× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Problem setting up my Duo v2
doug96
Hi there,
I have some issues with my Duo v2 NAS. Firstly, it was a chassis only when I got it as a present, and of course I bought 2x2tb HDD and installed it. When first booted up and setted up properly, I clicked on to use the disks as a JBOD (no RAID), but it automatically put it to RAID1 (redundant) 2tb. I have made 2 factory default resets yesterday and tried it again, but it keeps me putting into RAID1 mode, even when I choose RAID0. It's kinda annoying. How can I use it in JBOD mode?
Thanks
Model: RND2000v2 (ReadyNAS Duo v2)|READYNAS DUO v2 (DISKLESS)|EOL
Message 1 of 4
Accepted Solutions
Guru
Re: Problem setting up my Duo v2
@doug96 wrote:
Hot insert means, that should I install the second drive while it is running?
Yes.
Message 4 of 4
All Replies
Guru
Can you confirm that is it actually a v2?  The labels can be confusing, and many v1 owners mistakenly think they have a v2.
A v1
  • says "ReadyNAS Duo" on the front chassis
  • runs 4.1.x firmware
  • might say v2 on other labels
a v2
  • says "Readynas Duo v2" in the front chassis.
  • runs 5.3.x firmware.
Do a factory reset with only a single disk in place, and select RAID0.
After initial setup, hot-insert the second disk, and then create a second RAID-0 volume from the admin web ui.
Message 2 of 4
doug96
Yes, I confirm it is a v2 model (Front panel label, model numberplate on back, and also the ReadyNAS HW info confirms it). It runs the latest software (Raidiator 5.3.13)
Thanks for the help!
Message 3 of 4
Guru
Yes.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 918 views
  • 0 kudos
  • 2 in conversation
Announcements
