- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Drive Upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
New Drive Upgrade
I have a 2 disk volume with 2x3 TB drives. I purchased 2 WD 6TB WD60EFAX drives. I removed one 3 TB and plugged in a new 6 TB. It shows that the systed is degraded and the new drive does not appear.
Did I miss a step ? Will it format the drive automatically and how ling will it take to appear ?
Paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Drive Upgrade
Also the drive 2 LED (associated with the new drive) is flashing
paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's possible that it is dead. Perhaps try replacing it with the other drive, and see if that behaves differently. If it does, then return the failed drive to the seller.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried each of 2 new drives. Same result with either one. The drives were sealed in packaging, and using a USB adapter my windows machine sees the drive and capacity.
Am I correct in assuming that no initialization or other prep should be required ?
BTW the firmware is 6.10.3 (current release).
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are using XRAID, that is true. But not if you are using FlexRAID.
But either way, you should see the drive on the volume tab.
FWIW, I just got two 2 WD80EFAX (both sealed, etc), and one looks DOA. So it does happen.
Try testing it in the Windows PC with WD's lifeguard software. Start with the quick test, and then run the extended test. Usually I also run the full write test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved. After some testing using a USB adapter, problems seemed to be present. Since both drives seemed to have a problem, I returned both (to Amazon) and purchesed replacements from another reliable computer part supplier I have used for years. A bit more money, but seemed woth it. Got the new drives today, plugged one in and it was immediately recognized and started to synch.
The firts set of drives were bought on Amazon. They were shipped by a 3rd party supplier (not clear on Amazon that it was not from their supply). They were shipped in the sealed plastic envelope, but two were placed in a USPS 10"x12" yellow envelope with only a thin layer of bubble part of the envelope. They had aparently banged atround quite a bit in shipping and both had the dessicant pack ripped open and pulverized dessicant had dusted the drives. I brushed and tried to clean them as much as possible. Not sure what was the cause, but apparently both were DOA.
I was worried that I had missed something on the install, but in the end the simple swap worked when the drive is working.
paul
