× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NV+ wont get IP address after 4.1.13 update
McMacca
Hi Guys,
Pulling my hair out here. My NV+ last reported that it needed a reboot for the FW update to take effect, then upon return to work this week find its dead and will not get an IP address instead defaulting to 192.168.168.168.
I have tried a OS reinstall from the boot menu, direct connect (Following guides found elsewhere on this forum) to 2 different PC's changing cables all the usual stuff and nothing.
I'm sure it was at 4.1.12 before the issue, has 3x 1tb drives in X raid and that's about it.
Any suggestions greatly appreciated.....
Message 1 of 11
Guru
Re: NV+ wont get IP address after 4.1.13 update
Is the network connection led lit (either green or amber)?
Message 2 of 11
McMacca
Amber Solid, Green Blinking (Fast)
Message 3 of 11
Guru
That is very weird. Amber and Green are not supposed to be simultaneously lit.
Are you running gigabit?
Message 4 of 11
McMacca
Yip, Sure am: the switch is a TP Link 24 Port Gigabit hub but I have brought the NAS from another location where it was on a Netgear 24port 10/100 hub with a different router cables etc and it has mode no difference.
Message 5 of 11
Guru
What leds are lit on the TP Link switch?
Message 6 of 11
McMacca
There are 2 Green LEDS - One indicates Gigabit Connection - This is stable and the other is activity which is blinking.
Message 7 of 11
Guru
Does RAIDar find it?
Message 8 of 11
McMacca
Nope, not even when i connect directly between pc and NAS........
Message 9 of 11
McMacca
Ok guys, getting nowhere so it's disaster recovery time. I have another chassis bought on the same day in the same configuration, can I swap the drives over and if so any advice if it's been done before?
These were supposed to be a pair with one as a backup however the main unit has failed just a few days after I had to rebuild the backup due to virus and the backup was only 50% complete. I can't loose data from either set of drives....
All help greatly appreciated. Thx
Message 10 of 11
chirpa
Luminary
If its the same platform (an NV+ v1, sparc), yes you can swap the disks over, configuration will go with it.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1823 views
  • 0 kudos
  • 3 in conversation
Announcements
