× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
NightHawk Ax2700 and I forgot my username. Is RESET my only option. Thanks all.
CVL
Initiate
Initiate
Message 1 of 4
Guru
Re: NightHawk Ax2700 and I forgot my username. Is RESET my only option. Thanks all.
IF you setup the password recovery option, you can try it.
https://kb.netgear.com/24220/How-do-I-recover-my-NETGEAR-admin-password-using-the-password-recovery-...
otherwise yes, you would need to.
(btw, you posted in the readynas forum about a nighthawk product, might get better help in the proper forum next time)
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
CVL
Initiate
Initiate
Hey, thanks very much for the quick reply even though I posted in the wrong space. Means a lot.  Thanks again
Message 3 of 4
Guru
Good luck!
If it works, might mark it solved so others aren't still trying to solve it 🙂
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 338 views
  • 1 kudo
  • 2 in conversation
Announcements
