× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NeatGear NV+ V2 not mounting /dev/c/c
BaGRoS
Hi
After command:
root@nas-JohnyB:~# mount -o ro /dev/c/c
mount: special device /dev/c/c does not exist
?! Why?
Any help?
root@nas-JohnyB:~# sudo fsck
fsck from util-linux-ng 2.17.2
e2fsck 1.41.14 (22-Dec-2010)
fsck.ext4: No such file or directory while trying to open /dev/c/c
Model: RND4000v2|ReadyNAS NV+ v2 Chassis only
Message 1 of 18
Guru
Re: NeatGear NV+ V2 not mounting /dev/c/c
Are you booting up normally?
Are you seeing issues when you run dashboard?
Is RAIDar telling you anything useful about the NAS health?  https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
Message 2 of 18
BaGRoS
I try reinstalled firmware but is some error, see attached picture.
Message 3 of 18
Guru
Maybe try rebooting.
It would also be useful to download the full log zip file, and see if there are clues in there on why the data volume isn't mounting.
Was there a power loss of some kind?  Loss of cached writes can result in an out of sync RAID array that won't mount.
Message 4 of 18
BaGRoS
I pull out Disc no 1 and:
Why Disk 1 is Dead if is pull out completely???
Message 5 of 18
Guru
Again, I suggest downloading the full log zip.  Look for health of all disks in the smart logs.  Also look in system.log and kernel.log for errors related to disks, RAID, and the file system.
Message 6 of 18
BaGRoS
Disk 1 is removed and lying on the table!
***** Disk SMART log from 2022/04/07 *****
***** Disk SMART log for channel 1 [sda] *****
smartctl 5.42 2011-10-20 r3458 [armv5tel-linux-2.6.31.8.nv+v2] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model:     WDC WD40EFRX-68WT0N0
Serial Number:    WD-WCC4E5LRSFA4
LU WWN Device Id: 5 0014ee 20bfea843
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ACS-2 (revision not indicated)
Local Time is:    Thu Apr  7 20:05:19 2022 WEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(54240) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 255) minutes.
Conveyance self-test routine
recommended polling time: 	 (   5) minutes.
SCT capabilities: 	       (0x703d)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   186   178   021    Pre-fail  Always       -       7691
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       61
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   064   064   000    Old_age   Always       -       26520
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       61
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       59
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       471
194 Temperature_Celsius     0x0022   132   109   000    Old_age   Always       -       20
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
***** Disk SMART log for channel 2 [sdb] *****
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WMC4N0F7XY7H
LU WWN Device Id: 5 0014ee 003ec7af5
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
ATA Version is:   8
Local Time is:    Thu Apr  7 20:05:25 2022 WEST
					was never started.
					been run.
data collection: 		(41460) seconds.
					command.
					power-saving mode.
  3 Spin_Up_Time            0x0027   179   177   021    Pre-fail  Always       -       6050
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       85
  9 Power_On_Hours          0x0032   049   049   000    Old_age   Always       -       37371
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       85
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       82
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       452
194 Temperature_Celsius     0x0022   130   106   000    Old_age   Always       -       20
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
***** Disk SMART log for channel 3 [sdc] *****
Serial Number:    WD-WCC4E2KTAFA1
LU WWN Device Id: 5 0014ee 2609af609
ATA Version is:   8
Local Time is:    Thu Apr  7 20:05:30 2022 WEST
					was never started.
					been run.
data collection: 		(50760) seconds.
					command.
					power-saving mode.
  3 Spin_Up_Time            0x0027   174   170   021    Pre-fail  Always       -       8300
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       78
  9 Power_On_Hours          0x0032   054   054   000    Old_age   Always       -       33760
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       78
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       76
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       450
194 Temperature_Celsius     0x0022   130   106   000    Old_age   Always       -       22
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
***** Disk SMART log for channel 4 [sdd] *****
Serial Number:    WD-WCC4E4VTXLUE
LU WWN Device Id: 5 0014ee 261485995
ATA Version is:   8
Local Time is:    Thu Apr  7 20:05:35 2022 WEST
					was never started.
					been run.
data collection: 		(51420) seconds.
					command.
					power-saving mode.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       26
  3 Spin_Up_Time            0x0027   178   175   021    Pre-fail  Always       -       8083
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       39
  9 Power_On_Hours          0x0032   065   064   000    Old_age   Always       -       25553
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       39
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       37
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1694
194 Temperature_Celsius     0x0022   130   108   000    Old_age   Always       -       22
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       3
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Message 7 of 18
Guru
I'm wondering why you removed the disk.
Message 8 of 18
BaGRoS
With this disk I have:
so I removed for test.
And 1.5 year I don't have acces to my files, today I removed disk for test, and booom, all data are available.
Have a look thise case: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Volume-scan-failed-to-run-properly/...
Message 9 of 18
Guru
Ok, so you have access to all your data now?
If so, it would be a good time to back it up. The volume should be showing a "degraded" status w/o the disk.
I suggest testing the disk in a Windows PC using WDC's lifeguard program.  Run both the extended non-destructive test, and the erase disk test.  If it passes both, you could try inserting it back (with the NAS running).  That would start a resync process.  If it fails, you should of course replace it.  Get either a WD Red Plus or a Seagate Ironwolf - don't replace it with the WD40EFAX, as that is SMR (which can misbehave in RAID arrays).
BTW, the disk appears to be just out of warranty.
Message 10 of 18
BaGRoS
8TB external HHD is on his way, tomorrow before 1pm Amazon should deliver.
How create backup, from Radiator backup menu? External drive NTFS or exFat? Best way.
Message 11 of 18
BaGRoS
Why Disk 1 is as Dead, if is removed?
Message 12 of 18
BaGRoS
WD40EFRX-68WT0N0 - looks like WD RED Nas Hard drive.
Which exactly model I should use? I'll replace all of them.
Message 13 of 18
Guru
It was a Red drive when you bought it.  In June 2020, WDC rebranded it as a Red Plus drive - https://www.anandtech.com/show/15878/western-digital-cleans-up-the-red-smr-nas-hdd-mess.  You can see that on the Red Plus data sheet here: https://documents.westerndigital.com/content/dam/doc-library/en_us/assets/public/western-digital/pro...
The current model would be a WD40EFZX.
If that's your plan, I suggest looking at fewer but larger drives.
Three WD60EFZX cost about the same as four WD40EFZX, and would give you the same volume size.  That would leave an open slot for later expansion.
Either way, do a fresh install with all disks in place after your backup.  Then restore the data from the backup.   That will be faster than upgrading the disks one-by-one.  Label the old disks by slot as you remove them - if something goes wrong, you can reinstall them, and start again.
You connect the drive to a NAS USB port and use ReadyNAS backup job(s) - see chapter 6 of the manual here: https://www.downloads.netgear.com/files/GDC/READYNAS%20ARM-PLATFORM%20(DUO%20V2,%20NV+%20V2)/RAIDiat...
If you do this, you should format the drive as NTFS - the NAS doesn't support exFAT.
The other option is to connect the drive to a PC, and then backup over the network.  Something like FreeFileSync would be a tool you can use (likely better than drag/drop).
Message 14 of 18
BaGRoS
More than 12h test...
Message 15 of 18
Guru
Yes.  The full erase takes the same amount of time (and I have seen some disks that pass one test, and fail the other).
Part of the puzzle is whether the problem is with the NAS SATA electronics or the disk.
If bay one has failed, then putting a new disk in there won't help.
Message 16 of 18
BaGRoS
I suspected this is a problem, because I don't have a disk in bay 1, but NAS still see this disk as DEAD...
I started looking for new NAS, but I don't know which one to choose. Neatgear has stopped producing new equipment. I check on Amazon and everything is not available.
After finished backup, I'll check connectors and use contact cleaner.
Message 17 of 18
Guru
FWIW, that happened to me once with my Pro-6, but the chassis was fine.
If the disk becomes non-responsive, then the linux drivers can set the sata interface down.  Then the disk status will remain dead.  I shut down the NAS and disconnected the mains power off for a while, then restarted it.  Then the interface came back up.
Of course if the SATA interface has failed, then it won't recognize a new disk in that slot.
But I don't think you should touch this until after you make your backup.  Right now you have access to your data, and playing around with the NAS risks losing that again.
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 3278 views
  • 0 kudos
  • 2 in conversation
Announcements
