× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN 10400
prof290546
RN 10400
Hi,
how can i connect my RN 10400 with the app ExpanDrive? When I place admin and the password, ExpanDRive says "invalid credentials. Any help?
Thank you
Message 1 of 16
Sandshark
Sensei
Re: RN 10400
Mac or Windows?  What protocol?  While on the same LAN, or remotely?
Message 2 of 16
prof290546
Re: RN 10400
I use MAC Big Sur, FTP: Same LAN. Thank you.
Message 3 of 16
Guru
Re: RN 10400
Do you have FTP enabled on the NAS share?
Message 4 of 16
prof290546
Re: RN 10400
Yes it is.
Message 5 of 16
prof290546
Re: RN 10400
See foto please.
Message 6 of 16
Guru
Re: RN 10400
Can you try accessing the share using different software?  I suggest FileZilla.
Message 7 of 16
prof290546
Re: RN 10400
Even with Filezilla I can not connect. User and password are correct set, but see foto please.
Message 8 of 16
Guru
Re: RN 10400
And this same password works when you access https:\\198.168.1.61\admin from your browser?
Message 9 of 16
prof290546
Re: RN 10400
Yes. Frustrating.
Message 10 of 16
prof290546
Re: RN 10400
What I see: Filezilla left the port open. Should I name a port number?
Message 11 of 16
Sandshark
Sensei
Re: RN 10400
Just verifying you are using basic FTP or FTPS, which the ReadyNAS supports, not SFTP, which it does not.  And if using FTPS, that the appropriate checkbox is selected on the NAS under FTP.
Have you tried using SMB, just as a test if nothing else?
Message 12 of 16
prof290546
Re: RN 10400
My Reday NAS has only FTP no FTPS. As I know, SMB is only for Windows?
Message 13 of 16
Sandshark
Sensei
Re: RN 10400
FTPS is a checkbox available when you enable FTP.  While SMB is a Windows protocol, it is supported by the ReadyNAS and your screen print shows it is enabled.  AFAIK, it is also a selectable as the connection type in ExpanDRive.  Of course, current Mac OS's also support SMB, so I'm not entirely sure why you are using ExpanDRive.
Message 14 of 16
Guru
Re: RN 10400
SMB certainly works with MacOS.  FTP is enabled (at least on the backup share).
FTPS is enabled as optional by default - so that's not the problem.  Also, FileZilla is giving a bad password error - if @prof290546  were trying to use SFTP, you'd get a different result.
If you want to pursue using FTP, then I suggest either changing the admin password on the NAS, or creating a new account (with a different password) and try that.  Chose a password without special characters as a test.
Message 15 of 16
Sandshark
Sensei
Re: RN 10400
One thought:  Is the admin password on your NAS still the default?  There are some things that are intentionoally disabled for the admin user when it is, and maybe FTP is one of them.
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 3219 views
  • 0 kudos
  • 3 in conversation
Announcements
