× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN102 bricked
brianjmc1
Tutor
RN102 bricked
Was working fine, lost power now all I get is a blinking power light. No Gui or SSH. I can telnet to it. I have tried factory restore, reload OS through USB, nothing seems to be working. Just wondering if its dead or not? Drives had NO data on them..
Thanks for any help!
Model: RN10200|ReadyNAS 100 Series 2- Bay (Diskless)
Message 1 of 10
Accepted Solutions
brianjmc1
Tutor
Re: RN102 bricked
Previously formatted disk(s) detected (Dirty Disks)
Message 8 of 10
All Replies
mdgm-ntgr
NETGEAR Employee Retired
Re: RN102 bricked
What do you see in RAIDar?
Being able to telnet in would suggest that you've run into an error during the early stages of the boot process.
Message 2 of 10
brianjmc1
Tutor
Re: RN102 bricked
It shows everything, Model, name, serial, status, firmware(6.4.0), IP address, and mac address..
Thank you for the help!
Message 3 of 10
mdgm-ntgr
Re: RN102 bricked
What's the status?
Message 4 of 10
brianjmc1
Tutor
Re: RN102 bricked
"No disks detected" I pulled the disks, I have tried with them in too...
Message 5 of 10
mdgm-ntgr
Re: RN102 bricked
Do you get the same error with the disks installed?
If so, that would suggest either your disks are bad or there's a hardware issue with the chassis or external PSU.
Message 6 of 10
brianjmc1
Tutor
Re: RN102 bricked
I will power down, power back up, then report back....
Message 7 of 10
brianjmc1
Tutor
Re: RN102 bricked
Message 8 of 10
brianjmc1
Tutor
Re: RN102 bricked
MDGM got me going again. Once I formatted the drives, the GUI came back....
Thanks for all the help!!!
Message 9 of 10
mdgm-ntgr
Re: RN102 bricked
As you found after you clicked on the format button in RAIDar and confirm your choice the NAS wiped the disks and it has come up fine.
It's likely when the power failed the 4GB OS partition on the disks became out of sync. Anyway since you've wiped the disks there's no way to check now.
The OS is installed onto the disks.
You can now mark a post containing the solution to your problem as the solution.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3881 views
  • 0 kudos
  • 2 in conversation
Announcements
