- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN10400 6.2.5 no UI
- Mark as New
- Bookmark
- Subscribe
- Permalink
RN10400 6.2.5 no UI
Hello,
run in truble after upgrading to 6.2.5.
No login was possible, after reinstalling OS, i get an ssh login.
"Attemd to reconect ..."
First Problem was rootfs at 100%, after moving old locks i get 71%
i think readynasd dont start
systemctl status readynasd
readynasd.service - ReadyNAS System Daemon
Loaded: loaded (/lib/systemd/system/readynasd.service; enabled)
Active: activating (start) since Sun, 30 Aug 2015 20:45:01 +0200; 37s ago
Main PID: 14769 (readynasd)
Status: "Importing DB"
CGroup: name=systemd:/system/readynasd.service
└ 14769 /usr/sbin/readynasd -v 3 -t
Aug 30 20:45:01 nasn readynasd[14769]: readynasd log started
Aug 30 20:45:02 nasn readynasd[14769]: readynasd started. (restarted=0)
Aug 30 20:45:02 nasn readynasd[14769]: DB (main) schema version: 18 ==> 18
Aug 30 20:45:02 nasn readynasd[14769]: DB (queue) schema version: new ==> 0
###syslog ####
Aug 30 20:48:43 nasn apache2[2167]: [error] [client 192.168.178.107] Connect rddclient failed, referer: https://192.168.178.10/admin/
Aug 30 20:48:43 nasn apache2[2167]: [error] [client 192.168.178.107] Premature end of script headers: dbbroker.cgi, referer: https://192.168.178.10/admin/
Aug 30 20:48:47 nasn apache2[2101]: [error] [client 192.168.178.107] Connect rddclient failed, referer: https://192.168.178.10/admin/
Aug 30 20:48:47 nasn apache2[2101]: [error] [client 192.168.178.107] Premature end of script headers: dbbroker.cgi, referer: https://192.168.178.10/admin/
Aug 30 20:48:51 nasn apache2[2099]: [error] [client 192.168.178.107] Connect rddclient failed, referer: https://192.168.178.10/admin/
Aug 30 20:48:51 nasn apache2[2099]: [error] [client 192.168.178.107] Premature end of script headers: dbbroker.cgi, referer: https://192.168.178.10/admin/
Aug 30 20:48:52 nasn apache2[2100]: [error] [client 192.168.178.107] Connect rddclient failed, referer: https://192.168.178.10/admin/
Aug 30 20:48:52 nasn apache2[2100]: [error] [client 192.168.178.107] Premature end of script headers: dbbroker.cgi, referer: https://192.168.178.10/admin/
#### syslog end ####
#####messages ####
Aug 30 20:46:26 nasn readynasd[14889]: ReadyNASOS service or process (readynasd) was restarted.
Aug 30 20:47:11 nasn readynasd[15004]: ReadyNASOS service or process (readynasd) was restarted.
Aug 30 20:47:55 nasn readynasd[15120]: ReadyNASOS service or process (readynasd) was restarted.
Aug 30 20:48:37 nasn readynasd[15237]: ReadyNASOS service or process (readynasd) was restarted.
Aug 30 20:49:20 nasn readynasd[15341]: ReadyNASOS service or process (readynasd) was restarted.
Anny Idea ?
chears Carl
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN10400 6.2.5 no UI
71% is way too full. What have you out on there?
- Mark as New
- Bookmark
- Subscribe
- Permalink
mysql Database with more then 1.3GB Data.
i don't know witch apps use them.
Possible the squeesebox server. but i remove it 3 Month ago.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You want to make sure the app data is stored on the data volume.
What apps do you have installed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
can't look in UI, i have installed
- radius Server (only for testing)
- DNS UI (only for testing)
- squeezebox server (remove 3 month ago)
Im not sure, but i remove every app.
i install this DPK
- vim
- mc
- munin-node (removed)
- Mark as New
- Bookmark
- Subscribe
- Permalink
You should stop MySQL, move your database to the data volume and create a symlink to it on the OS partition.
- Mark as New
- Bookmark
- Subscribe
- Permalink
was my first try to get space.
but mysql don't start.
(move the db to the raid, linking it with "ln -s [path/dbname] [dbname]"
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
root@nasn:~# df Filesystem 1K-blocks Used Available Use% Mounted on rootfs 4175488 2811244 1154636 71% / tmpfs 10240 4 10236 1% /dev /dev/md0 4175488 2811244 1154636 71% / tmpfs 253640 0 253640 0% /dev/shm tmpfs 253640 524 253116 1% /run tmpfs 253640 0 253640 0% /sys/fs/cgroup tmpfs 253640 0 253640 0% /media /dev/sde1 2929982976 798412032 2131570944 28% /media/USB_HDD_1 /dev/md127 8776250112 3366463552 5408227520 39% /pub /dev/md127 8776250112 3366463552 5408227520 39% /home /dev/md127 8776250112 3366463552 5408227520 39% /apps /dev/md127 8776250112 3366463552 5408227520 39% /var/ftp/home
- Mark as New
- Bookmark
- Subscribe
- Permalink
up to now, i get no Answer.
at the Moment i copy every Data to an USB 3.0 HD with 10MB/S .i think in some Days i can reset the Nas to default, or buy a other with more speed and better Software ....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like an app could be using up a lot of space on the OS partition. An app storing data appropriately is up to the developer of the app.
I'd like to have a remote look at your system as it would be easier to diagnose the problem that way. Sending you a PM.
