Orbi WiFi 7 RBE973
Reply
Pro not booting after downloading log files
Elvis2020
I tried downloading the logs files with frontview. After this my ReadyNas Pro 6 hung and was not responsive anymore. I choose to force shutdown and reboot the NAS. Now the NAS is displaying Booting.. but nothing happens. I think the log files has filling up the OS volume. I can Telnet and login to the ReadyNas in tech Mode but I can not find the log files. The only filesystem I have is the tmpfs.
# df
Filesystem 1K-blocks Used Available Use% Mounted on
tmpfs 10240 0 10240 0% /dev
I already tried the OS reinstall but that didn't help. I have firmware version 4.2.26
Any advice or suggestion?
Many thanks.
Message 1 of 7
Guru
Re: Pro not booting after downloading log files
I think you need to mount /dev/md0
Message 2 of 7
mdgm-ntgr
NETGEAR Employee Retired
After starting the RAID, StephenB.
Message 3 of 7
Elvis2020
Thanks StephenB and mdgm for your help.
I have started the RAID and mount /dev/md0. Where can I find the log files?
# df
/dev/md0 4176564 2014504 1952400 51% /mnt
With kind regards.
Message 4 of 7
mdgm-ntgr
What's the output of the following?:
# cat /proc/mdstat
# df -h
Message 5 of 7
Elvis2020
# cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md0 : active raid1 sda1[0] sdd1[3] sdc1[2] sdb1[1]
4193268 blocks super 1.2 [4/4] [UUUU]
md1 : active raid6 sda2[0] sdd2[3] sdc2[2] sdb2[1]
1048448 blocks super 1.2 level 6, 64k chunk, algorithm 2 [4/4] [UUUU]
md2 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[1]
2916122112 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
unused devices: <none>
# df -h
Filesystem Size Used Available Use% Mounted on
tmpfs 10.0M 0 10.0M 0% /dev
/dev/md0 4.0G 1.9G 1.9G 51% /mnt
Message 6 of 7
Elvis2020
Delete log files.
# df -h
/dev/md0 4.0G 398.7M 3.4G 10% /mnt
Restart the NAS => Working again.
Many thanks StephenB and mdgm. Your help was of great benefit. 😄
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3555 views
  • 0 kudos
  • 3 in conversation
Announcements
