× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
RAID 1 question
jesusglezalv
RAID 1 question
Hi,
I have a RN102 with two disc on RAID 1 mode. In case the RN102 got damaged, is it possible to just install one of the discs on a computer to recover the data? Or should I buy a new NetGear storage product to access the data on the discs.
Thanks in advance!!
Message 1 of 4
Guru
Re: RAID 1 question
It is possible to mount the disks using a new linux boot CD with btrfs installed.
If you get a second RN102, you can also use it to back up the first RN102, which is better than just putting it on the shelf and hoping it still works when the first RN102 eventually fails.
Message 2 of 4
jesusglezalv
Re: RAID 1 question
Thanks for your quick answer. Is the same approach also valid for x-raid2 volumes?
Message 3 of 4
Guru
Re: RAID 1 question
XRAID2 with two disks is RAID 1 as far as the disk format is concerned. So yes.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1430 views
  • 0 kudos
  • 2 in conversation
Announcements
