Reply
Highlighted
Apprentice
Pro not releasing space
Hope this is posted in the right space, and apologies if this appears twice.  The first time i posted i simply couldn't find it in the forums, I could only view it under my own feed.
I'm having an issue with space not being freed up when I delete.  I do not have snapshots enabled, nor do I have the recycle bin turned on.  But it definately isn't freeing up.  I deleted close to 1/2 TB of data and no change in reported space.
Also, and I'm not 100% on this, but i can't help but feeling like I'm missing some files, there's a sizeable gap in a few years of home video's but it could just be that was when we started using our phones instead of the camcorder.
As part of the troubleshooting process, I ssh'd into the box, and got what i think is a disturbing directory structure (note the ? and }'s ).  Any thoughts on the wierd labels below?
Spacedock:/# ls -ls
total 100
4 -rw-r--r-- 1 root root 245 2019-01-28 12:46 ?} ?
4 -rw-r--r-- 1 root admin 37 2012-06-26 23:27 ?? ??
4 -rw-r--r-- 1 root root 37 2015-12-08 16:01 ?} ??
4 -rw-r--r-- 1 root root 37 2015-12-01 16:01 ?? ?
0 lrwxrwxrwx 1 root root 9 2010-12-19 19:42 backup -> /c/backup
4 drwxrwxr-x 2 1008 1008 4096 2015-08-23 06:43 bin
4 drwxrwxrwx 10 root root 4096 2015-09-16 22:50 c
0 drwxr-xr-x 18 root root 4700 2019-03-19 16:01 dev
4 drwxrwxr-x 67 1008 1008 4096 2019-03-19 16:00 etc
4 drwxr-xr-x 6 admin admin 4096 2009-10-02 19:15 frontview
4 drwxr-xr-x 3 root root 4096 2008-03-11 20:56 home
4 drwxr-xr-x 2 root root 4096 2007-09-07 13:53 initrd
4 drwxr-xr-x 14 root root 4096 2015-09-16 22:13 lib
4 drwxr-xr-x 2 root root 4096 2015-09-16 22:13 lib64
4 -rw-r--r-- 1 root root 37 2013-08-08 18:31 ?? ??} ??~ ??} ?.log?
16 drwx------ 2 root root 16384 2010-12-19 19:37 lost+found
0 lrwxrwxrwx 1 root root 8 2010-12-19 19:42 media -> /c/media
0 lrwxrwxrwx 1 root root 15 2011-01-09 13:11 MediaArchive -> /c/MediaArchive
4 drwxr-xr-x 2 root root 4096 2006-10-28 10:06 mnt
4 drwxr-xr-x 6 root root 4096 2011-03-09 13:55 opt
0 dr-xr-xr-x 112 root root 0 2019-03-19 16:00 proc
0 drwxrwxrwt 2 root root 0 2019-03-19 20:25 ramfs
4 drwxr-xr-x 3 root root 4096 2015-09-22 22:24 root
4 drwxr-xr-x 2 root root 4096 2015-09-16 22:13 sbin
0 drwxr-xr-x 12 root root 0 2019-03-19 16:00 sys
4 drwxrwxrwt 3 1008 1008 4096 2019-03-19 16:01 tmp
0 drwxrwxrwt 2 root root 40 2019-03-19 16:00 USB
4 drwxr-xr-x 10 root root 4096 2011-01-13 23:59 usr
4 drwxr-xr-x 16 root root 4096 2015-09-16 22:13 var
4 -rw-r--r-- 1 root admin 37 2012-06-26 23:27 ?? ??? ??? ?І ?? ?)
0 -rw-r--r-- 1 root root 0 2019-01-28 12:46 Ї ?
NAS:: NV+ :: Pro Business Edition, OS4.2.27, (4) ST2000DL003-9VT1666, 2x2Gb Kingston HyperX KHX6400D2K2/4G, E2160 :: 4200
NAS Models: NV+ ; Pro Business Edition, OS4.2.27, (4) ST2000DL003-9VT1666, 2x2Gb Kingston HyperX KHX6400D2K2/4G, E2160 CPU ; 4200
Model: ReadyNAS RNDP600E|ReadyNAS Pro Pioneeer Chassis only
Message 1 of 2
Highlighted
Guru
Re: Pro not releasing space
Did you log into the NAS as root?
One option is to back up the NAS, and do a factory default.  Then set up the NAS again, and restore the data from the backup.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 243 views
  • 0 kudos
  • 2 in conversation
Announcements
