001 0448dfec
Oct 7 16:02:36 The_Library kernel: 7e80: 00000000 cd307f58 cafbc800 cd307ec8 000ded18 c012f5a0 0448dfec 00000000
Oct 7 16:02:36 The_Library kernel: 7ea0: cd307ec8 cafbc800 cd307fa8 000000b5 00002000 cd306000 00000000 c00c1718
Oct 7 16:02:36 The_Library kernel: 7ec0: 0448dfec 00000000 ffffffff c99b6f00 00000000 00000001 ffffffff cafbc800
Oct 7 16:02:36 The_Library kernel: 7ee0: 00000000 00000000 00000000 00000000 c89b6000 c89b6000 00000000 00000000
Oct 7 16:02:36 The_Library kernel: 7f00: cd307efc c89b6000 c008753c cd307f0c cd307f0c c00f1c74 0448dfec 00000000
Oct 7 16:02:36 The_Library kernel: 7f20: 00002000 bed96840 cd307f48 00000000 00002000 cedd3328 c8002d80 00000001
Oct 7 16:02:36 The_Library kernel: 7f40: 00000000 c88c3d00 cedd3328 00002000 00000001 cafbc800 000dcd14 00002000
Oct 7 16:02:36 The_Library kernel: 7f60: cafbc800 000dcd14 cd307fa8 c00c2174 cafbc800 000dcd14 00002000 cafbc800
Oct 7 16:02:36 The_Library kernel: 7f80: 000dcd14 000000b5 c0029128 c00c226c 00000003 00000000 0448dfec 00000000
Oct 7 16:02:36 The_Library kernel: 7fa0: 00000003 c0028f80 0448dfec 00000000 00000003 000dcd14 00002000 00000000
Oct 7 16:02:36 The_Library kernel: 7fc0: 0448dfec 00000000 00000003 000000b5 000dcd14 00000001 00002000 000ded18
Oct 7 16:02:36 The_Library kernel: 7fe0: 400f2000 bed967b8 00049cc0 400e51e0 60000010 00000003 e1a00004 ebfffaa2
Oct 7 16:02:36 The_Library kernel: [<c002c8a8>] (__bug+0x18/0x24) from [<c009a478>] (iov_iter_advance+0x74/0xcc)
Oct 7 16:02:36 The_Library kernel: [<c009a478>] (iov_iter_advance+0x74/0xcc) from [<c009bf4c>] (generic_file_buffered_write+0x194/0x2c8)
Oct 7 16:02:36 The_Library kernel: [<c009bf4c>] (generic_file_buffered_write+0x194/0x2c8) from [<c009c6a8>] (__generic_file_aio_write_nolock+0x430/0x480)
Oct 7 16:02:36 The_Library kernel: [<c009c6a8>] (__generic_file_aio_write_nolock+0x430/0x480) from [<c009d09c>] (generic_file_aio_write+0x70/0xe8)
Oct 7 16:02:36 The_Library kernel: [<c009d09c>] (generic_file_aio_write+0x70/0xe8) from [<c012f5a0>] (ext4_file_write+0xbc/0x140)
Oct 7 16:02:36 The_Library kernel: [<c012f5a0>] (ext4_file_write+0xbc/0x140) from [<c00c1718>] (do_sync_write+0xac/0xfc)
Oct 7 16:02:36 The_Library kernel: [<c00c1718>] (do_sync_write+0xac/0xfc) from [<c00c2174>] (vfs_write+0xac/0x154)
Oct 7 16:02:36 The_Library kernel: [<c00c2174>] (vfs_write+0xac/0x154) from [<c00c226c>] (sys_pwrite64+0x50/0x70)
Oct 7 16:02:36 The_Library kernel: [<c00c226c>] (sys_pwrite64+0x50/0x70) from [<c0028f80>] (ret_fast_syscall+0x0/0x2c)
Oct 7 16:02:36 The_Library kernel: Code: e1a01000 e59f000c eb10ce4a e3a03000 (e5833000)
Oct 7 16:02:36 The_Library kernel: ---[ end trace d1004457f4676628 ]---
Oct 7 16:45:36 The_Library kernel: kernel BUG at mm/filemap.c:1939!
Oct 7 16:45:36 The_Library kernel: Unable to handle kernel NULL pointer dereference at virtual address 00000000
Oct 7 16:45:36 The_Library kernel: pgd = cdb18000
Oct 7 16:45:36 The_Library kernel: [00000000] *pgd=04a68031, *pte=00000000, *ppte=00000000
Oct 7 16:45:36 The_Library kernel: Internal error: Oops: 817 [#1]
Oct 7 16:45:36 The_Library kernel: Modules linked in: tntfs(P) armvpd(P)
Oct 7 16:45:36 The_Library kernel: CPU: 0 Tainted: P (2.6.31.8.nv+v2 #1)
Oct 7 16:45:36 The_Library kernel: PC is at __bug+0x18/0x24
Oct 7 16:45:36 The_Library kernel: LR is at __bug+0x14/0x24
Oct 7 16:45:36 The_Library kernel: pc : [<c002c8a8>] lr : [<c002c8a4>] psr: 20000013
Oct 7 16:45:36 The_Library kernel: sp : c8881d60 ip : 00003a09 fp : 00000000
Oct 7 16:45:36 The_Library kernel: r10: c8880000 r9 : 00000000 r8 : 00001000
Oct 7 16:45:36 The_Library kernel: r7 : 00000000 r6 : 1d606000 r5 : 00000014 r4 : 000022c0
Oct 7 16:45:36 The_Library kernel: r3 : 00000000 r2 : c8881d54 r1 : c05950b3 r0 : 00000027
Oct 7 16:45:36 The_Library kernel: Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Oct 7 16:45:36 The_Library kernel: Control: 0005397f Table: 0db18000 DAC: 00000015
Oct 7 16:45:36 The_Library kernel: Process afpd (pid: 2797, stack limit = 0xc8880270)
Oct 7 16:45:36 The_Library kernel: Stack: (0xc8881d60 to 0xc8882000)
Oct 7 16:45:36 The_Library kernel: 1d60: 000022c0 c009a478 000022c0 c009bf4c 00001000 000022c0 c07176e0 00000000
Oct 7 16:45:36 The_Library kernel: 1d80: ce7ef840 c8881ec8 c7864400 ce6bd844 c0468c90 ce6bd7a8 00001000 00000000
Oct 7 16:45:36 The_Library kernel: 1da0: c0468c90 ce6bd844 c8881f58 00000001 00000014 00001fec 00000000 c07176e0
Oct 7 16:45:36 The_Library kernel: 1dc0: ce6bd7a8 1d607fec 00000000 1d605fec 00000000 ce6bd7a8 00000000 00002000
Oct 7 16:45:36 The_Library kernel: 1de0: 00002000 c009c6a8 1d605fec 00000000 c8881f18 00002000 00000000 c03a1244
Oct 7 16:45:36 The_Library kernel: 1e00: c8448440 c8881f18 c8881f58 c8881ec8 c7864400 ce6bd844 00000000 00000001
Oct 7 16:45:36 The_Library kernel: 1e20: 000dcd14 c03a0528 00000040 00000000 c8881e3c 00002000 c9213600 ce6bd818
Oct 7 16:45:36 The_Library kernel: 1e40: c8881ec8 c8881f58 ce6bd7a8 00000001 00000000 c7864400 ce6bd844 c009d09c
Oct 7 16:45:36 The_Library kernel: 1e60: 00000040 00002000 c7000600 1d605fec 00000000 ce6bd7a8 00000001 1d605fec
Oct 7 16:45:36 The_Library kernel: 1e80: 00000000 c8881f58 c7864400 c8881ec8 000ded18 c012f5a0 1d605fec 00000000
Oct 7 16:45:36 The_Library kernel: 1ea0: c8881ec8 c7864400 c8881fa8 000000b5 00002000 c8880000 00000000 c00c1718
Oct 7 16:45:36 The_Library kernel: 1ec0: 1d605fec 00000000 ffffffff ccc94880 00000000 00000001 ffffffff c7864400
Oct 7 16:45:36 The_Library kernel: 1ee0: 00000000 00000000 00000000 00000000 c5648f00 c5648f00 00000000 00000000
Oct 7 16:45:36 The_Library kernel: 1f00: c8881efc c5648f00 c008753c c8881f0c c8881f0c c9242040 1d605fec 00000000
Oct 7 16:45:36 The_Library kernel: 1f20: 00002000 00000000 c20db450 00000000 00002000 c7000628 00000040 00000001
Oct 7 16:45:36 The_Library kernel: 1f40: 00000000 c3e8cc00 c7000628 00002000 00000001 c7864400 000dcd14 00002000
Oct 7 16:45:36 The_Library kernel: 1f60: c7864400 000dcd14 c8881fa8 c00c2174 c7864400 000dcd14 00002000 c7864400
Oct 7 16:45:36 The_Library kernel: 1f80: 000dcd14 000000b5 c0029128 c00c226c 00000003 00000000 1d605fec 00000000
Oct 7 16:45:36 The_Library kernel: 1fa0: 00000003 c0028f80 1d605fec 00000000 00000003 000dcd14 00002000 00000000
Oct 7 16:45:36 The_Library kernel: 1fc0: 1d605fec 00000000 00000003 000000b5 000dcd14 00000001 00002000 000ded18
Oct 7 16:45:36 The_Library kernel: 1fe0: 400f2000 bea3e7b8 00049cc0 400e51e0 60000010 00000003 00000000 00000000
Oct 7 16:45:36 The_Library kernel: [<c002c8a8>] (__bug+0x18/0x24) from [<c009a478>] (iov_iter_advance+0x74/0xcc)
Oct 7 16:45:36 The_Library kernel: [<c009a478>] (iov_iter_advance+0x74/0xcc) from [<c009bf4c>] (generic_file_buffered_write+0x194/0x2c8)
Oct 7 16:45:36 The_Library kernel: [<c009bf4c>] (generic_file_buffered_write+0x194/0x2c8) from [<c009c6a8>] (__generic_file_aio_write_nolock+0x430/0x480)
Oct 7 16:45:36 The_Library kernel: [<c009c6a8>] (__generic_file_aio_write_nolock+0x430/0x480) from [<c009d09c>] (generic_file_aio_write+0x70/0xe8)
Oct 7 16:45:36 The_Library kernel: [<c009d09c>] (generic_file_aio_write+0x70/0xe8) from [<c012f5a0>] (ext4_file_write+0xbc/0x140)
Oct 7 16:45:36 The_Library kernel: [<c012f5a0>] (ext4_file_write+0xbc/0x140) from [<c00c1718>] (do_sync_write+0xac/0xfc)
Oct 7 16:45:36 The_Library kernel: [<c00c1718>] (do_sync_write+0xac/0xfc) from [<c00c2174>] (vfs_write+0xac/0x154)
Oct 7 16:45:36 The_Library kernel: [<c00c2174>] (vfs_write+0xac/0x154) from [<c00c226c>] (sys_pwrite64+0x50/0x70)
Oct 7 16:45:36 The_Library kernel: [<c00c226c>] (sys_pwrite64+0x50/0x70) from [<c0028f80>] (ret_fast_syscall+0x0/0x2c)
Oct 7 16:45:36 The_Library kernel: Code: e1a01000 e59f000c eb10ce4a e3a03000 (e5833000)
Oct 7 16:45:36 The_Library kernel: ---[ end trace b5b8b72b1f26a506 ]---
***** File system check forced at Sun Oct 7 17:00:34 EST 2012 *****
fsck from util-linux-ng 2.17.2
e2fsck 1.41.14 (22-Dec-2010)
/dev/mapper/c-c: recovering journal
Clearing orphaned inode 15893392 (uid=65534, gid=65534, mode=042700, size=4096)
Clearing orphaned inode 15893409 (uid=65534, gid=65534, mode=0100666, size=741)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mapper/c-c: ***** FILE SYSTEM WAS MODIFIED *****
/dev/mapper/c-c: 202396/45547520 files (12.3% non-contiguous), 305451174/728760320 blocks
Message 1 of 4
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-24
09:48 AM
2013-08-24
09:48 AM
Re: NV+ v2 Kernel bug reported when under heavy load via AFP
Hi, did you resolve this problem?
I have simmilar, but it happens when NAS have overloaded CPU (proftpd, smb, copying file over linux etc.)
I'm using newest firmware BETA, but this problem still occure.
regards, Szymon
regards, Szymon
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-24
02:44 PM
2013-08-24
02:44 PM
I never resolved this bug, but it doesn't happen to me any more: only because I no longer have cause to do massive data dumps onto the NAS - my routine use only ever involves a couple of GB at a time via Time Machine from four computers, plus torrents and reading media from it. So for me I presume the bug is still there, but I don't trigger it.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-22
01:26 AM
2014-04-22
01:26 AM
I did trigger this bug again the other day, but either I got lucky or it is now harder to trigger: I transferred 1Tb in total (over gigabit ethernet via AFP), and it only stopped twice - once after about 400Gb, then after another ~10Gb, then it completed the rest of the transfer without a problem.
Message 4 of 4
