- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN524X00 Giving error message: "System volume root's usage is 100%"
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a RN524X00 with 4 2-TB hard drives in a RAID 10 configuration.
I was using 2.07TB of the 4TB volume to store videos and files, with a scheduled daily backup to a 4TB USB drive attached to the NAS and a nightly backup to CrashPlan.
After adding approximately 50GB of new files to the share, I began receiving alerts that said the system volume root's usage is 100%.
I have looked at many other topics here to find a solution, but nothing that applies to my issue. I have only rudimentary skills in SSH and am looking for some guidance on how to resolve this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN524X00 Giving error message: "System volume root's usage is 100%"
Welcome to the Community!
System volume/OS root volume is different from the Data volume where you store your videos and files. This do not typically gets full, common issue why it gets full are Apps installed on your NAS that uses the OS volume to store data instead on the Data volume.
I would recommend contacting NETGEAR Support to get assisted on resolving this issue especially if you are not comfortable working with SSH. If this is a brand new unit then you will have 90 Days phone support available or you may opt to purchase Support contract.
You can login to my.netgear.com and log a case so an expert will be able to assist you on this issue and get it resolved/
Hope this helps!
Regards!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ChronosGlitz wrote:
...and a nightly backup to CrashPlan.
Did you install CrashPlan on the NAS? If you did, that is likely what is causing the full OS partition - in particular the CrashPlan cache can easily fill it.
If that's the issue, you can create a new cache folder on the data volume, and replace the current cache folder with a soft link to the new location.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not have CrashPlan installed on the ReadyNAS, it's installed on a network machine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you aren't comfortable with ssh, then the best way to resolve this is to use paid support via my.netgear.com.
The other approach is to do a factory reset, reconfigure the NAS from scratch and restore the data from backup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am comfortable enough to enter basic commands in SSH and am looking for someone to help me figure out what is filling up my root volume. I am not willing to go nuclear and do a factory reset with a restore until i've exhausted all of my options.
I've run the df -h command with the following results:
Can anyone recommend next steps?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The basic process to figure out where the space is going is outlined here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN314-FW-6-7-1-root-partition-full-...
Once you figure that part out, post back.
Here's a sample from my NAS, to give you some idea on about how much space should be used in the top level folders. Note your's won't exactly match (even if there was nothing wrong).
root@NAS:~# mount --bind / /mnt root@NAS:~# cd /mnt root@NAS:/mnt# du -d1 -h 6.4M ./bin 0 ./boot 24K ./dev 11M ./etc 0 ./home 33M ./lib 4.0K ./lib64 0 ./media 4.6M ./opt 0 ./proc 24K ./root 0 ./run 11M ./sbin 0 ./srv 0 ./sys 0 ./tmp 199M ./usr 586M ./var 0 ./mnt 0 ./data 0 ./apps 39M ./frontview 887M . root@NAS:/mnt#
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, I followed the instructions from that page but I just don't see what the large files are that are causing the error. Here are the results:
- Mark as New
- Bookmark
- Subscribe
- Permalink
does df /mnt -h still show the volume as full?
Also, are you seeing any large files in the root (e.g. /mnt)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here are the results of df /mnt -h:
I don't see any large files in the root. If I am using 3.5G of the capacity of the root, why does the previous command only show 1.5G worth of files?
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is the question.
It's possible that there are large hidden files in the root. Did you try ls /mnt -alh ?
Perhaps also run btrfs fi df /mnt and post what it gives you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, i have tried both commands:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you migrate your disks from an arm platform (RN100 or RN200 series)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I migrated from an RN104 to an RN314 in 2017 and then to an RN524 in 2018.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, that explains why the OS partition is ext instead of btrfs. The arm platforms use ext when they create the OS partitions, and the migration process doesn't change that. The x86 platforms use btrfs.
The challenge here is that we can see that the OS partition is full, but we can't locate the files that are making it full. I am thinking that there might be some file system corruption on the OS partition. The best thing to do now is probably to back up your NAS and do a factory reset (though that is painful).
Paid support (my.netgear.com) is of course another option, though they might also end up recommending a reset.
