Orbi WiFi 7 RBE973
Reply
No login on https://my.ip/admin on 4.2.21
jwarthman1
Re: No login on https://my.ip/admin on 4.2.21
What happens if, in RAIDar, you select the NAS and click on the "Configure" button? What URL do you see in your browser, and does the NAS present a login screen?
Enjoy,
Jim
Message 26 of 39
nasmk
THE link it makers is https://192.168.2.102/admin with no login THE browser said unable to connect
Message 27 of 39
jwarthman1
Ok, thanks.
I might've missed it if you already said, but what is the IP address of your Mac that you are using to connect to the NAS?
Enjoy,
Jim
Message 28 of 39
nasmk
Same Ip but ends with 107.
Message 29 of 39
mdgm-ntgr
NETGEAR Employee Retired
What add-ons do you have installed? Have you installed the add-on that enables SSH access?
Hopefully this issue could be resolved simply by re-installing an add-on or two over the top of itself.
Message 30 of 39
nasmk
I have installed the SSH PHP SQL Sabnzb
http://youtu.be/Ssij5h701R4 (in Dutch)
Hope it helps
Message 31 of 39
mdgm-ntgr
O.K.
Login via SSH and re-install PHP over the top of itself then attempt to restart Frontview. Are you familiar with doing these two things via SSH?
Which PHP add-on were you using? super-poussin's or the one by WhoCares?
Message 32 of 39
nasmk
PHP 1.4 and Pro-PHPmyadmin and no I am not that good with SSH haha maybe you can give the comment line so i can copy paste
Message 33 of 39
mdgm-ntgr
O.K.
First make sure a copy of the add-on is on the NAS. For simplicity let us assume you put them in the root of the "backup" share (you can put them wherever you like).
In the below replace PHP_ADDON.bin with the name of the bin file
# mkdir /tmp/PHP5123
# cd /tmp/PHP5123
# cp /backup/PHP*.bin ./
# tail -c `head -n 1 PHP_ADDON.bin | awk -Fsize= '{print $2}' | cut -d, -f1` PHP_ADDON.bin | tar -xv
# sh install.sh
# /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf -t && /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf -k graceful
Message 34 of 39
mdgm-ntgr
If the above doesn't fix the problem please post the output of
# tail /var/log/frontview/error.log
Message 35 of 39
nasmk
But how do i get in the terminal? tried ssh admin@192.168.2.102 but i can't give a password.
I did a reset OS reinstall maybe he lost the ssh
Message 36 of 39
nasmk
MacBook-van-marcel:~ mkomman$ ssh admin@192.168.2.102
admin@192.168.2.102's password:
Last login: Sun Jun 17 08:58:32 2012 from 192.168.2.107 on pts/0
Linux nasmk 2.6.37.6.RNx86_64.2.4 #1 SMP Mon May 21 16:00:40 PDT 2012 x86_64 GNU/Linux
Last login: Sun Jun 17 09:07:36 2012 from 192.168.2.107
Connection to 192.168.2.102 closed.
Message 37 of 39
mdgm-ntgr
The user for SSH is 'root' not 'admin'. The 'root' password is initially set to be the same as the 'admin' password.
Message 38 of 39
nasmk
mdgm My credits.......... works like a sunshine ......... (werkt al een zonnetje in t nederland)
It was the PHP who was a ..... PIEP.
Pfff up to the next step trying to work on the NAS with wordpress and a FTP page with is accessible for others with login..
But I will some one let program it to work haha ore else it goes bad again....
Thanks a LOT forum people
Till next time
Message 39 of 39
Top Contributors
Discussion stats
  • 38 replies
  • 2620 views
  • 0 kudos
  • 5 in conversation
Announcements
