× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN102 don't shutdown properly since 6.4.0 upgrade
pit_vr
Re: RN102 don't shutdown properly since 6.4.0 upgrade
yes, of course it is no serious problem. Despite this "little" bug cost me several hours of troubleshooting (disk failure? wrong configuration? etc.)
And my RN102 was configured to shut down at night for various reasons (e.g. blackouts in our area are quite often), so I have to change this to 24/7 and wait.
BTW I dont think it is a good idea to use a beta, because there is no hint in the changelog, that it will fix our problem? But maybe I have overseen this.
Message 26 of 48
Lagamel
I don't agree, it's a serious problem.
I often use datas of my NAS when I am away from my home.
In this use case, I wake up the nas with wakeonlan and I turn it of at the end of the session.
With this problem, there is no way to wake it up as it don't shutdown totally.
It's a feature of the NAS, we are free to use it but it has to be fully fonctional.
I don't think the beta and the future release will solve the problem.
The update to 6.4.0 didn't take in count a partiular script or configuration of my device. With no understanding of the problem I'm curious to know how they will fix it.
By the way, the biggest problem of this nas is the lack of a console port to debug it when they are such problems.
Message 27 of 48
bhaal
Hi,
I solved the issue by desactivating the spin down. My RN102 shutdown proprely since 3 days
regards
Message 28 of 48
pit_vr
do you shutdown via power timer or by pressing the button?
Message 29 of 48
bhaal
via power time
Message 30 of 48
pit_vr
I'll try it - if it helps, that would be perfect, because I do not need the disk-spin-down feature.
Thanks bhaal!
Message 31 of 48
bhaal
it's works fine with an android app too 😉
Message 32 of 48
rubertjack
As mentioned earlier, with a blank harddisk and a factory reset, worked very well with the exact same configuration and applications (without the used one connected).
Then i removed  it and connected my old one the issue was still there. I'm not a tech savvy, but i assume.
BTW, issue is unresolved as i type. changing MTU back to 1500 didnt solve it. Never enabled disk spin-down.
Message 33 of 48
pit_vr
o.k. I checked with my RN102 what bhaal suggested, but it didn't work.
So disable disk-spin-down does _not_ help. No proper shutdown of the RN102 with 6.4.0. The RN102 hangs _every_ time at shutdown and the only solution is to unplug it from power, while some LEDs of the NAS are still on. Which in my opinion is no good at all, esp. on the long run.
I think a proper shutdown via time table is a key feature of the NAS and should work just smoothly. 😞
And it is no solution to wipe my hard-disks and set up the NAS from scratch, just because of an firmware update (which is no beta and which should be installed because of security reasons).
Message 34 of 48
JennC
NETGEAR Employee Retired
Hello pit_vr,
It may be best to contact support center.
Message 35 of 48
rubertjack
Do we have rollback option? I don't think so. Going off for vacation. Will have to contact support once I'm back. Will update you guys once I check with them. If you guys get any solution please keep us posted.
Have anyone tried to connect this hdd to a Linux system and checked whether anything can be done?
Message 36 of 48
pit_vr
Hi JennC,
I did what you suggested and contacted Netgear Support via Chat. What I found out (in my case) is:
- my NAS RN102 didn't properly shutdown, because of "ATA Error Count" of one of my HDs
- this shutdown problem didn't occur before updating to 6.4.0 (but the errors may have been there before)
So, for all of you with shutdown problems, please check your logs. What I learned is, that in the logs of the webinterface (Admin Page) _these_ errors are not listed. These errors do _not_ trigger a S.M.A.R.T. disk failure or anything like this - so you couldn't see them in the normal logs.
You have to "download" all the logs of your NAS "Admin Page -> Logs" and then open the "disk_info.log"
if there are any "ATA Errors" change this HD - and in my case everything is fine afterwards.
I hope this helps some of you  - and thanks to NETGEAR Support for their help.
pit
And dont forget to backup your data 😉
Message 37 of 48
Guru
@pit_vr wrote:
... my NAS RN102 didn't properly shutdown, because of "ATA Error Count" of one of my HDs
 ...What I learned is, that in the logs of the webinterface (Admin Page) _these_ errors are not listed. These errors do _not_ trigger a S.M.A.R.T. disk failure or anything like this - so you couldn't see them in the normal logs.
Increasing ATA error counts are logged in 4.x.x firmware, and do generate email alerts.  If that is not done with OS6, then in my opinion it is a bug.
FWIW, ATA errors aren't always caused by a faulty drive (but in most cases they are).
Message 38 of 48
mdgm-ntgr
Please let me know your case number so I can review it.
We do send email alerts about the ATA error count increasing. It's one of the key SMART stats that we track. The history of changes to counts such as the ATA error count are in smart_history.log
An increasing ATA error count is an indication that a disk may be failing.
Message 39 of 48
pit_vr
o.k. I see.
My case
Case # 26030582
I assumed, that these alerts will show up in the normal logs. I didn't set up an alert contact, because I viewed the logs of the NAS regularly. In my smart_history.log the increase of ata_erros is logged. Good to know, so I should set up the email notification Smiley Embarassed
If you still need it, I could post my smart_history.log
Message 40 of 48
pit_vr
Sorry, I have to come back on the issue, but yesterday my RN102 didn't shutdown again.
This time, there were no ATA-Errors.
To me it seems the problem still exists with 6.4.0 firmware ...
Message 41 of 48
Guru
There is a shutdown fix in the changelog for 6.4.1-T35 for RN100.  It might be worth a try.
Message 42 of 48
pit_vr
but should I install RN100 firmware on an RN102? And I couldn't find the firmware update, not on the website and there is no regular update via the admin page of my NAS. Could you show me, where I can find this?
Thanks a lot.
pit
Message 43 of 48
Guru
Thanks a lot.
pit
RN100 is the whole family, which includes RN102.
Beta release are in the forum, and are manually installed - they won't show up in the firmware update.  You'll find OS 6 betas here: https://community.netgear.com/t5/ReadyNAS-Beta-Release/bd-p/readynas-beta-releases?topic-zoom=Public...
The first post is the 6.4.1 beta information (fixes, change logs, download links).
It is beta, but T35 has been stable on my RN102.  Some folks have found it resolved 6.4.0 issues they were seeing (I'm one of them), but others haven't.
What disk model(s) are you using?
Message 44 of 48
rubertjack
My ATA Error Count is "0". Not sure why it wont shutdown.
Message 45 of 48
pit_vr
since the 6.4.1 update my NAS works as it should.
Message 46 of 48
rubertjack
Same here. Works well with 6.4.1
Message 47 of 48
Tonyp123
I have also had this same issue with 6.4.0. Unit just hanges flashing. Log's last entry is unit is shutting down. Now 6.4.1 will attemp to shut down, but goes from flashing to unit boot right back on.
Message 48 of 48
Top Contributors
Discussion stats
  • 47 replies
  • 6351 views
  • 0 kudos
  • 11 in conversation
Announcements
