× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Quick question about ReadyNAS 516
nudist
Can I operate the unit with only two HDD in RAID 1/2 (mirrored). If I put in two smaller HDDs say 1 Tb, how do I scale up the capacity in the future. Can I stay with two HDD or do I need to insert additional drives? Can I switch from RAID 1 to RAID 5 at that point?
Message 1 of 3
Guru
Re: Quick question about ReadyNAS 516
If you use the default XRAID you can gain capacity either by adding disks or replacing 2 disks with larger ones. Each disk you add has to be at least as large as your biggest installed disk. The expansion is done automatically.
Flexraid also lets you expand, but you end up with multiple volumes. For most folks XRAID is better.
Message 2 of 3
nudist
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1108 views
  • 0 kudos
  • 2 in conversation
Announcements
