- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN214 No volumes
- Mark as New
- Bookmark
- Subscribe
- Permalink
RN214 No volumes
Hello,
I can log onto my ReadyNAS through ReadyCLOUD but I cannot see any volumes. It states there are no volumes or USB drives. When I try the (currently up to date) desktop app it says "not connected". And yet, when I go through windows I can access the files. When I try to go the admin page, after entering the login information it says "the connection to this site is not private".
I'm pretty new to this but can anyone give any advice? This is about 2 years old.
Thanks,
RJT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN214 No volumes
That's because the certificate is self-signed by the NAS and can't be verified by a certificate authority. You need to click through that warning.
What firmware are you running?
- Mark as New
- Bookmark
- Subscribe
- Permalink
firmware is 6.10.3.
Also when i try to click through the admin logon - it keeps just asking me to log on again and so there's no way for me to push past it.
thanks
Rod
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are using admin for the username, and the NAS admin password?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried that also, but in the past my personal username and password was what was needed. I'm still having trouble.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you log into the NAS admin ui directly (w/o using ReadyCloud)? https://nas-ip-address/admin (using admin as the username). Use the real IP of course.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It gives me a similar problem. I keep typing my log in and password and it just defaults back to the same login and password box .
What's also strange is that on readycloud I cannot see any of the volumes of my drive, and trying to login from windows explorer just leads me to the log in box again. But when I run iTunes (my music is on the NAS) it seems to work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is when you use admin as the username?
What happens if you run CMD on the PC and enter this:
net use * /delete /y net use t: \\nas-ip-address\admin /user:admin nas-admin-password
using the actual IP address and nas admin password of course. Be careful with the typing - particularly the two different slash directions and the spaces.
The first command terminates any open SMB sessions; the second attempts to map the NAS data volume to drive letter T.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After the first command I get:
There are no entries in the list.
After the second command I get:
System error 67 has occurred
The network name cannot be found.
Thank you your help so far - still not sure what's going on.
Rod
- Mark as New
- Bookmark
- Subscribe
- Permalink
And yes, the username "admin" doesn't allow me to log in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What status does RAIDar give you? https://kb.netgear.com/20684/ReadyNAS-Downloads
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAIDar could not find any NETGEAR storage on your network. Check that your storage device is powered on and connected correctly. For more help, visit http://my.netgear.com
This is strange, right?
Thanks, open to more solutions!
RJT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also I have plex installed and I can still access my files through plex. I cannot however use Raidar or Readycloud!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have internet security software running on the PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just the Windows Antivirus. I cannot log into Readycloud and see my server using any other devices either including a work computer and an iphone using the app
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have a backup of the files?
Can you still access the files from a local PC? If so, update (or create) a backup if you don't have one that is up to date.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cannot access on a local PC for some reason. I have backups of the most important files however from prior saves on a portable hard drive, which is good. I don't think I can access the other files now to back them up sadly.
I just can't wrap my head around why I can access media via plex on my tv but cannot log into ReadyCloud, and importantly, how to fix this problem! Do I need to buy a new setup and would I be able to swap my drives to keep all my info?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I figured out that Raidar wasn't detecting because I had to configure windows firewall to allow it access. When I used admin and password I finally got in and can see all of my files.
However I still cannot use ReadyCloud as my Netgear username and password continues to show "no volumes" when I access my NAS. How can I get ReadyCloud to work at this point?
Thanks for all the assistance.
Rod
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you look at the Cloud page in the admin web UI, are you seeing that the ReadyCloud service is enabled?
Also, you should see two green checks at the top of the page (indicating that the NAS can reach the internet, and also the ReadyCloud server).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, so it turns out my ReadyCloud access was locked into an old email address. Under the Cloud tab in the Admin UI interface there is a section for ReadyCloud and it says I was signed in under my old email address and I couldn't figure out how to change it.
I had updated my email recently and apparently the ReadyCloud was not able to recognize my new email address to give me access to my files.
Does anyone know how to change this?
Thanks!
Rod
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi roderickjtan,
Have you created a new ReadyCLOUD account for your new email address? If you already created one, you can just click the Leave button under ReadyCLOUD and then rejoin the NAS to ReadyCLOUD using that new email address.
If not, you may update your email address by logging into the myNETGEAR portal using your old email address then go to My Profile > Login Settings > Change Email, then leave and rejoin the NAS to ReadyCLOUD.
