- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Not Resyncing new drive - Volume not redundant - Drive dead
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
For anyone out there with the issue of their NAS not rebuilding RAID volume redundancy after inserting a new drive and Frontview still reporting the old drive as dead, I feel your pain!
I didn't manage to find any aticle on here that helped but I found this article on how to force the resync process through ssh and it worked like a charm for me.
http://www.brull.me/linux/2015/06/03/replacing-readynas2100-disks.html
All credit goes to Chris Brull
Hope it helps someone else
Thanks
Matt
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Not Resyncing new drive - Volume not redundant - Drive dead
Hi @ru55ell75
Welcome to the community!
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
Regards!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @ru55ell75
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Matt,
I experience the same problem with my Readynas Ultra 2. Inserted a new HDD in bay 2 but Frontview still showing the as dead. When I connect to the Nas through ssh and write the command: sgdisk -p /dev/sdc I receive the following output. The disk I see is the active i the X volume I suppose? Could you guide med how to proceed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I write the command df-h it says the volume is 4GB? Not showing in Qraidar!
- Mark as New
- Bookmark
- Subscribe
- Permalink
zose the 4GB volume is the root volume. The data volume is the 914GB volume mounted at /c
sdc is your USB disk from looking at
# df -h
What do you see if you do e.g.
# cat /proc/mdstat
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, mdgm you are absolutely correct about that. When I write the cat /proc/mdstat I get the output:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you see the disk you added if you do a
# cat /proc/partitions
Have you hooked the disk up to a PC and tested it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the disk is fine. If I write the command I get the output below which seems to be correct because I have 2 3.5 HDD disks which are 2TB and 1 Usb which is 2TB connected to the Nas:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you checked the health of sdb?
# smartctl --all /dev/sdb
You could try writing zeroes to the start of the disk
# dd if=/dev/zero bs=1M count=1000 of=/dev/sdb
then remove the new disk and try adding it again.
