Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT!
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-13
12:34 AM
2013-06-13
12:34 AM
Re: OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT!
For those who are asking themselves if they can switch from 4.2.x to 6.0.x (advantages/which features are already working etc..) you can have a look there :
http://www.smallnetbuilder.com/nas/nas- ... 6-reviewed
Message 426 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-13
01:10 AM
2013-06-13
01:10 AM
The "corrupt root" error mentioned in that article would also be obtained if you put used disks in older ReadyNAS models. From what Skywalker said above it sounds like ReadyNAS OS is even more cautious about wiping used disks than older OSes were. Which is not a bad change as many users have put a disk full of data in a ReadyNAS while it was running only to find the disk was wiped automatically.
I believe a change is coming in the next release to make it clear that if you boot up the NAS with used disks installed that these need to be wiped by doing a factory default.
As mentioned in that review some missing features from 4.2.x are coming.
Message 427 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-16
05:18 AM
2013-06-16
05:18 AM
Skywalker wrote: If you didn't clear your 4th disk before re-inserting it, it won't be destroyed automatically. You can go to the volumes page; switch to flex-raid mode (uncheck the X-RAID button); destroy any old volumes; then re-check the X-RAID button.
It worked but I now realised I only have 3.49TB available (using 4 2TB drives). So one disk does not seme to be used, 5.58GB should be available. Winder if this is a bug in os6 or related to the use of older hardware.
Message 428 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-16
05:32 AM
2013-06-16
05:32 AM
IF you download your logs, what does your mdstat.log look like?
Message 429 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-16
06:17 AM
2013-06-16
06:17 AM
Here it is.
df -h
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[1]
5845987968 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid1 sda2[0] sdd2[3] sdc2[2] sdb2[1]
523968 blocks super 1.2 [4/4] [UUUU]
md0 : active raid1 sda1[0] sdd1[3] sdc1[2] sdb1[1]
4192192 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Sun Jun 9 10:17:24 2013
Raid Level : raid1
Array Size : 4192192 (4.00 GiB 4.29 GB)
Used Dev Size : 4192192 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Sun Jun 16 15:12:39 2013
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Name : 37c1fce2:0 (local to host 37c1fce2)
UUID : 23f73996:00927161:cb8ba31d:11825571
Events : 592
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 17 1 active sync /dev/sdb1
2 8 33 2 active sync /dev/sdc1
3 8 49 3 active sync /dev/sdd1
/dev/md/1:
Version : 1.2
Raid Level : raid1
Array Size : 523968 (511.77 MiB 536.54 MB)
Used Dev Size : 523968 (511.77 MiB 536.54 MB)
Raid Devices : 4
Total Devices : 4
Update Time : Wed Jun 12 15:20:41 2013
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Name : 37c1fce2:1 (local to host 37c1fce2)
UUID : 286efef5:5068202e:4fea135a:d79f84d5
Events : 42
0 8 2 0 active sync /dev/sda2
1 8 18 1 active sync /dev/sdb2
2 8 34 2 active sync /dev/sdc2
3 8 50 3 active sync /dev/sdd2
/dev/md/data-0:
Version : 1.2
Raid Level : raid5
Array Size : 5845987968 (5575.17 GiB 5986.29 GB)
Used Dev Size : 1948662656 (1858.39 GiB 1995.43 GB)
Raid Devices : 4
Total Devices : 4
Update Time : Sun Jun 16 15:12:37 2013
State : active
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
Name : 37c1fce2:data-0 (local to host 37c1fce2)
UUID : ce2c0a06:16137e0d:6e85985e:b61d9a2c
Events : 9877
0 8 3 0 active sync /dev/sda3
1 8 19 1 active sync /dev/sdb3
2 8 35 2 active sync /dev/sdc3
3 8 51 3 active sync /dev/sdd3
df -h
root@nas:~# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 4.0G 1.8G 1.8G 51% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.8G 1.8G 51% /
tmpfs 494M 0 494M 0% /dev/shm
tmpfs 494M 7.1M 487M 2% /run
tmpfs 494M 0 494M 0% /sys/fs/cgroup
tmpfs 494M 0 494M 0% /media
/dev/md127 3.7T 2.4T 1.2T 68% /data
/dev/md127 3.7T 2.4T 1.2T 68% /home
/dev/md127 3.7T 2.4T 1.2T 68% /apps
/dev/md127 3.7T 2.4T 1.2T 68% /var/ftp/Applications
/dev/md127 3.7T 2.4T 1.2T 68% /var/ftp/Audiobooks
/dev/md127 3.7T 2.4T 1.2T 68% /var/ftp/Backup
/dev/md127 3.7T 2.4T 1.2T 68% /var/ftp/Diverse
/dev/md127 3.7T 2.4T 1.2T 68% /var/ftp/Documents
/dev/md127 3.7T 2.4T 1.2T 68% /var/ftp/Music
/dev/md127 3.7T 2.4T 1.2T 68% /var/ftp/Videos
/dev/md127 3.7T 2.4T 1.2T 68% /run/nfs4/data/Videos
Message 430 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-16
05:51 PM
2013-06-16
05:51 PM
Did you recheck the X-RAID option? If not, recheck it.
Also, have you tried rebooting the NAS?
Message 431 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-22
02:51 AM
2013-06-22
02:51 AM
Hi, l am a newbie and have the ReadyNAS Pioneer Edition running 4x. When you say backup your data please clarify. L have 9.5TB of storage on this NAS. What do l backup? The data on these disks? or the Firmware on the NAS?
Thanks.
Thanks.
Message 432 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-22
03:00 AM
2013-06-22
03:00 AM
Backup your data
Message 433 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-22
11:52 AM
2013-06-22
11:52 AM
mdgm wrote: Did you recheck the X-RAID option? If not, recheck it.
jupp i have done this. array seam to be the right size but not my volume or /data are not
Message 434 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-22
12:57 PM
2013-06-22
12:57 PM
demetris wrote: ok i found where it reads the temperatures.
/etc/sensors.d/rn2120.conf
Delete everything and add what you need from
/etc/sensors3.conf
Untested
Edit:
I edit it like this:
chip "coretemp-isa-0000"
label Core 0 "CPU Temp"
label Core 1 "Aux Temp"
chip "it8721-isa-0a10"
label fan3 "fan1"
label fan3 "CPU Fan"
Edit2: FAIL 😄
Take a look at the fan fix thread. I have made a fix to log the the temps.
Message 435 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-22
01:36 PM
2013-06-22
01:36 PM
mdgm wrote: Backup your data
The 9.5TB?
Message 436 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-22
02:34 PM
2013-06-22
02:34 PM
Absolutely, unless it is data that you can easily retrieve somewhere else.
Message 437 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-22
04:06 PM
2013-06-22
04:06 PM
vandermerwe wrote: Absolutely, unless it is data that you can easily retrieve somewhere else.
cheaper to buy the new nas! lol thx
Message 438 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-22
04:18 PM
2013-06-22
04:18 PM
A second Nas is an excellent backup solution. Yes backup can be expensive. Loss of data is potentially much more expensive. It's just like insurance.
Message 439 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-22
04:25 PM
2013-06-22
04:25 PM
vandermerwe wrote: A second Nas is an excellent backup solution. Yes backup can be expensive. Loss of data is potentially much more expensive. It's just like insurance.
Wonder if dropbox is still viable? Say you any good with remote readynas?
Message 440 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-23
02:58 AM
2013-06-23
02:58 AM
We are veering off topic.
If you want to know more about backup solutions, please search the forums and perhaps post questions on the backup forum.
Message 441 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-24
06:13 AM
2013-06-24
06:13 AM
I have a Pro 6 2nd gen with 6 1TB hitachi drives. last night, I updated to 6.0.8 and ran apt-get update and upgrade. I also have fan control running. Here is my fancontrol file
Here is the output from sensors.
Does this look right?
And thank you to everyone for posting their work. I would not have gotten this far without your posts on this forum!
# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=5
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/w83627ehf.2576
DEVNAME=hwmon0=coretemp hwmon1=w83627dhg
FCTEMPS= hwmon1/device/pwm2=hwmon1/device/temp2_input hwmon1/device/pwm1=hwmon1/device/temp1_input
FCFANS= hwmon1/device/pwm2=hwmon1/device/fan2_input hwmon1/device/pwm1=hwmon1/device/fan1_input
MINTEMP= hwmon1/device/pwm2=20 hwmon1/device/pwm1=40
MAXTEMP= hwmon1/device/pwm2=60 hwmon1/device/pwm1=65
MINSTART= hwmon1/device/pwm2=45 hwmon1/device/pwm1=24
MINSTOP= hwmon1/device/pwm2=70 hwmon1/device/pwm1=20
MINPWM= hwmon1/device/pwm2=70 hwmon1/device/pwm1=15
MAXPWM= hwmon1/device/pwm2=200 hwmon1/device/pwm1=150
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +35.0°C (high = +76.0°C, crit = +100.0°C)
Core 1: +35.0°C (high = +76.0°C, crit = +100.0°C)
w83627dhg-isa-0a10
Vcore: +1.10 V (min = +0.00 V, max = +1.74 V)
in1: +21.12 V (min = +15.26 V, max = +12.67 V) ALARM
AVCC: +3.23 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.23 V (min = +2.98 V, max = +3.63 V)
in4: +6.06 V (min = +1.93 V, max = +7.79 V)
in5: +1.55 V (min = +2.48 V, max = +2.40 V) ALARM
in6: +1.55 V (min = +2.48 V, max = +2.40 V) ALARM
3VSB: +3.23 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.20 V (min = +2.70 V, max = +3.63 V)
fan1: 1350 RPM (min = 1214 RPM, div = 😎
fan2: 1721 RPM (min = 1721 RPM, div = 😎
fan3: 0 RPM (min = 1171 RPM, div = 128) ALARM
fan4: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan5: 0 RPM (min = 878 RPM, div = 128) ALARM
temp1: +41.0°C (high = -3.0°C, hyst = +127.0°C) sensor = thermistor
temp2: +24.0°C (high = +80.0°C, hyst = +123.0°C) sensor = CPU diode
temp3: +3.5°C (high = +80.0°C, hyst = +123.0°C) sensor = thermistor
cpu0_vid: +0.000 V
Message 442 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-25
03:07 PM
2013-06-25
03:07 PM
Anyone happens to know the default transmissionbt v3.00 username and password?
I have tried all combinations i could find without success.
Admin/admin/root
password/password1/netgear1
So what is it? hmmm
Admin/admin/root
So what is it? hmmm
Message 443 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-25
08:24 PM
2013-06-25
08:24 PM
admin/admin
Message 444 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-25
11:58 PM
2013-06-25
11:58 PM
OS6 Version 6.0.6 to 6.0.8 Fail on Ultra 4
Hi Everybody,
Did I miss some advice/instructions on how to go about the OS6 Version 6.0.6 to 6.0.8 update on the ReadyNAS Ultra 4? I accepted the update from the GUI when I logged in this morning, and now I'm hung up at "Booting. . ." with the power light flashing at me. It's been like that for about 3 hours now and it doesn't look like it is going to recover on its own. I've already held in the power button once to force a reboot but the results are the same. Fortunately I do not have any critical data on the drives so I could do a factory reset if necessary, but before I try that I thought I'd ask the experts about the preferred method of recovering from this on OS6.
Have you any advice for me?
Thanks in advance!
Thanks in advance!
Message 445 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-26
12:07 AM
2013-06-26
12:07 AM
You could see if an OS Re-install fixes the problem.
If that doesn't it's possible your OS partition may be full or that something went wrong during the update.
Did you have any add-ons installed?
There is now a volume read-only boot option that has replaced the skip volume check boot option from earlier OSes. See http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
You may be able to recover your data using the volume read-only boot option.
Message 446 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-26
12:30 AM
2013-06-26
12:30 AM
mdgm wrote: You could see if an OS Re-install fixes the problem.
Dear mdgm,
Thanks for your reply!
1.) What would cause the OS Partition to become full? I have no idea what the status of the OS Partition was prior to attempting the update. I do know that the Data Partition was a tad less than 33%. . .
2.) NO. No Add-ons whatsoever. Matter of fact, I was planning to remove the Plex and Photo's Apps as soon as I figured out exactly how to do that 😄
3.) I will look into the "volume read-only boot option" you mentioned above
4.) Would you please post a link (if there is one) for the OS Re-install procedures appropriate for my particular situation?
Edit: Please disregard #4 above. I just performed the OS-Reinstall from the boot menu. Unfortunately, it did not help 😞
Any other suggestions? Is an OS reinstall from USB an option, or should I just go with the factory reset and cut my losses?
Thank you VERY much (in advance)!
Message 447 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-26
12:34 AM
2013-06-26
12:34 AM
1. It is a 4GB partition. It can be filled by an add-on not working properly or something like that.
2. O.K.
3. O.K.
4. http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
2. O.K.
3. O.K.
Message 448 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-26
12:56 AM
2013-06-26
12:56 AM
Please see my edited post above. . .
Any other suggestions? Is an OS reinstall from USB an option? If so, what USB Flash drive creation tool would be best to use (link please)?
Thanks again!
Thanks again!
Message 449 of 1,275
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-26
12:58 AM
2013-06-26
12:58 AM
USB Boot Recovery would probably be quite pointless.
Did you try the Volume Read-Only boot option?
Message 450 of 1,275
