Orbi WiFi 7 RBE973
Reply
Nylon screws for ReadyNAS Duo
feathers_mcbird
Hi there.
Like many others,I am unable to find a source for the Duo's low profile hard drive mounting screws.
Has anyone tried nylon countersunk screws with a shaved-down head? Perhaps this could work.. haven't tried it, myself, but these screws are plentiful and cheap on eBay.
Message 1 of 14
mdgm-ntgr
NETGEAR Employee Retired
Re: Nylon screws for ReadyNAS Duo
The screws are found taped to a drive tray or in the packaging the NAS came in in a zip-lock bag.
If you can't find the screws then give NetGear support (http://www.readynas.com/support) a call. They can send you replacement screws for a small fee.
Four screws are used with each drive tray but you can use 2 or 3 screws per tray as a temporary fix till your replacement screws arrive.
Message 2 of 14
mangrove
Apprentice
feathers.mcbird wrote:
Hi there.
You don't strictly HAVE to use the countersunk screws -- you can use flat-headed screws (probably not normal computer screws, though) if you are a little careful when inserting the tray.
Any computer shop worth its salt should have some countersunk screws, as they are used in most every tray used for all RAID systems. They might be larger though, the Readynas ones have quite small heads. But it doesn't matter.
Message 3 of 14
feathers_mcbird
Hi there.
I've picked up several screws, local and online: None are quite low-profile enough.
I found some 6-32 "undercut" countersunk screws that work in a Dell NAS tray, but not the ReadyNAS... even this teeny-weeny (fingers pinched really close together) head height is too much. The head on these screws has got to be nearly nothing.. this is certainly a specialty item.
I'll see if the NetGear folks can help me out.
Message 4 of 14
chirpa
Luminary
Contact Support, they have them available.
Message 5 of 14
feathers_mcbird
Another dead end.
I bought these two older ReadyNAS Duos on eBay, second hand (that's why I don't have the screws).
NetGear support won't sell me the screws without registering the product, which I can't do since they were already registered by the first owner(s).
*sigh*
Message 6 of 14
ReadySECURE
Apprentice
Could you send a proof of purchase, the serial number, and your mailing address to attachment@netgear.com. Put in the subject screws and readysecure1985. I will have someone watch for it and get this cleared up for you. The Proof of purchase can be a screen shot of the ebay purchase.
Message 7 of 14
mangrove
Apprentice
Another dead end.
*sigh*
That's patently absurd. Why won't they sell spares for their equipment? It's just silly.
I was under the impression that all desktop devices more or less share the same tray? I have had success with flat-headed screws, and these are of a type I have seen lots and lots of times. You can see them in action here (unrelated article):
http://www.magnuswedberg.com/index.php?doc=2_5_inch_disks_in_a_Netgear_Readynas
Image number four. This works perfectly in both slots, even if you CAN make them snag on something when inserting the tray if you really try.
Can you post an image of your setup? If possible, also check where the screws bump into something 🙂
Edit: readysecure1985, on the other hand, shows a good example of good support. 😉
Message 8 of 14
feathers_mcbird
Excellent post, Mangrove.
I'll delve into this a bit and post back.
Message 9 of 14
feathers_mcbird
readysecure1985,
I sent images of the serial number and proof of purchase, but the message came back as undeliverable. Is attachment@netgear.com the correct email address?
Thanks,
--b
Message 10 of 14
ReadySECURE
Apprentice
Sorry about that. I put in the wrong email address. It is attachment@netgear-support.com.
Message 11 of 14
feathers_mcbird
Re: Nylon screws for ReadyNAS Duo / *RESOLVED*
Well.
Major kudos for the excellent and fast support from readysecure1985 and the NetGear support group.
Thanks to the discussion in this thread, and the amazingly fast assistance from readysecure1985 I am now in possession of the proper screws for my ReadyNAS Duo units 😉
Certainly a testament to the quality of NetGear support.
--b
Message 12 of 14
ReadySECURE
Apprentice
Thanks for letting us know you got them. I am glad we were able to get that resolved for you.
Message 13 of 14
Indexmill
Hi,
Same issue with no drive screws for my second-hand Readynas DUO.
Email request set to netgear-support with reference to readysecure 1985.
I appreciate any assistance. Thank you. John.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2281 views
  • 0 kudos
  • 6 in conversation
Announcements
