Orbi WiFi 7 RBE973
Reply
RN10400 Nas Station starts for 1 second then turns off then starts again for 1 second continuosly
pcsentinel
Hi, the power button and power light come on and the diplay shows an intial screen with NETGEAR STORAGE welcome, but then after a second they all turn off again, then after a few seconds that the cycle repeats, the fan done not move.
Any ideas?
Message 1 of 4
Accepted Solutions
Sandshark
Sensei
Re: RN10400 Nas Station starts for 1 second then turns off then starts again for 1 second continuosl
Most likely a power problem.  Booting without drives may help determine that.  If it is that, then the next step would be trying another power brick.
Message 3 of 4
All Replies
Guru
Try removing the disks (labeling by slot number), and then power up again.  See if it gives you a "no disks" status.
Message 2 of 4
Sandshark
Sensei
Message 3 of 4
pcsentinel
Thanks, yes with all drives removed then it started. I measured the pins on the the power supply output and only one was showing 12V. I purchased a new PS and everything works again.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1390 views
  • 0 kudos
  • 3 in conversation
Announcements
