× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RAID1 question
kakemann81
RAID1 question
Hi,
I just got my hands on the Ultra 4, but I have a question.
I've put my Nas into Raid1 mode with 2 WD 2TB disks.
This means that the disks are mirrored, right?
So how can I check both disks to see that the contents is the same on both disks?
I've copied some files over to the network drive for the NAS (in the media folder).
When I enter the NAS network drive, I can only find two folders: media, and backup.
So I'm not sure which disk I'm actually looking at.
Any advice is appreciated 🙂
Message 1 of 6
HERBIEO
Re: RAID1 question
When it's mirrored the data is identical on both disks you do not need to check it, 2 disks in raid 1 show as 1 volume.
Message 2 of 6
Guru
Re: RAID1 question
The mirroring is invisible to you - the NAS is writing to both drives, and only shows you one volume. If it showed you both, you could possibly destroy the mirror by modifying one and not the other.
Under "Volume maintenance" there is a "disk scrub" function which should compare the drives for you. (At least, that is available with xraid2, I think it is there with raid 1).
Message 3 of 6
kakemann81
Re: RAID1 question
Ok I get it! Thanks 🙂
Yes the scrub function seems to be available with raid1 mode as well
Message 4 of 6
TeknoJnky
Hero
Re: RAID1 question
as long as the volume status is 'redundant' then the disks are in sync
Message 5 of 6
Guru
Re: RAID1 question
Yes. And the disk scrub validates that.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2933 views
  • 0 kudos
  • 4 in conversation
Announcements
