Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NVX - Stuck Booting - Upgrade to 4.2.18(x86)
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-25
10:01 AM
2011-07-25
10:01 AM
Download the new 4.2.18 image, upload and upgrade within the FrontView.
Reboot.
Then stuck booting several hours.
Use SSH to check the /var/log/messages, as belows:
So, what's going on?
I've tried the Skip Checking FS mode, but no effect. Plz help.
Reboot.
Jupiter:/var/log# tail messages
Jul 26 00:48:25 Jupiter kernel: ata1: EH complete
Jul 26 00:48:25 Jupiter kernel: ata2.00: configured for UDMA/133
Jul 26 00:48:25 Jupiter kernel: ata2: EH complete
Jul 26 00:48:25 Jupiter kernel: ata3.00: configured for UDMA/133
Jul 26 00:48:25 Jupiter kernel: ata3: EH complete
Jul 26 00:48:25 Jupiter kernel: Adding 524272k swap on /dev/md1. Priority:-1 extents:1 across:524272k
Jul 26 00:48:25 Jupiter kernel: EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: acl,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv1
Jul 26 00:48:25 Jupiter kernel: EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: acl,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv1
Jul 26 00:48:29 Jupiter syslogd 1.4.1#18: restart.
Jul 26 00:53:03 Jupiter kernel: [Hardware Error]: Machine check events logged
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-25
10:02 AM
2011-07-25
10:02 AM
Re: NVX - Stuck Booting - Upgrade to 4.2.18(x86)
And no permission to run the mcelog command.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-25
11:45 AM
2011-07-25
11:45 AM
Open an online tech support case with Netgear. Apparently the upgrade process was corrupted in some manner. When you get the case #, edit your first post and add the case # to the subject line.
Do you have a current and complete backup?
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-25
05:24 PM
2011-07-25
05:24 PM
@papabear
I don't have a backup cause the NAS is the last backup.
The great and strange news, the system is up now. I'm confused.
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-25
10:55 PM
2011-07-25
10:55 PM
The fact that it is back up is good news. The fact that you consider the the NAS as the backup is not. You have just had a close call, and I would advise you to take heed unless you really want to joint the "Lost Data" club.
Every ReadyNAS manual warns that the ReadyNAS should not be considered a backup device. RAID is a technique to combine multiple disks into a single volume and provide some redundancy so the volume can survive a disk failure. Once you then replace the failed disk, it should re-establish the array and continue. However, if you had a dual drive failure, or a failure in the unit, or catastrophic failure or theft of device, where would your data be?
Message 5 of 5
