- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN316 (6.4.1) - usb3 device disconnects
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
I'm using a RN316 and have updated to latest firmware (6.4.1). I'm trying to transfer data from a couple of old hdd's (a seagate 750gb and a 2tb) using a USB3 dock that I recently purchased - ASTONE clonedock DOC-232.
The dock is externally powered, appears to be functioning properly, the RN recognises and mounts the (NTFS) volume. However, it seems to disconnect during file reads at random. It appears to be more sensitive to large file reads than small file reads. The RN reports "The external storage device was disconnected."
Is this possible a BIOS problem aka https://community.netgear.com/t5/Using-your-ReadyNAS/RN314-USB-3-0-disconnects/td-p/876254 ? If so, where can I find an updated BIOS?
Any help would be appreciated.
regards,
deleat
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN316 (6.4.1) - usb3 device disconnects
What is the date showing in bios_ver.log?
Which services and apps are you running?
Did you see this problem before the firmware update or only afterwards?
Can you send me your logs (see the Sending Logs link in my sig)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
/sys/class/dmi/id/bios_date
11/06/2013
/sys/class/dmi/id/bios_version
4.6.5
Just running standard aps. Antivirus, Plex, etc. Logs sent.
I've successfully used other usb3 devices before the firmware update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You already have the latest BIOS.
Perhaps try disabling the anti-virus service and see what difference that makes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you didn't use this particular dock before updating to 6.4.1?
Do your other USB3 disks still work fine with 6.4.1?
