× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
READYNAS DUO V1 RND2120 Bricked (update firmware fail)
Paul80910
Follower
Hello,
i have a READYNAS DUO V1 RND2120-100ISS bricked, in the time of the firmware update the power was turn off, now only the fan is working, and no lights...
Can i be recoverd with a UART cable, to write the firmware directly to cip?
Message 1 of 2
Guru
Re: READYNAS DUO V1 RND2120 Bricked (update firmware fail)
I don't think so.  Did you try powering up the system diskless, and check the status with RAIDar?  https://kb.netgear.com/20684/ReadyNAS-Downloads
It's an old NAS, and much slower (and more limited) than newer models.  Personally I don't think it's worth a lot of effort to bring it back to life - instead you should probably just replace it.  Do you have data on it that you need to extract?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 418 views
  • 0 kudos
  • 2 in conversation
Announcements
