× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT!
glem
Re: OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT!
Power off is picture button left to the NAS picture on system overview menu
Message 276 of 1,275
MACDaHac
Thanx, I was expecting it next to the log-out button :?
Message 277 of 1,275
chirpa
Luminary
Ya, UI/UX isn't designed by an actual UI person, but random developers. The ReadyDATA UI has the shutdown button where you expected it, up by the logout button.
And the Logout button is pointless, doesn't even try to kill the active session, just an alert box to close the browser heh.
Message 278 of 1,275
MACDaHac
Thank you, and just for the record, I was not bashing the UI and the effort of developers to make this happen, just did not see the button.
Message 279 of 1,275
Guru
On the whole I think it works well, there are a couple of things that are hard to find. Where to change the admin password (done under "profile") is one I ran across today.
Message 280 of 1,275
chirpa
Luminary
Ya, power options should be near Logout. Admin password should be under Accounts tab (like RAIDiator).
Message 281 of 1,275
Skywalker
NETGEAR Expert
pywong wrote:
I know that RAID-6 is dual redundancy but RAID-6 is not expandable compared to the dual redundancy in X-RAID2 on 4.2.22.
If it's possible to use dual redundancy in X-RAID2 on OS 6 that would be great.
Hint: Try clicking the X-RAID button after you have your RAID6.
Message 282 of 1,275
chirpa
Luminary
Welcome Skywalker to this long winding thread!
Message 283 of 1,275
mdgm-ntgr
NETGEAR Employee Retired
Does X-RAID2 dual-redundancy work like it does on 4.2.x (e.g. 6x2TB disks installed, replace four of the disks with 3TB disks and then the volume will expand)?
Message 284 of 1,275
chirpa
Luminary
24 hours since 6.0.5 showed up on the update server, still no announcement, release notes, or GPL package... #wtf
Message 285 of 1,275
bramete
Hi!!
please, if MACDaHac would like to explain how he did the fan control(i´m a newbie) as i´m running the same hardwear.
thx!!
Message 286 of 1,275
glem
Look at my previous post
http://www.readynas.com/forum/viewtopic.php?f=51&t=70133&start=255#p393886
sorry I cannot insert url in post, I don't know why... copy this link to your webbrowser
Message 287 of 1,275
MACDaHac
bramete wrote:
Hi!!
thx!!
OS6.0.5 I have updated by "check for updates" button in 6.0.4 UI.
Fan-control I have updated by following the steps as described by glem @ http://www.readynas.com/forum/viewtopic.php?f=51&t=70133&start=255#p393886
and then editing the fancontrol file manually (just to tweak it a bit).
BTW, glem thank you.
Message 288 of 1,275
F_L_
Tutor
So it seems that we now have a working solution for the fan issue, that's great!
Regarding the other problem (genie add-ons) the only solution is to use apt-get and then donate the amount to the developer?
I don´t mind paying for add-ons but I would prefer doing it from http://readynasxtras.com/ directly.
Message 289 of 1,275
mwlodarc
great solution with fancontrol.
And with 6.0.5 firmware readycloud work on legacy ULTRA 4
rgds
Message 290 of 1,275
Skywalker
NETGEAR Expert
Yes, it does. Actually, it should be a little better than 4.2.x, because it does it all online without a reboot.
Message 291 of 1,275
bramete
Thank you all!!will put my hands on it this week-end
Message 292 of 1,275
pywong
It would be nice to be able to do this from the start, instead of deleting the volume, creating a RAID6 volume, waiting for that to complete and then convert that to a X-RAID2 dual-redundancy volume. The old way made more sense. But I guess this will work for now.
I think I will give OS6 another chance this weekend too.
Message 293 of 1,275
Skywalker
NETGEAR Expert
You don't have to wait for the RAID sync to finish before using it. You should be able to delete your RAID 5, create a RAID 6, and turn X-RAID back on within about one minute.
Message 294 of 1,275
pywong
Last time I tried it the X-RAID was grayed out once I had a RAID6 volume.
Message 295 of 1,275
jtclark
Is there any way to convert to XRAID-2/RAID6 without losing the factory default shares and apps (PLEX for example)?
Going through a factory default is only giving me single redundancy on my 516 but I lose some of the defaults when I manually switch.
I've been playing on a Pro with OS6 and see the same thing.
Is there an easier way to get to dual redundancy?
Message 296 of 1,275
mdgm-ntgr
An OS Re-install or installing the firmware over the top of itself should bring back the pre-installed apps after you create a new volume.
Deleting the data volume would delete all the shares on it including the apps share and the other default shares. I don't think I've checked but some of these may automatically be recreated as empty shares after creating a new data volume.
Message 297 of 1,275
jtclark
Is 6.0.5 available for download yet?
Message 298 of 1,275
mdgm-ntgr
Good point. Do an OS Re-install following the instructions in the Hardware Manual for your 516.
Message 299 of 1,275
jtclark
Will do, thanks for the info.
I'm running 6 4TB WD Reds in the 516 and really want dual redundancy before I start migrating data.
Message 300 of 1,275
Top Contributors
Announcements
