- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN104 degraded, but no prorgess
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all.
I am using my RN104 as a backup device sonce a very, very long time w/o any issues... Cool thing, not high performance, but good it works :-).
I changed in my RN104 one of the 4 harddrives. Before I had 4x 4TB WD red harddrives. I exchanged a old one some days/weeks ago (regular exchange without failiure). Now I have the following setup:
1x WD80EFBX; 2x WD60EFAX; 1x WD60EFRX
The front display shows "DEGRADED" error message - same on the web frontend, but no progress.
"green" traffic light on all 4 devices
mdadm --detail /dev/md127 shows "degraded", but I do not know why and I have no idea how that happend (is ithis normal) or any idea how to fix that?
Any proposal is welcome ,
Thanks. Norbert
checking /proc/mdstat shows no progress:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md126 : active raid5 sda3[5] sdc3[3] sdd3[6] sdb3[4]
11706503424 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md127 : active raid5 sdc4[1] sda4[3] sdb4[2]
5860115712 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [_UUU]
md1 : active raid10 sda2[0] sdd2[3] sdc2[2] sdb2[1]
1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
md0 : active raid1 sda1[5] sdc1[3] sdd1[6] sdb1[4]
4190208 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/var/log# mdadm --detail /dev/md126
/dev/md126:
Version : 1.2
Creation Time : Fri Nov 1 10:17:34 2019
Raid Level : raid5
Array Size : 11706503424 (11164.19 GiB 11987.46 GB)
Used Dev Size : 3902167808 (3721.40 GiB 3995.82 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Fri Nov 5 20:15:36 2021
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
Consistency Policy : unknown
Name : 0e349ed8:Volume_Backup-0 (local to host 0e349ed8)
UUID : a5655641:0de3a15d:04ae0e91:b294b7d0
Events : 235152
Number Major Minor RaidDevice State
5 8 3 0 active sync /dev/sda3
4 8 19 1 active sync /dev/sdb3
6 8 51 2 active sync /dev/sdd3
3 8 35 3 active sync /dev/sdc3
/dev/md127:
Version : 1.2
Creation Time : Fri Nov 15 09:24:58 2019
Raid Level : raid5
Array Size : 5860115712 (5588.64 GiB 6000.76 GB)
Used Dev Size : 1953371904 (1862.88 GiB 2000.25 GB)
Raid Devices : 4
Total Devices : 3
Update Time : Fri Nov 5 20:15:55 2021
State : clean, degraded
Active Devices : 3
Working Devices : 3
Failed Devices : 0
Spare Devices : 0
Chunk Size : 64K
Name : 0e349ed8:Volume_Backup-1 (local to host 0e349ed8)
UUID : 31979138:f23cfef8:dca0bbed:4e1804e3
Events : 113565
- 0 0 0 removed
1 8 36 1 active sync /dev/sdc4
2 8 20 2 active sync /dev/sdb4
3 8 4 3 active sync /dev/sda4
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree it doesn't look like it's expanding. First, make sure a 4th partition was created: fdisk -l /dev/sdd. You can also compare the size of the 4th partition to another drive's: fdisk -l /dev/sdc. If the partition is there and the right size, then the following should add it or give you an error message as to why it won't: mdadm /dev/md127 --add /dev/sdd4 --verbose.
If the partition isn't there, don't try to use fdisk to create it, it'll refuse to start it in the right place. I recommend you install and use parted for that.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN104 degraded, but no prorgess
The array is degraded because you replaced a drive. It will remain degraded until the resync completes.
"Degraded" means that there is no RAID redundancy, so if one of the original disks fails the volume will be lost.
@XAffi wrote:
2x WD60EFAX;
The WD60EFAX drives use SMR technology. Several folks here have found they misbehave in OS-6 ReadyNAS. SMR drives have variable write speeds (sustained writes can result in glacial speeds).
Generally I don't recommend them for any NAS - not saying you should replace them, but I do suggest keeping an eye out for problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stephan.
Thanks for your reply.
1. "SMR-Drives"--- I have them since almost 2 years now and yes, I am in the progress of replacing them step-by-step - the one I replaced was also an "SMR".
2. Is resync really running? Usually I see it in the /proc/mdstat. Any proposal where I can see if resync is running if it is not shown on the readynas itself, the web-interface or in the /proc/mdstat file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's a good question. Usually it is shown on the volume page. Your mdstat post shows sdd is missing from md127 (but it is in the md126 raid group).
What drive did you recently replace?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I replaced 1x WD60EFAX with 1x WD80EFBX...
And yes, I know the difference between md126 and m127...Any idea?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So that should be sda.
The puzzle is why sdd is missing from md127. Replacing sda worked, so it must have dropped out after the resync the WD80EFBX completed.
Have you tried rebooting the NAS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Sandshark,
Thanks.. Meaning you assumed that due to whatever reason resync has not started by itself...
I have checked ans seen that all partitions are available, size matches as well...
I will follow closely...but it seems it is working...
fdisk -l /dev/sdd
Disk /dev/sdd: 7.3 TiB, 8001563222016 bytes, 15628053168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: E93A4BDA-2E80-4CE4-9C98-3E82A6477A2F
Device Start End Sectors Size Type
/dev/sdd1 64 8388671 8388608 4G Linux RAID
/dev/sdd2 8388672 9437247 1048576 512M Linux RAID
/dev/sdd3 9437248 7814037119 7804599872 3.6T Linux RAID
/dev/sdd4 7814037120 11721045119 3907008000 1.8T Linux RAID
fdisk -l /dev/sdc
Disk /dev/sdc: 5.5 TiB, 6001175126016 bytes, 11721045168 sectors
Disklabel type: gpt
Disk identifier: 328949D9-CF99-4854-BAA8-3FD7BCFE4E4C
/dev/sdc1 64 8388671 8388608 4G Linux RAID
/dev/sdc2 8388672 9437247 1048576 512M Linux RAID
/dev/sdc3 9437248 7814037119 7804599872 3.6T Linux RAID
/dev/sdc4 7814037120 11721045119 3907008000 1.8T Linux RAID
root@Saturn:~# mdadm /dev/md127 --add /dev/sdd4 --verbose
mdadm: added /dev/sdd4
cat /proc/mdstat
md127 : active raid5 sdd4[4] sdc4[1] sda4[3] sdb4[2]
[>....................] recovery = 0.0% (647904/1953371904) finish=5449.9min speed=5971K/sec
And finally:
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was clear from the mdstat that the partition never got added to the volume, which would have then started the re-sync. The only question was why, and we still don't know. But I agree that manually doing so seems to have done the trick. But keep a lookout in case it fails somewhere along the way.
For whatever reason, the ReadyNASOS seems to increase the number of drives in an array before it adds a device to fill the empty slot. It is much more common to first add the device (so it becomes a spare), then change the number of devices (which will automatially start integrating the spare into the RAID).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sandshark, I will follow, but for the time being things are running now as expected... Thanks again. Honnestly the RN104 is already a liittle bit older, and I am happy adding an 8TB drive is working at all... Latest next week resync shall be done.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stephan,
Thanks for your effort.
The newly added WD80EFBX is sdd - all other drives show 5.5 TiB:
fdisk -l /dev/sdd
And a reboot has not fixed anything before. I followed the manual approach as posted and in a couple of days I will see if this was the magic trick.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Quick/Last feedback...
RESYNC finished successfully.. Thanks.
Norbert
