× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RAID5 Expansion
Data_Dan
RAID5 Expansion
I am currently in the process of expanding my RAID5 volume from 4 x 3 TB drives to 4 x 6TB drives. The 3rd drive has been added but I have not seen it go ONLINE in the logs yet but it displays as ONLINE on the System page. The volume is still syncing. Is it too soon to upgrade the 4th drive or do I have to wait for the process to finish? I am hoping it will remain a RAID5 volume and not change to a RAID6 volume.
Model: RNDP4000|ReadyNAS Pro 4 Chassis only
Message 1 of 9
Accepted Solutions
Guru
Re: RAID5 Expansion
Wait for resyncing to complete.  If you remove a drive too early you will lose your data.
You now have two RAID groups on the 6 TB disks (the original 4x3 TB group, and a new 2 TB group).  Both need to sync.
That never happens with vertical expansion.  And the threshold for horizontal expansion is higher than 4 drives.
Message 3 of 9
All Replies
Data_Dan
Re: RAID5 Expansion
Here is the System page showing the drive is ONLINE.
Message 2 of 9
Guru
Re: RAID5 Expansion
Message 3 of 9
Data_Dan
Re: RAID5 Expansion
Thanks!
Message 4 of 9
Data_Dan
Re: RAID5 Expansion
I added the 4th drive this morning after the volume had re-synced and now the volume is degraded and is prompting to remove inactive volume. If I click on the 4th drive the format option appears. Do I have to format the 4th drive to add it to the 1st RAID group?
Message 5 of 9
Guru
Re: RAID5 Expansion
I'm assuming that the main volume is ok (and you still have access to your files).  If that's not the case, let me know.
The NAS won't automatically add a formatted disk to a data volume - that helps prevent inadvertent data loss.  So you do need to click on the fourth drive on the volume tab, and format it there.
Message 6 of 9
Data_Dan
Re: RAID5 Expansion
Yes files are OK. I put the original drive back in so now I have wait for it to sync. Once that's done I will try the other drive again. The "new" drive is from another NAS. I had performed a quick erase using WD Lifeguard. I am now in the process of doing a full erase on it. I will report back tomorrow
Thanks.
Message 7 of 9
Guru
Re: RAID5 Expansion
Hmm... That should have been enough to remove the partitions (zeroing the first and last million sectors).
Hopefully the full erase will take care of it.
Message 8 of 9
Data_Dan
Re: RAID5 Expansion
I put the erased drive in this morning. It is now re-syncing. I guess it wasn't wiped clean enough the first time
Thanks!.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1380 views
  • 1 kudo
  • 2 in conversation
Announcements
