- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RND2000v1 is not start
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
My RND2000v1 is not starting. Power led, disk leds, all leds are blinking 3 times fast and stopping for 5-10 sec and doing it again. I tried without disks and with one disk in first bay and second bay, nothing change. I tried reset it using the reset button on back and nothing happened. Also tried recover boot from usb, as well nothing happened. Any ideas?
Best regards.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RND2000v1 is not start
Hi miglanc,
Welcome to the Community!
Do you have RAIDar installed on a computer? If yes, does it detect the NAS even if there are no disks inside it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately is not detected by RAIDar with or without disks. Is not even show up in index connected devices on my router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Usually the Duo's error codes start with three fast blinks, followed by 1-5 slow blinks:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
- attempt a USB recovery procedure
- replace the memory
Do you have data that you need to extract from the NAS? Or do you have a backup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My apologies for late response. I was unavailable for long time.
If is possible to recover data from raid 0 via PC?
Regarding repair, I don't want to fix this NAS is to slow anyway for UHD. I will buy new one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could try RAID recovery software. R-Studio is worth a try. If that fails, perhaps try the more expensive ReclaiMe. I believe both will show you what files they can recover before you purchase.
