× NETGEAR will be terminating ReadyCLOUD service by April 1st, 2023. For more details click here.
Reply
RN316 - reverse on apt-get update(how)
FeliC
:~# apt-get install rsync
Reading package lists... Done
Building dependency tree
Reading state information... Done
rsync is already the newest version (3.1.3-1.netgear1).
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
linux-image-extra : Depends: linux-image (= 4.4.218-610070001) but 4.4.218-6100 80001 is to be installed
mysql-server-core-5.5 : Depends: libaio1 (>= 0.3.93) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
--rsync is just an example--
it seems that my last-time using ssh (should be "apt-get update") cause this problem.
i know i shouldn't do it but just forget at that moment.
can you guys tell me how to reverse/undo those packages?or i have to reinstall?
Message 1 of 2
Marc_V
NETGEAR Employee Retired
Re: RN316 - reverse on apt-get update(how)
@FeliC
Welcome to the Community!
This can be corrected but may need intervention via SSH since the solution may vary depending on the setup you may have. Have you tried OS-reinstall? If you have an existing Support contract sending an E-mail to readynassupport@netgear.com may help.
HTH
Marc_V
NETGEAR Community Team
It's what you do that defines you
NETGEAR Community User Guidelines
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 493 views
  • 0 kudos
  • 2 in conversation
Announcements
