× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NetGear ReadyNAs 4220 Snapshot
tarekj
Tutor
Hello, I have Ready NAS storage 4220, I made volume consists of 5 disks (5*4TB) with RAID 5 and I made ISCSI Lun with size (13.48 TB) , the free space is (1.05TB) after three snapshots , I received email from the storage that the volume usage is above 95 % and therefore i delete all snapshots manually to resolve that alarm. So, If I want to use data protection option (snapshot) , is there any space consideration for snapshot, and what is the space required for each snapshot for the previous lun (13.48TB) Thanks.
Model: ReadyNAS-4200|ReadyNAS 4200
Message 1 of 5
Accepted Solutions
Guru
Re: NetGear ReadyNAs 4220 Snapshot
When you first make a snapshot it uses no space.  Every time a block changes in the LUN, the snapshot space goes up by a block.  So the required snapshot space depends on the usage pattern.
With BTRFS it's good to maintain about 15% free space, and that's what you started with (with no snapshots).  So maybe add another 4 TB drive to the array?
Message 2 of 5
All Replies
Guru
Message 2 of 5
tarekj
Tutor
Is there any formula to collect the required space for snapshot depending on the LUN size ???
Message 3 of 5
FramerV
NETGEAR Employee Retired
Hi tarekj,
Based on the description of the issue that you have provided, I may need to check this with others who can probably assist you and get back to you as soon as possible.
Thanks for your cooperation!
Message 4 of 5
mdgm-ntgr
It depends entirely on what the changes are at the block level how much space snapshots will consume. It could be not a lot, or it could be quite a lot depending on how you use the LUN.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2121 views
  • 1 kudo
  • 4 in conversation
Announcements
