- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN102 : can't access admin page after upgrade to 6.10.0
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi everybody,
I upgraded my ReadyNAS RN102 from 6.9.5 to 6.10.0, and now I can no longer access the ReadyNAS admin page. Everything seems to work otherwise: I normally access the NAS files via SMB, but also with RAIDar and even by ssh. The status of the NAS with RAIDar is: "Management service is offline".
I did an OS reintall via boot menu, but that didn't change anything. Does anyone know of a way to recover access to the admin page without having to restore the factory settings and thus overwrite all the data ?
Thanks in advance !
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN102 : can't access admin page after upgrade to 6.10.0
If you want to try a manual reinstall of 6.10 (from the linux command line), then the commands would be
# cd /root # wget http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNASOS-6.10.0-arm.zip # unzip ReadyNASOS-6.10.0-arm.zip # echo /root/ReadyNASOS-6.10.0-arm.img > /etc/.flash_update # reboot
Make sure you log in as root (not admin)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello StephenB,
I will try. Thanks !
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi StephenB,
I did what you suggest. But unfortunately the problem is not solved. Still "Management service is offline".
Do you think I can try something else ?
Thanks !
- Mark as New
- Bookmark
- Subscribe
- Permalink
Were you running any apps? If so which ones?
Also, do you have a backup of the data?
- Mark as New
- Bookmark
- Subscribe
- Permalink
A priori no apps running. But the following errors in the RAIDar diagnostics :
- 2019-05-04 12:20:59: Malformed json file.
- 2019-05-04 12:20:59: rndb_amazon_drive_import() ==> 5 (2ms)
- 2019-05-04 12:20:59: rndb_import() ==> 5 (1715ms)
- 2019-05-04 12:20:59: Error rndb_import() ==> rc=5
- 2019-05-04 12:20:59: dba import failed
- 2019-05-04 12:20:58: DB (queue) schema version: new ==> 0
- 2019-05-04 12:20:57: DB (main) schema version: 24 ==> 24
- 2019-05-04 12:20:56: Malformed json file.
- 2019-05-04 12:20:56: rndb_amazon_drive_import() ==> 5 (2ms)
- 2019-05-04 12:20:56: rndb_import() ==> 5 (1721ms)
- 2019-05-04 12:20:56: Error rndb_import() ==> rc=5
- 2019-05-04 12:20:56: dba import failed
- 2019-05-04 12:20:56: Failed to start ReadyNAS System Daemon.
- 2019-05-04 12:20:55: DB (queue) schema version: new ==> 0
- 2019-05-04 12:20:54: DB (main) schema version: 24 ==> 24
- and so on...
I have a backup copy, but I was hoping it was possible to repair without full restoration... Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK StephenB. I will wait a little bit. Thank you so much
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some more info from my NAS...
- Power button and LED = Blinking
- Disk LEDs (1, 2) = On
- Disk activity LED = On
- Rear panel Ethernet port LEDs = Green blinking, amber off
Seems to me the system will not boot correctly, so is there something I can do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What status is RAIDar giving you? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try powering down the NAS, and then remove the disks (labeling by slot).
Then turn on the NAS, and see if RAIDar can find it (reporting a "no disks" status)
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAIDar still can't find my NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible that internet security software is blocking it? Perhaps try disabling any AV or Internet security software on the PC
Can you ping the IP address? (whatever you are seeing in the router).
- Mark as New
- Bookmark
- Subscribe
- Permalink
All my machines is running Linux with no AV/Internet security and everything have been working alright for the last three years until the last firmware upgrade, so that's where something went wrong.
Ping seems ok.
64 bytes from 192.168.1.4: icmp_seq=1 ttl=64 time=0.274 ms
- Mark as New
- Bookmark
- Subscribe
- Permalink
If ping works, then perhaps try to boot the NAS into tech support mode (with disks installed). You can confirm that it works by trying to connect to the NAS using telnet.
See pages 20-23 in the hardware manual for instructions on the boot menu: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! I will try that asap.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @eichen,
I checked the readynasd.log and saw these messages:
May 10 22:39:09 CORNEILLE readynasd[26170]: Error rndb_import() ==> rc=5
May 10 22:39:09 CORNEILLE readynasd[26170]: dba import failed
May 10 22:39:10 CORNEILLE readynasd[26248]: readynasd log started
May 10 22:39:10 CORNEILLE readynasd[26248]: readynasd started. (restarted=0)
It looks like the database file is corrupt. Please enable the remote access so we can further check what caused it. You may enable it by using the URL: https://ReadyNAS_IP_address/start_svc=remote-access.service. You should see this on the page:
After enabling it, you can get the 5-digit code from RAIDar then PM the code to me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. We will check the NAS and will provide you feedback asap. Just leave the NAS powered ON.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue, after installing 6.10.0 not able to open the Admin Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi amarajmera,
Welcome to the Community!
It will be best for you to create a new thread about the issue on your NAS. Although you are experiencing the same symptoms, the root cause may be different.
Regarding the issue on your NAS, you may download the system logs then provide it to us. We will check the cause of the issue. You may upload it to a file-sharing site then send to me the download link via PM (private message).
