- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NetGear ReadyNas 2120 Upgrade Issue from 6.1.6 to 6.8.0
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I have a problem with my storage after trying to update it from 6.1.6 to 6.8.0. I simply lost access to the admin webpage and the NAS is not pingable anymore. I don't wanna do a factory reset because I don't wanna lose any data.
I don't know if this could be the best idea.
And this document is a little bit vague because t doesn't tell you if you have to user the same firmware that was before the update or a new firmware than the update you tried to apply. I just don't wanna make any mistake.
Can anyone try to help me?
Best regards
Rafael Luz
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Rafael_Luz wrote:
Which firmware should I use, as I don’t want to lose any data, I do prefer to make sure I am going to use the right one
I suggest following the release notes
"They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.9.x."
So try using 6.2.5 in the USB recovery. When the NAS comes back, then upgrade to 6.5.2, and then finally 6.9.3. I see no good reason to stop at 6.8.0.
Hopefully you have a backup (and simply want to avoid the inconvenience of rebuilding the NAS and restoring the data). RAID isn't enough to keep your data safe.
That said, this process shouldn't be destructive. If you want to be particularly safe, you could remove the disks (labeling them by slot), and insert a single blank disk. After a successful USB recovery, the system would do factory install to the blank disk. You'd then power down, restore the original disks to their original slots, and then boot up again. The system should then install 6.2.5 onto the disks.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NetGear ReadyNas 2120 Upgrade Issue from 6.1.6 to 6.8.0
I've read the warning before, and there was nothing related to not upgrade from 6.1.6 to 6.8.0. I've seen some that was showing the warnings so I didn't go to those upgrades..
- Mark as New
- Bookmark
- Subscribe
- Permalink
The warning has been on all Release Notes since 6.5.2, circa September 2016
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's done is done.
Yes, you'll need to use USB Boot Recovery to fix this.
Note that not all USB keys are compatible.
Your USB key should be formatted with a single FAT32 partition using the MBR partitioning scheme.
Let us know how you go with this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should I use the 6.1.6
Or the same I tried to update (6.8.0)?
After the restore, will I get the same config I had before? Because the network the storage is in, doesn’t have DHCP and the doc says if it doesn’t find any DHCP it gets de APIPA address which I find horrible instead of having an default IP
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It worked like a charm and I didn’t lose any data or configuration.
NetGear should work on those KBs better because some explanations are vague but thank Jesus it worked 🙂
Thanks for all your help man 🙂
God bless you
