× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN102 cannot upgrade from 6.2.2. to 6.2.3 #25074886
volfra
Hi everyone,
I have two identical RN102 units. The first equipped with 2x320Gb WD HDD, the second with 2x3Tb WD RED HDD. With the new 6.2.3 upgrade the first unit has discovered the upgrade and has installed properly. The second unit doesn't see the upgrade available in Internet. So I downloaded manually the firmware: nothing to do. The power on process shows me ever the 6.2.2 firmware. Can you help me? I cannot understand the meaning of that issue. Thanks. F
Message 1 of 4
RX
Luminary
Luminary
Re: RN102 cannot upgrade from 6.2.2. to 6.2.3
For automatic detection of new firmware, have you check the DNS of your 2nd RN102? You may set 8.8.8.8 and 8.8.4.4 as DNS servers.
Have you tried to manually upload again firmware v6.2.3 to your 2nd RN102?
As reference guide on how to manually update the firmware, check this article: http://kb.netgear.com/app/answers/detai ... -system%3F
Message 2 of 4
Nhellie
Virtuoso
System>Settings>Update Manual install FW. does it let you load 6.2.3?
Message 3 of 4
mdgm-ntgr
NETGEAR Employee Retired
Re: RN102 cannot upgrade from 6.2.2. to 6.2.3 #25074886
Turns out the RAM (memory) in this unit has failed.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1701 views
  • 0 kudos
  • 4 in conversation
Announcements
