Cooperkc's avatar
Cooperkc
RN4220X backplane question
Hello,
So I'm planning on removing the motherboard from this case and replacing it with something newer.
Does anyone know if the backplane on the ReadyNAS RN4220X can support SAS drives assuming I installed a SAS raid card in my frankenNAS?
    • Sandshark's avatar
      Sandshark
      Sensei
      schumaku wrote:
      Check the internal of the RN4220X ... the storage slots are connected by SATA cables, the connectors for the HDDs are pure SATA. FMI https://tech.sina.cn/2010-11-01/detail-ichmifpy4502247.d.html
      That's a 4200, not a 4220.  They are entirely different.  The 4220 (and 3220) has three SFF-8087's at the backplane and two SFF-8087's and four SATA connectors at the motherboard.  The drive connectors in both will handle both SAS and SATA drives but the motherboard drive controller is SATA only.  I suspect that the 4220 was manufactured for Netgear by Chenbro, since the chassis is a Chenbro one, while the 4200 is a SuperMicro design.  The motherboard is a Netgear unique one, but I suspect the backplane is also a Chenbro design.  There would be little reason to design a unique one.  It certainly looks to me like it would support SAS drives, but since the 4220 motherboard doesn't support them, there is no way for me to check.
      Unless you have a cheap source for them, I recommend against using SAS, though.  They provide far less SMART diagnostics and, with spinning drives, there is no speed advantage.  The only reason to choose them over SATA, IMHO, is if everything is dual port, which the 4220 backplane would not support (it has no connectors for another channel).  You can, of course, use a SAS controller with SATA drives.
      Personally, I'd go with a SuperMicro chassis, as parts are readily available, should you need them.
      FYI, the 4200V2 does support SAS drives in the eight slots that connect to the motherboard SFF-8087's.  The original 4200 (as in the linked description) doesn't have SFF-8087's or a SAS controller.
      • Cooperkc's avatar
        Cooperkc
        Thank you for the in depth feedback.
        I was going to replace the motherboard as it seems to be ATX.
        From there my plan was to go get a low profile SAS controller card and connect to the backplane.   Going to use SATA drives for now but thought, if it supported it,  upgrade in the future to SAS.
        You recommend a Supermicro chassis, but since I already have the 4220X sitting here I planned to just reuse that.   Unless you can recommend a fairly inexpensive way to get a decent Supermicro chassis (maybe from an old used server)?
        Is there a chassis you would recommend?
ProSupport for Business
