- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN316 Drive upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey community.
I had recently sn Experiance which appeared that there was a failed drive upgrade on my RN316 which had 3x 8TB and 3TB 3TB I replaced the bay 4 which was a 3TB with an 8TB and for some reason the resync didn't go smoothly I backed up as much as I could and then tried a factory reset, took a couple of days but it came online with the right storage that it should for 4x8TB and 2x 3TB but today I noticed bay 4 (the new 8TB this is a wd plus so 7200rpm) has a steady red light. I do a disc check and after 2 days it says that the drive in bay 5 has failed. Is ther any reason why the light for bay 4 will be on instead of bay 5?
it shouldn't matter that bay 4 is a 7200 RPM drive while all the others ate 5900 right?
From New Zealand, 950/450MB Fibre connection, RN316 NAS, Orbi RBK850
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@AKLGUY wrote:
Thank you StephenB I will give that a go this weekend.
If it is the 3TB in bay 5 that is bad I guess I can put in the 3TB i took out of Bay 4 right? Just format it first?
I suggested testing the old Bay 4 drive first on your other thread, just to make sure it is healthy. If you run the write zeros test, you will not need to format it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN316 Drive upgrade
It shouldn't, and I have used mis-matched speeds myself. @Sandshark had an issue once (related to spinup time), but I think that was unusual. FWIW, there is no reason why the mismatch would target drive 5, and not the others.
That seems odd, and you might want to confirm that drive 5 has failed and not the new drive. You can power down, and test both in a Windows PC with vendor tools (Seatools for Seagate, either Lifeguard or the Digital Dashboard tools for Western Digital).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
