- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN422 reboot destroyed both my Discs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
replaced my RN104 with a RN422 - the 104 seemed to be very slow and was constantly rebooting randomly when ever more than one person was accessing it.
I used a 6tb WD Green HDD (from the 104) to Disc 1 position, formatted and restored the data from backup drives - ended up as Blue and Healthy on the Graphic. Was shown as JBOD and as Flex-Raid. Added one more 6tb the same as Disk1 to disk 2, Formated and made a global spare (Green Coloured on the graphic).
the Unit went to recovering and sync mode so i left it the 48 hours to sort itself out. I added a new USB Drive to backup data at a later date but that disc wasnt seen so after the Sync was completed and both Discs showing Blue i rebooted the unit so the new USB external drive could be seen.
There seemed to be no isue with the reboot at first but the USB Drive still couldnt be seen and Disc 1 was showing RED & Disc 2 Green on the Graphic. The only option for both was to DESTROY the volumes.
Any ideas what has gone wrong and what can i do about it ??
Looks like the options are to Format both disks and transfer all the data across again ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The logs show that disk 2 has an uncorrectable sector count of 672. That's huge. I assume that's the disk taken from the old NAS?
Sounds like due to that the new disk wasn't able to sync with the old disk.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN422 reboot destroyed both my Discs
Can you send in your logs (see the Sending Logs link in my sig)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
that makes sense to me as one of the 6TB Discs in my 104 was throwing up errors - I'll replace the discs with a new ones (WD Red 6TB) and go from there.
They are a quite old pair of WD Green 6TB and i didnt ever set up the Disc Spin down so they have probably been running constantly for the 20,000 hrs as shown on the Disc Data that pops up if you hovver over the Green dot on the graphic.
Thanks for your help.
