× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Prevent CrashPlan service from starting automatically on reboot
InterClaw
When you reboot the NAS, CrashPlan is set to start its service, right? It will do so even if I manually stopped it with "./CrashPlanEngine stop" before rebooting, correct?
How do I prevent it from starting automatically on reboot? I don't want to uninstall it.
Model: ReadyNASRNDP6000|ReadyNAS Pro 6 Chassis only
Message 1 of 9
Accepted Solutions
Guru
Re: Prevent CrashPlan service from starting automatically on reboot
If disable isn't available, then I'd either try chmod or break the symlink.  You should be able to create a new symlink later on.
Message 5 of 9
All Replies
Guru
I think update-rc.d crashplan disable should work, using update-rc.d crashplan enable to reverse.
Alternatively you could try chmod -x /etc/init.d/crashplan, using chmod +x /etc/init.d/crashplan to reverse.
Message 2 of 9
InterClaw
Running your first suggestion, I got this result:
usage: update-rc.d [-n] [-f] <basename> remove
update-rc.d [-n] <basename> defaults [NN | sNN kNN]
update-rc.d [-n] <basename> start|stop NN runlvl [runlvl] [...] .
-n: not really
-f: force
 So I tried this:
update-rc.d crashplan remove
... and then it said this:
update-rc.d: /etc/init.d/crashplan exists during rc.d purge (use -f to force)
 Not sure if I should do this. What do you think Stephen? Maybe something should be changed in /etc/init.d/crashplan instead? It looks like this:
#!/bin/sh
# Linux Standard Base comments
### BEGIN INIT INFO
# Provides:          CrashPlanEngine
# Required-Start:    $local_fs $network $remote_fs
# Required-Stop:     $local_fs $network $remote_fs
# Should-Start:
# Should-Stop:
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: CrashPlan Engine
# Description:       CrashPlan backup service engine
### END INIT INFO
# Init script for CrashPlanEngine
# Defaults
SCRIPTNAME=/usr/local/crashplan/bin/CrashPlanEngine
case "$1" in
start)
        $SCRIPTNAME start
stop)
        $SCRIPTNAME stop
restart)
        $SCRIPTNAME restart
force-reload)
        $SCRIPTNAME force-reload
status)
        $SCRIPTNAME status
        echo "Usage: $0 <start|stop|restart|force-reload|status>" >&2
        exit 3
esac
exit 0
Message 3 of 9
InterClaw
Okay, now I'm learning things about runlevels... Seems like default runlevel for the NAS is 2? in /etc/rc2.d there's S01readynas_startup and S99crashplan. This is the only runlevel where crashplan is it seems.
Also seems like this update-rc.d disable is a new feature that might not be available in this semi-old Linux environment?
So removing is more permanent. Why is the force flag needed? Seems like S99crashplan is just a symlink to /etc/init.d/crashplan, which is the real startup script? So if I delete it from rc.d and want to restore it, can I just manually recreate the symlink in /etc/rc2.d, call it S99crashplan, pointing at /etc/init.d/crashplan, and it will work? Or is there more to it? Smiley Tongue
Message 4 of 9
Guru
Message 5 of 9
InterClaw
Perfect. I used the chmod approach, so the system doesn't have access to run that script on boot (I'm guessing is what I did Smiley Happy).
I verified with ./CrashPlanEngine status after a reboot and the service stayed off.
Message 6 of 9
mdgm-ntgr
NETGEAR Employee Retired
It's better where possible to use systemd service files rather rc.d scripts.
With systemd you have greater control over when the service starts, which services must start first etc.
Message 7 of 9
InterClaw
Either you completely missed the point of the topic, or this is some weak phishing attempt.
Message 8 of 9
mdgm-ntgr
Thanks for reporting this. peterstrong was a spammer and his posts have been removed.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 5424 views
  • 1 kudo
  • 3 in conversation
Announcements
