Orbi WiFi 7 RBE973
Reply
RN516 USB3 stability problems(many I/O errors) and other issues
MauroA
Tutor
Hello to all.
From the beginning we have been using an RN516 as a target for our Veeam backup with good results because it is fast enough. However, we need to copy those archives in an external USB disk for security reasons and we programmed that operation with its own NAS backup procedure: if we use USB3 disk we get through stability problems (see attached image).
We noticed that only the first attempt is successfull and with the second one,  errors arise and  than  we have to restart the NAS because USB ports goes down and at that point it is not able any more to recognise a new disk connected to it.
We made several tests:
1)we changed the cable with a quality one;
2)for testing we used a seagate external disk an other 2 different external case (ASM chipset).
The strange thing is that the procedure shows to be pretty rock stable if we use a USB2 disk.
I have also a curiosity: is it correct that every time I connect and  disconnect a USB disk  ,in my Esxi log I see the warning  “All Paths Down state"  that last 7 seconds? At the same time, the NAS log shows that NFS protocol stops and restarts.
Thank you in advance for your help.
Model: RN51662E|ReadyNAS 516 6-Bay
Message 1 of 4
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: RN516 USB3 stability problems(many I/O errors) and other issues
Updating the USB3 F/W for the RN516 resolved the problem.
Message 4 of 4
All Replies
JohnCM_S
Hi MauroA,
Can you send the system logs of the NAS so we can further investigate it? You may upload it to a file sharing website and PM to me the download link.
JohnCM_S
NETGEAR Community Team
Message 2 of 4
MauroA
Tutor
Hi JohnCM_S
I have sent the PM : have you got the time to evaluate it.
Thank you for your support.
MauroA
Message 3 of 4
mdgm-ntgr
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1609 views
  • 1 kudo
  • 3 in conversation
Announcements
