- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN10400 Won't Shut Down
- Mark as New
- Bookmark
- Subscribe
- Permalink
My NAS won't complete shut down when selected from the GUI or initiated by the power button on the unit. It hangs on the "Shutting Down Goodbye" screen with only the power indicator blinking at approximately a 1 Hz rate. Othe LEDs are on solid. Only the WoL function is enabled. Disk Spin Down and Power Timer are both off. And the Log contains all GREEN indications.
Tried to manually re-install the FW from the downloaded ZIP file, but of course that did not complete because it could not shut down to restart. Did an OS Reinstall from the Boot Menu. No luck on any of these efforts. When unit hangs at Shut Down, I have to pull the DC plug from the rear and then reinsert it. Unit operates fine otherwise. Any suggestions would be greatly appreciated!!
Running FW 6.5.1.
One application loaded: PLEX.
1.77TB free out of 1.81TB
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems that the last entry before the system is booting again consistently relates to shutting down the MySQL service.
What do you use MySQL for? Perhaps removing this would resolve the problem.
I can see you don't have much data on this unit (less than 70GB) and it hasn't been factory reset (wipes all data, settings, everything) since you got it with 6.0.0 firmware. So one option would be to backup your data, do a factory default (wipes all data, settings, everything) and restore your data from backup.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN10400 Won't Shut Down
If you disable WoL does that make any difference?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I unchecked the WoL box and that made no difference. Still hangs on the "Shutting down" screen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you update to ReadyNAS OS 6.5.2 now that has been released and check again after you have updated to that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Clicking on the "Check for Updates" button returned a "Your System is up to date" message. So I downloaded the ZIP file and did the manual update, which necessitated the removal of power to get it to restart. I did the manual boot routine to get it to load the OS from the flash and when it finally came on line, the admin page displayed FW 6.5.2 version. So I believe it was updated to OS 6.5.2. BUT, after waiting for all the activity to cease on the hard drive, I clicked the shutdown in the upper right of the GUI and the system is still hung at the "Shutting Down Goodbye" screen with the power LED blinking.
Should I copy off all my data to another drive on my computer and do a factory reset? I can't think of anything more to try. This problem used to arise once in a while, but not consistantly like it does now. Hope it's not a HDD going bad. If you have anymore suggestions, I'm willing to give it a try. Thanks for your efforts.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please send in your logs (see the Sending Logs link in my sig).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Plex Media Server appears to be the culprit. When I removed it from the NAS, the unit could restart or shut down consistantly. Something has happened to Plex that it won't even reinstall now. I guess I'll have to go without, but I'll sure miss the nice user interface it had, showing album artwork and info on the artists. But I'm sure glad you were able to find the problem. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think the problem is Plex. Plex doesn't use MySQL.
I have sent you a PM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After cleaning some things up the NAS now can shutdown properly with Plex installed.
