× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN104: Disk failed, replaced, resync, data still degraded, NAS reboot = repeated resync problem
plostyle
Hello everyone Michał from Poland here,
I have a RN104 with 2x 4TB WD drives (initially 2x WD Green [Desktop i know]).
Recently one of the drives has been failing, so i replaced it with a 4TB WD Red, everything was going fine, few hours of resync and done.
Now i have 2 problems:
  1. Both disk show a green light, but the data is still degraded. Any ideas what should i do to bring it back to normal?
  2. After resync has completed - i have restarted the NAS (3 times now) - after the reboot - data resync starts over again (it takes a few hours).
I have searched the forums and google for an answer but no luck... maybe somebody can help me out with my problems. Below are the recent logs, and a screnshot:
15 Jan 2019 01:00:18 Volume: Volume data is Degraded.
15 Jan 2019 00:44:01 Volume: The resync operation finished on volume data. However, the volume is still degraded.
15 Jan 2019 00:43:51 Disk: Disk in channel 1 (Internal) changed state from RESYNC to ONLINE.
14 Jan 2019 18:14:43 System: ReadyNASOS background service started.
14 Jan 2019 18:14:32 Volume: Resyncing started for Volume data.
14 Jan 2019 18:14:32 Volume: Volume data is Degraded.
14 Jan 2019 18:11:31 System: The system is rebooting.
Model: RN104|ReadyNAS 100 Series
Message 1 of 6
Guru
Re: RN104: Disk failed, replaced, resync, data still degraded, NAS reboot = repeated resync problem
Can you check the SMART stats for both disks?  Perhaps also copy/paste mdstat.log here (you can use the "insert code" tool for that).
Also, what firmware are you running?
Message 2 of 6
plostyle
Hi again,thanks for your reply
I have the newest firmware version (6.9.4 Hotfix 1)
Below the mdstat.log
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid1 sda3[0] sdb3[2](S)
      3902166784 blocks super 1.2 [2/1] [U_]
      bitmap: 17/30 pages [68KB], 65536KB chunk
md1 : active raid1 sda2[0] sdb2[1]
      523712 blocks super 1.2 [2/2] [UU]
md0 : active raid1 sda1[3] sdb1[2]
      4190208 blocks super 1.2 [2/2] [UU]
unused devices: <none>
/dev/md/0:
        Version : 1.2
  Creation Time : Wed Apr 15 05:15:17 2015
     Raid Level : raid1
     Array Size : 4190208 (4.00 GiB 4.29 GB)
  Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
   Raid Devices : 2
  Total Devices : 2
    Persistence : Superblock is persistent
    Update Time : Wed Jan 16 18:32:20 2019
          State : clean
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
           Name : 2fe4f60e:0  (local to host 2fe4f60e)
           UUID : b939f237:dcc8fe34:e975d6b5:7b3f6c4e
         Events : 57378
    Number   Major   Minor   RaidDevice State
       3       8        1        0      active sync   /dev/sda1
       2       8       17        1      active sync   /dev/sdb1
/dev/md/1:
        Version : 1.2
  Creation Time : Sat Jan 12 12:25:30 2019
     Raid Level : raid1
     Array Size : 523712 (511.44 MiB 536.28 MB)
  Used Dev Size : 523712 (511.44 MiB 536.28 MB)
   Raid Devices : 2
  Total Devices : 2
    Update Time : Wed Jan 16 18:30:00 2019
          State : clean
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
           Name : 2fe4f60e:1  (local to host 2fe4f60e)
           UUID : 6eb0e2e7:ac8458bc:f4b8df87:ff5ca7fb
         Events : 19
       0       8        2        0      active sync   /dev/sda2
       1       8       18        1      active sync   /dev/sdb2
/dev/md/data-0:
        Version : 1.2
     Raid Level : raid1
     Array Size : 3902166784 (3721.40 GiB 3995.82 GB)
  Used Dev Size : 3902166784 (3721.40 GiB 3995.82 GB)
   Raid Devices : 2
  Total Devices : 2
  Intent Bitmap : Internal
    Update Time : Tue Jan 15 19:54:27 2019
          State : clean, degraded
 Active Devices : 1
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 1
           Name : 2fe4f60e:data-0  (local to host 2fe4f60e)
           UUID : f499f3cd:f84f401f:f890486d:667c8673
         Events : 30171
       0       8        3        0      active sync   /dev/sda3
       -       0        0        1      removed
       2       8       19        -      spare   /dev/sdb3
and disk_info.log
Device:             sdb
Controller:         0
Channel:            0
Model:              WDC WD40EFRX-68N32N0
Serial:             WD-WCC7K1AKUE03
Firmware:           82.00A82
Class:              SATA
RPM:                5400
Sectors:            7814037168
Pool:               data
PoolType:           RAID 1
PoolState:          3
PoolHostId:         2fe4f60e
Health data
  ATA Error Count:                0
  Reallocated Sectors:            0
  Reallocation Events:            0
  Spin Retry Count:               0
  Current Pending Sector Count:   0
  Uncorrectable Sector Count:     0
  Temperature:                    26
  Start/Stop Count:               13
  Power-On Hours:                 102
  Power Cycle Count:              1
  Load Cycle Count:               13
Device:             sda
Controller:         0
Channel:            1
Model:              WDC WD40EZRX-00SPEB0
Serial:             WD-WCC4E6UXL0NV
Firmware:           80.00A80
Class:              SATA
RPM:                5400
Sectors:            7814037168
Pool:               data
PoolType:           RAID 1
PoolState:          3
Health data
  ATA Error Count:                1
  Spin Retry Count:               0
  Current Pending Sector Count:   4
  Uncorrectable Sector Count:     3
  Temperature:                    28
  Start/Stop Count:               9396
  Power-On Hours:                 27349
  Power Cycle Count:              1397
  Load Cycle Count:               1500666
hope this makes some sense Man Surprised
Message 3 of 6
plostyle
Hi again,
My reply has vanished - i don't see it, so i am posting again:
I have the latest firmware (6.9.4 Hotfix 1), the disk status below:
and the mdstat.log:
/dev/md/0:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 2
  Total Devices : 2
          State : clean
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
         Events : 57378
/dev/md/1:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 2
  Total Devices : 2
          State : clean
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
         Events : 19
/dev/md/data-0:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 2
  Total Devices : 2
 Active Devices : 1
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 1
         Events : 30171
       -       0        0        1      removed
disk_info.log:
Device:             sdb
Controller:         0
Channel:            0
Firmware:           82.00A82
Class:              SATA
RPM:                5400
Sectors:            7814037168
Pool:               data
PoolType:           RAID 1
PoolState:          3
Health data
  ATA Error Count:                0
  Spin Retry Count:               0
  Temperature:                    26
  Power-On Hours:                 102
Device:             sda
Controller:         0
Channel:            1
Firmware:           80.00A80
Class:              SATA
RPM:                5400
Sectors:            7814037168
Pool:               data
PoolType:           RAID 1
PoolState:          3
Health data
  ATA Error Count:                1
  Spin Retry Count:               0
  Temperature:                    28
i hope thismakes some sense Man Surprised
Message 4 of 6
plostyle
Firmware 6.9.4 Hotfix 1
mdstat.log:
/dev/md/0:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 2
  Total Devices : 2
          State : clean
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
         Events : 57378
/dev/md/1:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 2
  Total Devices : 2
          State : clean
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
         Events : 19
/dev/md/data-0:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 2
  Total Devices : 2
 Active Devices : 1
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 1
         Events : 30171
       -       0        0        1      removed
disk_info.log:
Device:             sdb
Controller:         0
Channel:            0
Firmware:           82.00A82
Class:              SATA
RPM:                5400
Sectors:            7814037168
Pool:               data
PoolType:           RAID 1
PoolState:          3
Health data
  ATA Error Count:                0
  Spin Retry Count:               0
  Temperature:                    26
  Power-On Hours:                 102
Device:             sda
Controller:         0
Channel:            1
Firmware:           80.00A80
Class:              SATA
RPM:                5400
Sectors:            7814037168
Pool:               data
PoolType:           RAID 1
PoolState:          3
Health data
  ATA Error Count:                1
  Spin Retry Count:               0
  Temperature:                    28
Message 5 of 6
plostyle
Hi,
Thanks for the reply, i am using the latest firmware 6.9.4. Hotfix 1smart.png
mdstat.log
/dev/md/0:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 2
  Total Devices : 2
          State : clean
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
         Events : 57378
/dev/md/1:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 2
  Total Devices : 2
          State : clean
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
         Events : 19
/dev/md/data-0:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 2
  Total Devices : 2
 Active Devices : 1
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 1
         Events : 30171
       -       0        0        1      removed
disk_info.log
Device:             sdb
Controller:         0
Channel:            0
Firmware:           82.00A82
Class:              SATA
RPM:                5400
Sectors:            7814037168
Pool:               data
PoolType:           RAID 1
PoolState:          3
Health data
  ATA Error Count:                0
  Spin Retry Count:               0
  Temperature:                    26
  Power-On Hours:                 102
Device:             sda
Controller:         0
Channel:            1
Firmware:           80.00A80
Class:              SATA
RPM:                5400
Sectors:            7814037168
Pool:               data
PoolType:           RAID 1
PoolState:          3
Health data
  ATA Error Count:                1
  Spin Retry Count:               0
  Temperature:                    28
hope this makes any sense 🙂
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1354 views
  • 0 kudos
  • 2 in conversation
Announcements
