- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ready nas NV+ booting problem HDD?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I have a readynas NV+,with 4 HDDs of 2TB. Suddenly I couldn't access my files anymore.
Did a reset but it hangs on booting. It also failed to get to the front page via Raidar.
I bought a 2nd hand Readynas NV+, with 4 1TB.
I put the 4x1TB HDD drives in my own Readynas NV+ and it works well.
so the problem is not the readynas nv+ itself.
I put my own 4x2TB hdd in the bought 2nd hand readynas nv+.
Now it's this one hanging with the same drives (my 4x2TB) on boot.
How do I find out which disk is broken, or have I really lost everything.
How do I find out, and is there anything to fix,
all family videos and photos are on it, and more important information.
I used translate, thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved.
hooked up 3 HDD to a desktop Computer
With recovery software, it could find all maps. 5,4TB
and it was all possible to recover.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ready nas NV+ booting problem HDD?
Unfortunately, you have learned that RAID isn't enough to keep your data safe. Hopefully you can get it back, and then put a backup plan in place.
@gerritreijnders wrote:Did a reset but it hangs on booting. It also failed to get to the front page via Raidar.
What kind of reset? A factory default (sometimes called factory reset) is destructive.
Can you connect the disks to a Windows PC (either with SATA or a USB adapter/dock)? If so, try testing them with vendor tools - Seatools for Seagate, WD's Dashboard for WDC. Run the long generic test on each (which will take a couple hours).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah what kind of "reset" did you perform.
While it's Booting... can you ping it? Can you SSH into it?
My problem was solved when I deleted a bunch of large log files:
- Mark as New
- Bookmark
- Subscribe
- Permalink
i hold the reset button power button for 5 seconds the leds go on.OS
I did a memory test but thats ok.
Now they are in the NAS almost a day, booting ...
led 123 are on
led 4 is blinking
Power button, first blinking, now solid blue.
Raidar
Status, system is starting
IP adres 192.168.168.168
Else i cant do nothing with Raidar
All HDD are the same WD20EARX 2TB
The test i will try.
Thanks so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
reques timed out
send 4 packaged sent 4 received 0 lost 4 100% lost
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved.
