- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN214 Cannot connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Raidar sees it, but I cannot connect to the admin page through a web browser, connection refused. Apparently pool is offline. I've had a case open for almost a week now with little response :/. Can't seem to attach logs here, either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN214 Cannot connect
And you shouldn't post them publicly.
@JohnCM_S can check on what the hold-up is on getting a response on your case. He might also be willing to review your logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, that would be awesome if someone could take a look. My device has been down for a week now, and I don't seem to be getting anywhere.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Starminder,
You may PM me the case number so I can check what happened to the case.
You can also send to me the logs so we can review it as well. You may upload it to Google Drive then PM me the download link.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can also take a look at those logs for you.
Upload the log zip file to Google drive or similar. Share it and PM me the link to download them.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi again
Thanks for sending logs over.
Something odd is going on with the raids here. I think you were running a raid0 on 3 disks (Volume: "Pool")?
Did you try to replace a disk at some point? Or did you try and add a disk?
Let me know a little more about your setup. Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the current setup is raid0 with three 8TB disks and the Volume name is Pool. I noticed Plex was offline and rebooted, now the volume is ofline and I cannot connect to the admin interface. Like I mentioned, Raidar dies see it, but I'm stuck in this half pregnant state. Is there way to get to a safe mode from here? Thanks for looking, I need all the help I can get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have booted into tech support mode....still stuck, appreciate thoughts on what comes next.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Starminder wrote:
Still stuck. Anyone?
It'd be best to wait for @Hopchen or @JohnCM_S since they've seen your logs.
My next step would be mount the OS partition and chroot. You do that by entering
# rnutil chroot
Were you able to access the NAS shares with SMB before you booted into tech support mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm on Windows 10. I only tried web browsers to accesss the admin interface, so far still to no avail. Raidar can see the box, that's how I got the logs. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then I suggest rebooting the NAS normally, and seeing if you can access the shares from file explorer.
The results there will focus the rest of the troubleshooting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. Went back to a normal boot. No Admin page access from a browser.
Tried Windows Explorer. There's a "ghost" there, but I get the error:
"Windows cannot access \\\SPROCKET\Documents
Check the spelling of the name. Otherwise, there might be a problem with your network. To try and identify and resolve network problems, click Diagnose.
Error code 0x80070035
The Network Path was not found.
Raidar sees it. but indicates the volume is inactive.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. A reasonable next step is to power down the NAS and test the disks in a Windows PC with vendor tools. That would be Lifeguard for Western Digital and Seatools for Seagate. You can connect either with SATA or via a USB adapter/dock.
Label the disks by slot as you remove them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry @Starminder
I left you hanging. Had to go inactive for a while. Where did you end up with this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No worries @Hopchen . I appreciate your help. I'm still in the same boat.
I tried rebooting to no avail. Cannot see device through admin page. Can see device with Raidar. Per Tier 2 support, booted to Tech Support mode. Case was escalated to Tier 3 over a week ago, have not heard from anyone since.
I guess I can run the tools and test the disks next, I was trying to leave things in place for Netgear Support as they requested.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, so you opened a case with NTGR. Well, leave the NAS as is (in tech support mode) and wait til L3 takes a look at it 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Hopchen Well, I'm still back where I started, nothing's changed. There's been no activity on my case in almost a month. Is there a way to escalate the case to a supervisor?
Case #41192043
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Starminder,
I have forwarded this to an appropriate team so they can send a follow up to the L3 handling the case.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Starminder,
I have sent another follow up regarding the case. I am not sure why no one has contacted you yet. I will provide you an update once I get feedback.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Starminder,
It looks like you are already in contact with L3. You may just update us if you will need again our assistance.
