- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN104 fail to boot
- Mark as New
- Bookmark
- Subscribe
- Permalink
RN104 fail to boot
Hi, today I made an aupgrade FW to 6.10 and after reboot I get an error on LCD
mount_block_root+248
I am unable to recover OS from USB, reinstall OS, factory default etc.
That is what I am getting on serial port
Normal Boot
[Mon Apr 15 21:48:50.932 2019]
[Mon Apr 15 21:48:50.932 2019] BootROM 1.08
[Mon Apr 15 21:48:50.938 2019] Booting from NAND flash
[Mon Apr 15 21:48:50.984 2019]
[Mon Apr 15 21:48:50.984 2019] General initialization - Version: 1.0.0
[Mon Apr 15 21:48:50.988 2019]
[Mon Apr 15 21:48:50.988 2019] High speed PHY - Version: 2.1.4 (COM-PHY-V20)
[Mon Apr 15 21:48:51.169 2019] Update PEX Device ID 0x6710
[Mon Apr 15 21:48:51.169 2019] High speed PHY - Ended Successfully
[Mon Apr 15 21:48:51.174 2019] 0000
[Mon Apr 15 21:48:51.174 2019] DDR3 Training Sequence - Ver 5.7.1
[Mon Apr 15 21:48:51.178 2019] DDR3 Training Sequence - Run without PBS.
[Mon Apr 15 21:48:51.217 2019] DDR3 Training Sequence - Ended Successfully
[Mon Apr 15 21:48:51.650 2019] BootROM: Image checksum verification PASSED
[Mon Apr 15 21:48:51.668 2019]
[Mon Apr 15 21:48:51.668 2019] __ __ _ _
[Mon Apr 15 21:48:51.672 2019] | \/ | __ _ _ ____ _____| | |
[Mon Apr 15 21:48:51.675 2019] | |\/| |/ _` | '__\ \ / / _ \ | |
[Mon Apr 15 21:48:51.679 2019] | | | | (_| | | \ V / __/ | |
[Mon Apr 15 21:48:51.682 2019] |_| |_|\__,_|_| \_/ \___|_|_|
[Mon Apr 15 21:48:51.682 2019] _ _ ____ _
[Mon Apr 15 21:48:51.687 2019] | | | | | __ ) ___ ___ | |_
[Mon Apr 15 21:48:51.691 2019] | | | |___| _ \ / _ \ / _ \| __|
[Mon Apr 15 21:48:51.694 2019] | |_| |___| |_) | (_) | (_) | |_
[Mon Apr 15 21:48:51.699 2019] \___/ |____/ \___/ \___/ \__|
[Mon Apr 15 21:48:51.702 2019] ** LOADER **
[Mon Apr 15 21:48:51.706 2019]
[Mon Apr 15 21:48:51.706 2019] U-Boot 2011.12-gec25d27-dirty (Oct 26 2015 - 16:56:14) Marvell version: v2011.12 2014_T2.0p1
[Mon Apr 15 21:48:51.714 2019] 06/23/2015 ReadyNAS-104 V2.0
[Mon Apr 15 21:48:51.718 2019]
[Mon Apr 15 21:48:51.718 2019] Board: DB-88F6710-BP
[Mon Apr 15 21:48:51.718 2019] SoC: MV6710 A1
[Mon Apr 15 21:48:51.721 2019] CPU: Marvell PJ4B v7 UP (Rev 1) LE
[Mon Apr 15 21:48:51.721 2019] CPU @ 1200 [MHz]
[Mon Apr 15 21:48:51.725 2019] L2 @ 600 [MHz]
[Mon Apr 15 21:48:51.728 2019] TClock @ 200 [MHz]
[Mon Apr 15 21:48:51.731 2019] DDR @ 600 [MHz]
[Mon Apr 15 21:48:51.731 2019] DDR 16Bit Width, FastPath Memory Access
[Mon Apr 15 21:48:51.736 2019] DRAM: 512 MiB
[Mon Apr 15 21:48:51.811 2019]
[Mon Apr 15 21:48:51.811 2019] Map: Code: 0x1feef000:0x1ff9f514
[Mon Apr 15 21:48:51.816 2019] BSS: 0x1ffef8a0
[Mon Apr 15 21:48:51.820 2019] Stack: 0x1f9eeef8
[Mon Apr 15 21:48:51.820 2019] Heap: 0x1f9ef000:0x1feef000
[Mon Apr 15 21:48:51.824 2019]
[Mon Apr 15 21:48:51.863 2019] NAND: (ID 0xf1ad) 128 MiB
[Mon Apr 15 21:48:51.863 2019] MMC: MRVL_MMC: 0
[Mon Apr 15 21:48:51.867 2019] Bad block table found at page 65472, version 0x01
[Mon Apr 15 21:48:51.873 2019] Bad block table found at page 65408, version 0x01
[Mon Apr 15 21:48:51.876 2019] nand_read_bbt: Bad block at 0x000000080000
[Mon Apr 15 21:48:51.881 2019] nand_read_bbt: Bad block at 0x0000064c0000
[Mon Apr 15 21:48:51.885 2019] nand_read_bbt: Bad block at 0x000006c60000
[Mon Apr 15 21:48:51.889 2019] nand_read_bbt: Bad block at 0x000007680000
[Mon Apr 15 21:48:51.936 2019]
[Mon Apr 15 21:48:51.936 2019] Initialize and scan all PCI interfaces
[Mon Apr 15 21:48:51.939 2019] PEX unit.port(active IF[-first bus]):
[Mon Apr 15 21:48:51.943 2019] ------------------------------------------
[Mon Apr 15 21:48:51.946 2019] PEX 0: Root Complex Interface, Detected Link X1, GEN 2.0
[Mon Apr 15 21:48:51.953 2019] PEX 1: Root Complex Interface, Detected Link X1, GEN 2.0
[Mon Apr 15 21:48:51.961 2019] FPU not initialized
[Mon Apr 15 21:48:51.961 2019] USB 0: Host Mode
[Mon Apr 15 21:48:51.968 2019] USB 1: Host Mode
[Mon Apr 15 21:48:51.970 2019] Shutting down unused interfaces:
[Mon Apr 15 21:48:51.973 2019] SDIO
[Mon Apr 15 21:48:51.973 2019] AUDIO
[Mon Apr 15 21:48:51.973 2019] TDM
[Mon Apr 15 21:48:51.977 2019] Modules/Interfaces Detected:
[Mon Apr 15 21:48:51.980 2019] RGMII0 Phy
[Mon Apr 15 21:48:51.980 2019] RGMII1 Phy
[Mon Apr 15 21:48:51.983 2019] PEX0 (Lane 0)
[Mon Apr 15 21:48:51.987 2019] PEX1 (Lane 1)
[Mon Apr 15 21:48:51.987 2019] SATA0 (Lane 2)
[Mon Apr 15 21:48:51.991 2019] SATA1 (Lane 3)
[Mon Apr 15 21:48:51.991 2019] Net: egiga0, egiga1 [PRIME]
[Mon Apr 15 21:48:52.340 2019] Power On!
[Mon Apr 15 21:48:52.400 2019] FDT loaded successfully
[Mon Apr 15 21:48:52.400 2019] Saving Environment to NAND...
[Mon Apr 15 21:48:52.420 2019] Erasing Nand...
[Mon Apr 15 21:48:52.423 2019] Writing to Nand... done
[Mon Apr 15 21:48:52.474 2019] Hit any key to stop autoboot: 0
[Mon Apr 15 21:48:52.479 2019]
[Mon Apr 15 21:48:52.479 2019] NAND read: device 0 offset 0x200000, size 0x400000
[Mon Apr 15 21:48:53.331 2019] 4194304 bytes read: OK
[Mon Apr 15 21:48:53.331 2019] NAND read: device 0 offset 0x800000, size 0x400000
[Mon Apr 15 21:48:54.185 2019] 4194304 bytes read: OK
[Mon Apr 15 21:48:54.185 2019] ## Booting kernel from Legacy Image at 02000000 ...
[Mon Apr 15 21:48:54.190 2019] Image Name: Linux-4.4.163.armada.1
[Mon Apr 15 21:48:54.194 2019] Created: 2019-03-01 23:13:48 UTC
[Mon Apr 15 21:48:54.198 2019] Image Type: ARM Linux Kernel Image (uncompressed)
[Mon Apr 15 21:48:54.202 2019] Data Size: 3461624 Bytes = 3.3 MiB
[Mon Apr 15 21:48:54.209 2019] Load Address: 00008000
[Mon Apr 15 21:48:54.209 2019] Entry Point: 00008000
[Mon Apr 15 21:48:54.212 2019] Verifying Checksum ... OK
[Mon Apr 15 21:48:54.578 2019] ## Loading init Ramdisk from Legacy Image at 03000000 ...
[Mon Apr 15 21:48:54.582 2019] Image Name: initramfs
[Mon Apr 15 21:48:54.586 2019] Created: 2019-03-12 2:28:30 UTC
[Mon Apr 15 21:48:54.591 2019] Image Type: ARM Linux RAMDisk Image (lzma compressed)
[Mon Apr 15 21:48:54.596 2019] Data Size: 3426443 Bytes = 3.3 MiB
[Mon Apr 15 21:48:54.599 2019] Load Address: 00000000
[Mon Apr 15 21:48:54.603 2019] Entry Point: 00000000
[Mon Apr 15 21:48:54.606 2019] Verifying Checksum ... OK
[Mon Apr 15 21:48:54.966 2019] ## Flattened Device Tree blob at 01000000
[Mon Apr 15 21:48:54.969 2019] Booting using the fdt blob at 0x01000000
[Mon Apr 15 21:48:54.973 2019] Loading Kernel Image ... OK
[Mon Apr 15 21:48:55.375 2019] Loading Ramdisk to 1f6aa000, end 1f9ee88b ... OK
[Mon Apr 15 21:48:55.770 2019] Using Device Tree in place at 01000000, end 010068e5
[Mon Apr 15 21:48:55.841 2019] Updating device tree successful
[Mon Apr 15 21:48:55.846 2019]
[Mon Apr 15 21:48:55.846 2019] Starting kernel ...
[Mon Apr 15 21:49:01.155 2019] [ 3.443626] Initramfs unpacking failed: LZMA data is corrupt
[Mon Apr 15 21:49:01.805 2019] [ 4.386455] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[Mon Apr 15 21:49:01.812 2019] [ 4.394765] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.163.armada.1 #1
[Mon Apr 15 21:49:01.820 2019] [ 4.401582] Hardware name: Marvell Armada 370/XP (Device Tree)
[Mon Apr 15 21:49:01.826 2019] [ 4.407479] [<c001524c>] (unwind_backtrace) from [<c001173c>] (show_stack+0x10/0x18)
[Mon Apr 15 21:49:01.834 2019] [ 4.415276] [<c001173c>] (show_stack) from [<c0380090>] (dump_stack+0x78/0x9c)
[Mon Apr 15 21:49:01.840 2019] [ 4.422548] [<c0380090>] (dump_stack) from [<c009b23c>] (panic+0x84/0x1f8)
[Mon Apr 15 21:49:01.848 2019] [ 4.429464] [<c009b23c>] (panic) from [<c090c244>] (mount_block_root+0x24c/0x29c)
[Mon Apr 15 21:49:01.857 2019] [ 4.436986] [<c090c244>] (mount_block_root) from [<c090c42c>] (prepare_namespace+0x128/0x188)
[Mon Apr 15 21:49:01.865 2019] [ 4.445554] [<c090c42c>] (prepare_namespace) from [<c090be94>] (kernel_init_freeable+0x210/0x260)
[Mon Apr 15 21:49:01.874 2019] [ 4.454478] [<c090be94>] (kernel_init_freeable) from [<c06b8758>] (kernel_init+0x8/0xe8)
[Mon Apr 15 21:49:01.882 2019] [ 4.462612] [<c06b8758>] (kernel_init) from [<c000ed00>] (ret_from_fork+0x14/0x34)
[Mon Apr 15 21:49:02.048 2019] [ 4.629973] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[Mon Apr 15 21:50:00.401 2019]
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN104 fail to boot
USB - Recovery
[Mon Apr 15 21:50:00.401 2019] BootROM 1.08
[Mon Apr 15 21:50:00.407 2019] Booting from NAND flash
[Mon Apr 15 21:50:00.453 2019]
[Mon Apr 15 21:50:00.453 2019] General initialization - Version: 1.0.0
[Mon Apr 15 21:50:00.456 2019]
[Mon Apr 15 21:50:00.457 2019] High speed PHY - Version: 2.1.4 (COM-PHY-V20)
[Mon Apr 15 21:50:00.637 2019] Update PEX Device ID 0x6710
[Mon Apr 15 21:50:00.637 2019] High speed PHY - Ended Successfully
[Mon Apr 15 21:50:00.642 2019] 0000
[Mon Apr 15 21:50:00.642 2019] DDR3 Training Sequence - Ver 5.7.1
[Mon Apr 15 21:50:00.646 2019] DDR3 Training Sequence - Run without PBS.
[Mon Apr 15 21:50:00.687 2019] DDR3 Training Sequence - Ended Successfully
[Mon Apr 15 21:50:01.120 2019] BootROM: Image checksum verification PASSED
[Mon Apr 15 21:50:01.137 2019]
[Mon Apr 15 21:50:01.137 2019] __ __ _ _
[Mon Apr 15 21:50:01.141 2019] | \/ | __ _ _ ____ _____| | |
[Mon Apr 15 21:50:01.145 2019] | |\/| |/ _` | '__\ \ / / _ \ | |
[Mon Apr 15 21:50:01.149 2019] | | | | (_| | | \ V / __/ | |
[Mon Apr 15 21:50:01.153 2019] |_| |_|\__,_|_| \_/ \___|_|_|
[Mon Apr 15 21:50:01.153 2019] _ _ ____ _
[Mon Apr 15 21:50:01.158 2019] | | | | | __ ) ___ ___ | |_
[Mon Apr 15 21:50:01.162 2019] | | | |___| _ \ / _ \ / _ \| __|
[Mon Apr 15 21:50:01.165 2019] | |_| |___| |_) | (_) | (_) | |_
[Mon Apr 15 21:50:01.169 2019] \___/ |____/ \___/ \___/ \__|
[Mon Apr 15 21:50:01.173 2019] ** LOADER **
[Mon Apr 15 21:50:01.177 2019]
[Mon Apr 15 21:50:01.177 2019] U-Boot 2011.12-gec25d27-dirty (Oct 26 2015 - 16:56:14) Marvell version: v2011.12 2014_T2.0p1
[Mon Apr 15 21:50:01.184 2019] 06/23/2015 ReadyNAS-104 V2.0
[Mon Apr 15 21:50:01.189 2019]
[Mon Apr 15 21:50:01.189 2019] Board: DB-88F6710-BP
[Mon Apr 15 21:50:01.189 2019] SoC: MV6710 A1
[Mon Apr 15 21:50:01.193 2019] CPU: Marvell PJ4B v7 UP (Rev 1) LE
[Mon Apr 15 21:50:01.193 2019] CPU @ 1200 [MHz]
[Mon Apr 15 21:50:01.197 2019] L2 @ 600 [MHz]
[Mon Apr 15 21:50:01.197 2019] TClock @ 200 [MHz]
[Mon Apr 15 21:50:01.201 2019] DDR @ 600 [MHz]
[Mon Apr 15 21:50:01.201 2019] DDR 16Bit Width, FastPath Memory Access
[Mon Apr 15 21:50:01.208 2019] DRAM: 512 MiB
[Mon Apr 15 21:50:01.280 2019]
[Mon Apr 15 21:50:01.280 2019] Map: Code: 0x1feef000:0x1ff9f514
[Mon Apr 15 21:50:01.283 2019] BSS: 0x1ffef8a0
[Mon Apr 15 21:50:01.287 2019] Stack: 0x1f9eeef8
[Mon Apr 15 21:50:01.287 2019] Heap: 0x1f9ef000:0x1feef000
[Mon Apr 15 21:50:01.291 2019]
[Mon Apr 15 21:50:01.333 2019] NAND: (ID 0xf1ad) 128 MiB
[Mon Apr 15 21:50:01.333 2019] MMC: MRVL_MMC: 0
[Mon Apr 15 21:50:01.336 2019] Bad block table found at page 65472, version 0x01
[Mon Apr 15 21:50:01.342 2019] Bad block table found at page 65408, version 0x01
[Mon Apr 15 21:50:01.346 2019] nand_read_bbt: Bad block at 0x000000080000
[Mon Apr 15 21:50:01.350 2019] nand_read_bbt: Bad block at 0x0000064c0000
[Mon Apr 15 21:50:01.354 2019] nand_read_bbt: Bad block at 0x000006c60000
[Mon Apr 15 21:50:01.358 2019] nand_read_bbt: Bad block at 0x000007680000
[Mon Apr 15 21:50:01.405 2019]
[Mon Apr 15 21:50:01.405 2019] Initialize and scan all PCI interfaces
[Mon Apr 15 21:50:01.409 2019] PEX unit.port(active IF[-first bus]):
[Mon Apr 15 21:50:01.414 2019] ------------------------------------------
[Mon Apr 15 21:50:01.418 2019] PEX 0: Root Complex Interface, Detected Link X1, GEN 2.0
[Mon Apr 15 21:50:01.423 2019] PEX 1: Root Complex Interface, Detected Link X1, GEN 2.0
[Mon Apr 15 21:50:01.430 2019] FPU not initialized
[Mon Apr 15 21:50:01.430 2019] USB 0: Host Mode
[Mon Apr 15 21:50:01.437 2019] USB 1: Host Mode
[Mon Apr 15 21:50:01.439 2019] Shutting down unused interfaces:
[Mon Apr 15 21:50:01.442 2019] SDIO
[Mon Apr 15 21:50:01.442 2019] AUDIO
[Mon Apr 15 21:50:01.442 2019] TDM
[Mon Apr 15 21:50:01.446 2019] Modules/Interfaces Detected:
[Mon Apr 15 21:50:01.450 2019] RGMII0 Phy
[Mon Apr 15 21:50:01.450 2019] RGMII1 Phy
[Mon Apr 15 21:50:01.453 2019] PEX0 (Lane 0)
[Mon Apr 15 21:50:01.457 2019] PEX1 (Lane 1)
[Mon Apr 15 21:50:01.457 2019] SATA0 (Lane 2)
[Mon Apr 15 21:50:01.457 2019] SATA1 (Lane 3)
[Mon Apr 15 21:50:01.460 2019] Net: egiga0, egiga1 [PRIME]
[Mon Apr 15 21:50:01.810 2019] Power On!
[Mon Apr 15 21:50:01.868 2019] FDT loaded successfully
[Mon Apr 15 21:50:03.126 2019] Hit any key to stop autoboot: 0
[Mon Apr 15 21:50:03.131 2019] (Re)start USB...
[Mon Apr 15 21:50:03.131 2019] USB: Active port: 0
[Mon Apr 15 21:50:03.135 2019] Register 10011 NbrPorts 1
[Mon Apr 15 21:50:03.143 2019] USB EHCI 1.00
[Mon Apr 15 21:50:03.143 2019] scanning bus for devices... 2 USB Device(s) found
[Mon Apr 15 21:50:04.235 2019] scanning bus for storage devices... 1 Storage Device(s) found
[Mon Apr 15 21:50:04.423 2019] reading /uImage-recovery
[Mon Apr 15 21:50:06.498 2019]
[Mon Apr 15 21:50:06.498 2019] 3159060 bytes read
[Mon Apr 15 21:50:06.523 2019] reading /initrd-recovery.gz
[Mon Apr 15 21:50:08.010 2019]
[Mon Apr 15 21:50:08.010 2019] 2213667 bytes read
[Mon Apr 15 21:50:08.010 2019] NAND read: device 0 offset 0xd4000, size 0x6000
[Mon Apr 15 21:50:08.021 2019] 24576 bytes read: OK
[Mon Apr 15 21:50:08.021 2019] ## Booting kernel from Legacy Image at 02000000 ...
[Mon Apr 15 21:50:08.028 2019] Image Name: Linux-3.0.101.RN_ARM.4
[Mon Apr 15 21:50:08.031 2019] Created: 2015-04-01 23:06:44 UTC
[Mon Apr 15 21:50:08.040 2019] Image Type: ARM Linux Kernel Image (uncompressed)
[Mon Apr 15 21:50:08.040 2019] Data Size: 3158996 Bytes = 3 MiB
[Mon Apr 15 21:50:08.045 2019] Load Address: 00008000
[Mon Apr 15 21:50:08.045 2019] Entry Point: 00008000
[Mon Apr 15 21:50:08.049 2019] Verifying Checksum ... OK
[Mon Apr 15 21:50:08.384 2019] ## Loading init Ramdisk from Legacy Image at 03000000 ...
[Mon Apr 15 21:50:08.388 2019] Image Name: initramfs
[Mon Apr 15 21:50:08.392 2019] Created: 2016-10-27 4:30:30 UTC
[Mon Apr 15 21:50:08.396 2019] Image Type: ARM Linux RAMDisk Image (lzma compressed)
[Mon Apr 15 21:50:08.401 2019] Data Size: 2213603 Bytes = 2.1 MiB
[Mon Apr 15 21:50:08.405 2019] Load Address: 00000000
[Mon Apr 15 21:50:08.408 2019] Entry Point: 00000000
[Mon Apr 15 21:50:08.412 2019] Verifying Checksum ... OK
[Mon Apr 15 21:50:08.643 2019] ERROR: Did not find a cmdline Flattened Device Tree
[Mon Apr 15 21:50:08.647 2019] Could not find a valid device tree
[Mon Apr 15 21:50:08.725 2019] Marvell>>
- Mark as New
- Bookmark
- Subscribe
- Permalink
OS Reinstall
[Mon Apr 15 21:51:14.944 2019] BootROM 1.08
[Mon Apr 15 21:51:14.950 2019] Booting from NAND flash
[Mon Apr 15 21:51:14.996 2019]
[Mon Apr 15 21:51:14.996 2019] General initialization - Version: 1.0.0
[Mon Apr 15 21:51:15.000 2019]
[Mon Apr 15 21:51:15.000 2019] High speed PHY - Version: 2.1.4 (COM-PHY-V20)
[Mon Apr 15 21:51:15.180 2019] Update PEX Device ID 0x6710
[Mon Apr 15 21:51:15.180 2019] High speed PHY - Ended Successfully
[Mon Apr 15 21:51:15.185 2019] 0001
[Mon Apr 15 21:51:15.185 2019] DDR3 Training Sequence - Ver 5.7.1
[Mon Apr 15 21:51:15.189 2019] DDR3 Training Sequence - Run without PBS.
[Mon Apr 15 21:51:15.229 2019] DDR3 Training Sequence - Ended Successfully
[Mon Apr 15 21:51:15.662 2019] BootROM: Image checksum verification PASSED
[Mon Apr 15 21:51:15.680 2019]
[Mon Apr 15 21:51:15.680 2019] __ __ _ _
[Mon Apr 15 21:51:15.684 2019] | \/ | __ _ _ ____ _____| | |
[Mon Apr 15 21:51:15.687 2019] | |\/| |/ _` | '__\ \ / / _ \ | |
[Mon Apr 15 21:51:15.691 2019] | | | | (_| | | \ V / __/ | |
[Mon Apr 15 21:51:15.695 2019] |_| |_|\__,_|_| \_/ \___|_|_|
[Mon Apr 15 21:51:15.695 2019] _ _ ____ _
[Mon Apr 15 21:51:15.701 2019] | | | | | __ ) ___ ___ | |_
[Mon Apr 15 21:51:15.705 2019] | | | |___| _ \ / _ \ / _ \| __|
[Mon Apr 15 21:51:15.710 2019] | |_| |___| |_) | (_) | (_) | |_
[Mon Apr 15 21:51:15.715 2019] \___/ |____/ \___/ \___/ \__|
[Mon Apr 15 21:51:15.715 2019] ** LOADER **
[Mon Apr 15 21:51:15.719 2019]
[Mon Apr 15 21:51:15.719 2019] U-Boot 2011.12-gec25d27-dirty (Oct 26 2015 - 16:56:14) Marvell version: v2011.12 2014_T2.0p1
[Mon Apr 15 21:51:15.728 2019] 06/23/2015 ReadyNAS-104 V2.0
[Mon Apr 15 21:51:15.728 2019] Board: DB-88F6710-BP
[Mon Apr 15 21:51:15.728 2019] SoC: MV6710 A1
[Mon Apr 15 21:51:15.732 2019] CPU: Marvell PJ4B v7 UP (Rev 1) LE
[Mon Apr 15 21:51:15.736 2019] CPU @ 1200 [MHz]
[Mon Apr 15 21:51:15.736 2019] L2 @ 600 [MHz]
[Mon Apr 15 21:51:15.741 2019] TClock @ 200 [MHz]
[Mon Apr 15 21:51:15.746 2019] DDR @ 600 [MHz]
[Mon Apr 15 21:51:15.746 2019] DDR 16Bit Width, FastPath Memory Access
[Mon Apr 15 21:51:15.750 2019] DRAM: 512 MiB
[Mon Apr 15 21:51:15.822 2019]
[Mon Apr 15 21:51:15.822 2019] Map: Code: 0x1feef000:0x1ff9f514
[Mon Apr 15 21:51:15.826 2019] BSS: 0x1ffef8a0
[Mon Apr 15 21:51:15.829 2019] Stack: 0x1f9eeef8
[Mon Apr 15 21:51:15.830 2019] Heap: 0x1f9ef000:0x1feef000
[Mon Apr 15 21:51:15.833 2019]
[Mon Apr 15 21:51:15.872 2019] NAND: (ID 0xf1ad) 128 MiB
[Mon Apr 15 21:51:15.877 2019] MMC: MRVL_MMC: 0
[Mon Apr 15 21:51:15.877 2019] Bad block table found at page 65472, version 0x01
[Mon Apr 15 21:51:15.883 2019] Bad block table found at page 65408, version 0x01
[Mon Apr 15 21:51:15.889 2019] nand_read_bbt: Bad block at 0x000000080000
[Mon Apr 15 21:51:15.892 2019] nand_read_bbt: Bad block at 0x0000064c0000
[Mon Apr 15 21:51:15.896 2019] nand_read_bbt: Bad block at 0x000006c60000
[Mon Apr 15 21:51:15.901 2019] nand_read_bbt: Bad block at 0x000007680000
[Mon Apr 15 21:51:15.947 2019]
[Mon Apr 15 21:51:15.947 2019] Initialize and scan all PCI interfaces
[Mon Apr 15 21:51:15.951 2019] PEX unit.port(active IF[-first bus]):
[Mon Apr 15 21:51:15.954 2019] ------------------------------------------
[Mon Apr 15 21:51:15.958 2019] PEX 0: Root Complex Interface, Detected Link X1, GEN 2.0
[Mon Apr 15 21:51:15.964 2019] PEX 1: Root Complex Interface, Detected Link X1, GEN 2.0
[Mon Apr 15 21:51:15.973 2019] FPU not initialized
[Mon Apr 15 21:51:15.973 2019] USB 0: Host Mode
[Mon Apr 15 21:51:15.980 2019] USB 1: Host Mode
[Mon Apr 15 21:51:15.982 2019] Shutting down unused interfaces:
[Mon Apr 15 21:51:15.985 2019] SDIO
[Mon Apr 15 21:51:15.985 2019] AUDIO
[Mon Apr 15 21:51:15.985 2019] TDM
[Mon Apr 15 21:51:15.989 2019] Modules/Interfaces Detected:
[Mon Apr 15 21:51:15.993 2019] RGMII0 Phy
[Mon Apr 15 21:51:15.994 2019] RGMII1 Phy
[Mon Apr 15 21:51:15.997 2019] PEX0 (Lane 0)
[Mon Apr 15 21:51:15.997 2019] PEX1 (Lane 1)
[Mon Apr 15 21:51:15.997 2019] SATA0 (Lane 2)
[Mon Apr 15 21:51:16.001 2019] SATA1 (Lane 3)
[Mon Apr 15 21:51:16.004 2019] Net: egiga0, egiga1 [PRIME]
[Mon Apr 15 21:51:16.352 2019] Power On!
[Mon Apr 15 21:51:16.411 2019] FDT loaded successfully
[Mon Apr 15 21:51:18.596 2019] Saving Environment to NAND...
[Mon Apr 15 21:51:18.613 2019] Erasing Nand...
[Mon Apr 15 21:51:18.616 2019] Writing to Nand... done
[Mon Apr 15 21:51:18.731 2019] Enter Bootmenu...
[Mon Apr 15 21:51:23.675 2019] Bootmenu : NORMAL
[Mon Apr 15 21:51:24.629 2019] Bootmenu : FACTORY_DEFAULT
[Mon Apr 15 21:51:25.885 2019] Bootmenu : OS_REINSTALL
[Mon Apr 15 21:51:26.478 2019] Bootmenu : TECH_SUPPORT
[Mon Apr 15 21:51:26.873 2019] Bootmenu : VOL_RO
[Mon Apr 15 21:51:27.406 2019] Bootmenu : MEMORY_TEST
[Mon Apr 15 21:51:29.873 2019] Bootmenu : TEST_DISK
[Mon Apr 15 21:51:31.747 2019] Bootmenu : NORMAL
[Mon Apr 15 21:51:32.426 2019] Bootmenu : FACTORY_DEFAULT
[Mon Apr 15 21:51:33.878 2019] Bootmenu : OS_REINSTALL
[Mon Apr 15 21:51:49.062 2019] Hit any key to stop autoboot: 0
[Mon Apr 15 21:51:49.066 2019]
[Mon Apr 15 21:51:49.066 2019] NAND read: device 0 offset 0x200000, size 0x400000
[Mon Apr 15 21:51:49.919 2019] 4194304 bytes read: OK
[Mon Apr 15 21:51:49.919 2019] NAND read: device 0 offset 0x800000, size 0x400000
[Mon Apr 15 21:51:50.773 2019] 4194304 bytes read: OK
[Mon Apr 15 21:51:50.773 2019] ## Booting kernel from Legacy Image at 02000000 ...
[Mon Apr 15 21:51:50.779 2019] Image Name: Linux-4.4.163.armada.1
[Mon Apr 15 21:51:50.782 2019] Created: 2019-03-01 23:13:48 UTC
[Mon Apr 15 21:51:50.786 2019] Image Type: ARM Linux Kernel Image (uncompressed)
[Mon Apr 15 21:51:50.790 2019] Data Size: 3461624 Bytes = 3.3 MiB
[Mon Apr 15 21:51:50.795 2019] Load Address: 00008000
[Mon Apr 15 21:51:50.795 2019] Entry Point: 00008000
[Mon Apr 15 21:51:50.798 2019] Verifying Checksum ... OK
[Mon Apr 15 21:51:51.166 2019] ## Loading init Ramdisk from Legacy Image at 03000000 ...
[Mon Apr 15 21:51:51.170 2019] Image Name: initramfs
[Mon Apr 15 21:51:51.174 2019] Created: 2019-03-12 2:28:30 UTC
[Mon Apr 15 21:51:51.181 2019] Image Type: ARM Linux RAMDisk Image (lzma compressed)
[Mon Apr 15 21:51:51.186 2019] Data Size: 3426443 Bytes = 3.3 MiB
[Mon Apr 15 21:51:51.190 2019] Load Address: 00000000
[Mon Apr 15 21:51:51.190 2019] Entry Point: 00000000
[Mon Apr 15 21:51:51.194 2019] Verifying Checksum ... OK
[Mon Apr 15 21:51:51.554 2019] ## Flattened Device Tree blob at 01000000
[Mon Apr 15 21:51:51.558 2019] Booting using the fdt blob at 0x01000000
[Mon Apr 15 21:51:51.561 2019] Loading Kernel Image ... OK
[Mon Apr 15 21:51:51.963 2019] Loading Ramdisk to 1f6aa000, end 1f9ee88b ... OK
[Mon Apr 15 21:51:52.358 2019] Using Device Tree in place at 01000000, end 010068e5
[Mon Apr 15 21:51:52.429 2019] Updating device tree successful
[Mon Apr 15 21:51:52.433 2019]
[Mon Apr 15 21:51:52.433 2019] Starting kernel ...
[Mon Apr 15 21:51:57.743 2019] [ 3.443288] Initramfs unpacking failed: LZMA data is corrupt
[Mon Apr 15 21:51:58.358 2019] [ 4.352425] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[Mon Apr 15 21:51:58.365 2019] [ 4.360735] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.163.armada.1 #1
[Mon Apr 15 21:51:58.374 2019] [ 4.367553] Hardware name: Marvell Armada 370/XP (Device Tree)
[Mon Apr 15 21:51:58.379 2019] [ 4.373450] [<c001524c>] (unwind_backtrace) from [<c001173c>] (show_stack+0x10/0x18)
[Mon Apr 15 21:51:58.388 2019] [ 4.381247] [<c001173c>] (show_stack) from [<c0380090>] (dump_stack+0x78/0x9c)
[Mon Apr 15 21:51:58.394 2019] [ 4.388519] [<c0380090>] (dump_stack) from [<c009b23c>] (panic+0x84/0x1f8)
[Mon Apr 15 21:51:58.402 2019] [ 4.395435] [<c009b23c>] (panic) from [<c090c244>] (mount_block_root+0x24c/0x29c)
[Mon Apr 15 21:51:58.411 2019] [ 4.402958] [<c090c244>] (mount_block_root) from [<c090c42c>] (prepare_namespace+0x128/0x188)
[Mon Apr 15 21:51:58.419 2019] [ 4.411526] [<c090c42c>] (prepare_namespace) from [<c090be94>] (kernel_init_freeable+0x210/0x260)
[Mon Apr 15 21:51:58.428 2019] [ 4.420450] [<c090be94>] (kernel_init_freeable) from [<c06b8758>] (kernel_init+0x8/0xe8)
[Mon Apr 15 21:51:58.436 2019] [ 4.428584] [<c06b8758>] (kernel_init) from [<c000ed00>] (ret_from_fork+0x14/0x34)
[Mon Apr 15 21:51:58.602 2019] [ 4.595954] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Alein,
This is probably not good. It says that the NAS has some bad blocks
Your NAS also has an old kernel. OS 6.10 uses kernel 4.4. What was the firmware of the NAS before you upgraded it to 6.10?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
6.9.5 .The problem perhaps was damaged RAM, and reboot just kill this NAS.
Currently, I suspect RAM damage. And I made something stupid( you know it is after midnight and you feel that there must be something that can fix the issue 🙂 , I have erased the whole NAND, without u-boot binaries I am not able to fix it.
This NAS was a gift, and as a result, Netgear support refuses to fix it on warranty without proof of purchase.
So I made an order for a new RAM on Aliexpress Hynix H5TQ2G83DFRH9C and NAND Hynix H27U1G8F2BTR
The NAND is not a problem yet, as I have working one from the previous RN104. It seems that this one had exactly this same issue. There are a lot of companies with the proper hardware to do it, and even if they refuse or ask me about astronomical price, I can order the programmer ProMan Professional TSOP48
As I saw in logs, every time when new FW is stored, there is a check, and BIOS is trying to boot u-boot every 10000 blocks
