× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT!
jtclark
Re: OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT!
I switched to XRAID-2/RAID6 and reinstalled the OS (before the volume was rebuilt).
The volume is rebuilding now.
It set the admin password back to the default but did not restore the factory shares.
I do have the factory apps.
I guess I'll recreate the factory shares and see how it goes.. at least I feel a little safer about the RAID settings.
BTW, I had tried backing up the configs before I started, but the backup process just kept spinning.
Sorry to hijack the thread, but I'm trying all these things on an old Pro too.
Message 301 of 1,275
maboehme
Hi there,
at first I'm enjoing the silence with my pro 6! Did it the glem-way. 😄 Thank you!!!! :worship:
From time to time I cannot login via ssh:
Sometimes on 192.168.1.16 (static) I get no respone at all.
Sometimes I can only access the nas vie the second interface. Any clues?
Also I have problems with samba, I guess: The Pro 6 (OS 6.05) often cannot be seen, neighter with android (es file browser) nor under Windows 7 (32/64). 😞 And if it shows up, I cannot access the shares (factory settings!), because (translated errormessage:) "\\Nas couldn't be accessed". The Windows7 assistance says there is no computer names "Nas" on the network also it showed up...
If the VirtualBox NASOS6.05 (many thanks )showes up all the shares can be accessed with no problems... strange
btw: no proplems with my Duo V1 at all.
Best regards,
Martin
Message 302 of 1,275
maboehme
btw:
:rofl:
unused : "Frei"
Kostenlos: free of charge
used: Belegt (in this context)
Daten: data
don't worry, be happy!
brgs,
Martin
Message 303 of 1,275
L_Mic
mwlodarc wrote:
great solution with fancontrol.
And with 6.0.5 firmware readycloud work on legacy ULTRA 4
rgds
Updating my Ultra to OS 6 worked straight away. Thanks to those who made this available.
However I could not get readycloud to work on my Ultra with OS 6.05. At the end of the registration proces it asks for the Backup button to be pressed.
But nothing happens when this button is pressed.
Is there a work around for this?
Also activating the Dropbox functionality in OS 6.05 did not work. The Dropbox webpage says "The request to link the app is invalid"
Message 304 of 1,275
pywong
I have the ReadyNAS Pro 6 and this is my values for /etc/fancontrol
INTERVAL=5
DEVPATH=hwmon0=device/platform/coretemp.0 hwmon1=devices/platform/w83627ehf.2576
DEVNAME=hwmon0=coretemp hwmon1=w83627dhg
FCTEMPS=hwmon1/device/pwm2=hwmon1/device/temp2_input hwmon1/device/pwm1=hwmon1/device/temp1_input
FCFANS=hwmon1/device/pwm2=hwmon1/device/fan2_input hwmon1/device/pwm1=hwmon1/device/fan1_input
MINTEMP=hwmon1/device/pwm2=20 hwmon1/device/pwm1=20
MAXTEMP=hwmon1/device/pwm2=60 hwmon1/device/pwm1=60
MINSTART=hwmon1/device/pwm2=45 hwmon1/device/pwm1=15
MINSTOP=hwmon1/device/pwm2=14 hwmon1/device/pwm1=10
MINPWM= hwmon1/device/pwm2=70 hwmon1/device/pwm1=15
MAXPWM= hwmon1/device/pwm2=150 hwmon1/device/pwm1=150
Correct me if I'm wrong but I think theses are the best values so far, I think a little more test is in order once the volume rebuild is complete.
Message 305 of 1,275
pywong
INTERVAL=5
Here's my updated fancontrol file
INTERVAL=5
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/w83627ehf.2576
FCTEMPS= hwmon1/device/pwm2=hwmon1/device/temp2_input hwmon1/device/pwm1=hwmon1/device/temp1_input
FCFANS= hwmon1/device/pwm2=hwmon1/device/fan2_input hwmon1/device/pwm1=hwmon1/device/fan1_input
MINTEMP= hwmon1/device/pwm2=20 hwmon1/device/pwm1=40
MAXTEMP= hwmon1/device/pwm2=60 hwmon1/device/pwm1=65
MINSTART= hwmon1/device/pwm2=45 hwmon1/device/pwm1=15
MINSTOP= hwmon1/device/pwm2=14 hwmon1/device/pwm1=10
MAXPWM= hwmon1/device/pwm2=240 hwmon1/device/pwm1=75
But I am still having problems it does not seem to be working, the fan speed does not change and it's quite loud.
Also the LCD does not seem to turn off.
So it looks like that the new OS6 does not work on the ReadyNAS Pro 6.
Any Ideas?
Thanks
Message 306 of 1,275
glem
You can try (to download the latest packages):
apt-get update && apt-get upgrade
You have to stop/start fancontrol daemon for changes in file /etc/fancontrol takes effect
...change values in file
/etc/init.d/fancontrol stop
/etc/init.d/fancontrol start
Message 307 of 1,275
mdgm-ntgr
NETGEAR Employee Retired
Is your volume still resyncing? The display won't turn off while the volume is resyncing.
Message 308 of 1,275
bramete
Slowly, slowly getting there. Maybe maboehme could share how he makes logitechmediaserver start automatically when the nas starts, as there is no icon, and i don´t manage with the console. Vielen Dank!!
Message 309 of 1,275
glem
May be you have a problem with your two ip addresses configuration on the same NAS in the same subnetwork... Why one static address and one DHCP? Normally, the MTU would be the same within a given network... strange issues are possible when you mix MTU within a subnetwork, and within a multi-NIC server too...
You have one hostname with two IP addresses in the same network... As you described before, Windows use hostname and doesn't like it.
You can try bonding the two NICs in "Adaptative Load Balancing" mode, you don't need any special switch configuration for this mode. You will have only one mac address and one IP address....and one MTU. Go to network menu to activate it.
Message 310 of 1,275
pywong
I did a apt-get update and upgrade. The unit has finished restriping.
I install fancontrol and did a reboot but it does not work right.
Message 311 of 1,275
glem
You must not define a very low temperature, otherwise fan run already loud to decrease temperature, and it cannot do this. For example, I think 20°C is too low for system temperature. MINTEMP parameter would be the optimal temp read by the sensor, id normal running temp.
This is the same thing for fan rpm : define MINSTART, MINSTOP, MINPWM as the same value, the optimal value correspond to the lowest realistic rpm value you want to have in normal running.
For example on Ultra6, minimal system temperature would be around 37°C, minimal CPU temp around 51°C, minimal system fan 900 rpm (may be higher on pro6).
Do you remember temp and rpm values with 4.2.xx ? they are the best ones.
Message 312 of 1,275
pywong
I got fancontrol working, Thanks for the tip.
Here's what I used:
INTERVAL=10
MINTEMP= hwmon1/device/pwm2=30 hwmon1/device/pwm1=55
MAXTEMP= hwmon1/device/pwm2=60 hwmon1/device/pwm1=60
MINSTART= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINSTOP= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINPWM= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MAXPWM= hwmon1/device/pwm2=200 hwmon1/device/pwm1=80
I'm still having problems with the LCD screen, how can I use lcdproc to make the LCD screen work?
Thanks
Message 313 of 1,275
chirpa
Luminary
demetris wrote:
I would install weezy somewhere and get them from that if you cant find them online.
Also put them here for others to use ;).
it87.ko (The fan sensor driver) 😉
coretemp.ko (the cpu sensor driver)
Or you can try these 😄
http://www.multiupload.nl/YE7X1LRF8M
Place them in example given:
/lib/modules/3.0.0-generic/kernel/drivers/hwmon/
Owned by root
example with scp utility
scp -r *.ko root@192.168.1.209:/lib/modules/3.0.70.RNx86_64.2.1/kernel/drivers/hwmon/
Link doesn't work anymore.
Message 314 of 1,275
BadButton
Owned by root
Linux noob here. Since the links for the Fancontrol drivers are dead. Ive been trying to find another copy of thoes drivers all over the internet, but sadly unable to find them. I however think i found their source code.
Coretemp--Here http://lxr.free-electrons.com/source/drivers/hwmon/coretemp.c?v=2.6.32
IT8721F/IT8758E --- Here http://khali.linux-fr.org/devel/misc/it87/
Question is how in the world do i get these files to compile/install? Ive tried make but i get an error stating "nothing to do here". Can this source code be compiled? Does anyone have a copy the readynas fan control drivers?
Untill thoes drivers are found im afraid this project is a dead end for me. 😞
Message 315 of 1,275
spiderman1
Guide
You can download the drivers at this URL:
http://www14.zippyshare.com/v/9728759/file.html
Message 316 of 1,275
BadButton
Thanks Spiderman!
Only issue is when i try to install the modules i get an error:
insmod: can't insert 'it87.ko': invalid module format same with coretemp
Message 317 of 1,275
demetris
They were from an ubuntu 12.04 OS. You guys have to find a matchable pair for Debian Wheezy.
Message 318 of 1,275
sventunus
Nope.
"Us guys" [ReadyNAS Ultra 6] don't need to install any modules, they're available in the kernel (I'm on an Ultra 6).
Check dmesg | grep coretemp it87, the modules are there.
What you need to do first is the following:
apt-get update && apt-get -y upgrade
apt-get install lm-sensors fancontrol
Then edit /etc/fancontrol via vi or nano or whatever to be as such:
INTERVAL=5
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/it87.2576
DEVNAME=hwmon0=coretemp hwmon1=it8721
FCTEMPS= hwmon1/device/pwm3=hwmon1/device/temp3_input
FCFANS= hwmon1/device/pwm3=hwmon1/device/fan3_input
MINTEMP= hwmon1/device/pwm3=51
MAXTEMP= hwmon1/device/pwm3=58
MINSTART= hwmon1/device/pwm3=40
MINSTOP= hwmon1/device/pwm3=40
MINPWM= hwmon1/device/pwm3=40
MAXPWM= hwmon1/device/pwm3=150
Then:
reboot
Then, create & chmod 755 a file called /bin/fan-monitor with the following contents:
#!/bin/bash
# log and send mail
function sendmail {
( echo "To:$email_address"
echo "From:$email_address"
echo "Subject:$host: temp-monitor: $1"
echo
echo "$2" ) | /usr/sbin/sendmail -t --read-envelope-from
echo $message >> $log
# files
lock="/tmp/.fan-monitor.lock" # lock file (needed?)
log="/var/log/fan-monitor.log" # log file
pwm_file="/sys/devices/platform/it87.2576/pwm3" # pwm file
# misc
dt=$(date +"%F %R") # get timestamp for logging
email_address="<your_email>"
host=`hostname`
# superuser check
if [[ $EUID -ne 0 ]]; then # check if process is running as superuser
echo $dt "This script must be run as root" >> $log # need su to write pwm file
exit 10
fi
# check for lock
[ -f "$lock" ] && exit # exit if another instance of this script
>$lock # is writing to pwm file (not nessesary?)
# get output from sensors into an array
OLDIFS="$IFS" # store current IFS
IFS=$'\n' # set IFS to newline
list=(`sensors`) # populate array from sensors output
IFS="$OLDIFS" # restore original IFS
# get values from array
cpu0=$(echo ${list[2]} | cut -f3 -d' ' | grep -P -o "[0-9.]+" | cut -f1 -d'.') # sensors cpu0 temperature
cpu1=$(echo ${list[3]} | cut -f3 -d' ' | grep -P -o "[0-9.]+" | cut -f1 -d'.') # sensors cpu1 temperature
fan=$(echo ${list[18]} | cut -f3 -d' ') # sensors fan speed
fan_min=$(echo ${list[18]} | cut -f7 -d' ') # sensors minimum fan speed
# read pwm values
pwm=$(cat $pwm_file) # pwm value from pwm file
pwm_min=40 # known minimum value
pwm_max=255 # known maximum value
# determine cpu with highest temperature
cpu=0
cpu_name=""
if ((cpu0 >= cpu1))
then
cpu=$cpu0
cpu_name="CPU0"
else
cpu=$cpu1
cpu_name="CPU1"
fi
# verify cpu test has returned a value
if ((cpu == 0)); then
message="$dt: CPU test failed, cpu0: $cpu0, cpu1: $cpu1"
sendmail "ERROR" "$message"
rm -f $lock # cleanup lock
exit 11 # exit error code
fi
# set the new pwm value for the fan speed.
if ((cpu < 40)); then
new_pwm=$pwm_min
elif ((cpu > 70)); then
new_pwm=$pwm_max
else
let new_pwm=($cpu-40)*10+40
fi
# check new pwm value
if ((new_pwm == 0)); then # no new pwm value = no need to do anything
echo "$dt: OK: $cpu_name: $cpu, pwm: $pwm" >> $log # log ok status if you want to keep track of what's
happening
rm -f $lock # cleanup locks
exit 0 # exit with ok status
fi
# don't resend emails if there is no change from previous run
if ((new_pwm != pwm)); then
# ok, now we have a new pwm value and need to set it
command_out=$( `echo $new_pwm > $pwm_file` 2>&1 ) # write new pwm value to pwm file, and catch any
output
command_rc=$? # get error codes
uptime=$(echo `uptime`) # get extra data for email
if (( command_rc == 0)); then
# no errors setting pwm.
message="$dt: pwm changed: $pwm -> $new_pwm, $cpu_name temp: $cpu, fan: $fan uptime: $uptime"
sendmail "Fan speed changed" "$message"
else
# oops, we got an error setting new pwm.
message="$dt: ERROR setting pwm: $pwm -> $new_pwm, $cpu_name temp: $cpu, fan: $fan uptime: $uptime -
ERRROR rc: $command_rc, stdout and stderr: $command_out"
fi
fi
#cleanup locks
rm -f $lock
Change <your_email> to your own email address.
And then edit crontab by typing
crontab -e
and adding the following line:
* * * * * /bin/fan-monitor > /dev/null
This will monitor the CPU temps for both Atom cores & adjust the fan speeds accordingly (for an Ultra 6) & send email when things get out of hand.
It doesn't make frontview display the correct fan speed though, need to figure out how to do that still.
I've finally come around to updating my RN Ultra 6's FW with 3 weeks delay. It's syncing the array right now, will play with it some more this weekend.
A BIG, ++MEGA++ thank you goes out to all the people who made it possible to run NG's latest FW on our legacy devices!!
You know... those devices that are perfectly capable from a HW POV, but were supposedly not eligible for running this firmware according to Netgear...
Too bad we don't get to post metal-smileys here, but you guys rock! \m/
If anyone might have some tips on how to make frontview report correct fan speeds for an Ultra 6, I'm all ears, thanks! 🙂
Message 319 of 1,275
chirpa
Luminary
Message 320 of 1,275
sventunus
chirpa wrote:
F this! 😄
/** CHECKING SMILEYS NOW...
NOT FINDING THEM **/
// realizing it's too late to realize that chirpa ref'd an external url & feeling dumbass 😕
// 1AM here to excuse myself 😉
Message 321 of 1,275
chirpa
Luminary
I borrowed that one from another board 😛
On the Dashboard native fan monitoring... Once we find out where it stores the config for that, we can update it for the correct values. On boot it would determine the SYSTYPE and change the config accordingly. We can then step in with boot script and change it again for these models. In the 4.x firmware, they used /ramfs/enclosure.cfg to drive where monitor_enclosure would read the values. In 6.0, it looks like readynasd keeps it in its SQLite db file.
Message 322 of 1,275
sventunus
Thanks for posting your thoughts chirpa!
Shouldn't be too hard to get the webif to reflect the correct sensors' outputs I'd guess, no. A matter of time - mine or someone else's.
Like I said: I'll be playing a bit with the new FW this weekend.
Sleepy time now though... Long days, clock will be ringing in 4 hrs again 😕
Message 323 of 1,275
glem
Hi,
you don't need to create a specific script to use contrab, all already exists when you install fancontrol. A shell called fancontrol is automaticaly created in /etc/init.d/ and you can use it as a daemon with stop/start commands. No need to reboot. It's easier 😄
Look at my previous post http://www.readynas.com/forum/viewtopic.php?f=51&t=70133&start=255#p393886
Message 324 of 1,275
glem
New version 6.0.6 is now available
uname -a
Linux nas-xx-xx-xx 3.0.74.RNx86_64.2.1 #1 SMP Wed May 15 00:37:43 PDT 2013 x86_64 GNU/Linux
Message 325 of 1,275
Top Contributors
Announcements
